Post by jcoutu1 on May 9, 2016 11:39:46 GMT -6
What are you guys doing? - Kick in and out?
- Snare up and down?
- Stereo or Mono room? If doing stereo room mics, how are you aligning them? XY? Spaced pair on different sides of the room? Mid/Side? Blumlein?
- Front of kit mic?
What do you guys have cooking beyond just the basic micing each drum and a pair of overheads?
Post by warrenfirehouse on May 9, 2016 11:49:36 GMT -6
Constantly changing and experimenting, but as of right now my go to is:
Snare top - 57 or i5 Rack top - d2 Floor top - d4 Kick in - d6 Mono OH - mk012 or tbone sc140 Spaced pair rooms- 3u Audio cm1s
Post by EmRR on May 9, 2016 12:10:08 GMT -6
I own one 57, and it lives on snare. unless it's a super light touch brushes thing then it may get a KM140 or Octava 012 omni. Toms can be RE-20, RE-38, 666's, 421, 414, UMT70S, K47H/012, 012 omni, again depends what it is. Kick can be 666, RE-20, 602, Red/012, K47H/012, UMT70S..... OH is almost always M130/M160 mid side, matrixed to stereo on the way to print. Room tends to be Samar MF65 out front around mounted tom height, but can be another Samar custom stereo or even a SASS-P. Mid side if it's the ribbons. Lately the 1932 Carrier model 94 tube mic gets used as a mono room mic for thickness aspects. Sometimes a Shure 300 behind the drummers body so they are baffling it off a bit, smashed up with an RCA BA-78A talkback limiter, which is a pre/limiter combo in one. Among the most smashed things I've ever heard. They need a good bit of tech sussing to sort out best practices with, you won't buy one off ebay and have it work well without sorting the right associated support circuits. Not used if the Carrier 94 is employed.
HH: never. just not needed.
Approach is usually such that close mics might not be employed in the end, if they aren't needed. They are viewed as support rather than OH/amb viewed as such. I pretty much never double mic kick or snare. I don't mic terribly close with the 'close'. I don't reinforce with samples unless a kick is totally hopeless, then that one drum might get a bit mixed in, really only one guy locally I can think of I've used that with.
Post by jazznoise on May 9, 2016 12:15:46 GMT -6
Standard setup for me is this:
Kick Res Head - Beyer Opus 99 Kick Beater - Oktava MK012 Snare Top - Beyer M201 Snare Bottom - Oktava MK012 Toms - Uher M538 OH's - Rm700 ribbons, blumlein Room Stereo - ECM8000, AB (wide spaced and taped to the floor, hoping to replace them with some nicer omnis) Room Mono - T. Bone SCT 800 (cardioid tube mic, betwen the stereo room mics)
I'll vary the OH's and Stereo room for width, ambience and how much bleed from the band I want. Obviously if the drummer has no top resonant head, or they want a dryier sound, I'll work on a more OH-centric approach.
Post by sozocaps on May 9, 2016 12:51:21 GMT -6
Constantly changing and experimenting, but as of right now my go to is: Snare top - 57 or i5 Rack top - d2 Floor top - d4 Kick in - d6 Mono OH - mk012 or tbone sc140 Spaced pair rooms- 3u Audio cm1s Very similar I use KM184's OH AB Snare top - 57 Snare Btm - 57 or i5 Rack top - d2 Rack btm - e604 Floor top - d4 Floor btm - e604 Kick in - d6 and Beta52 and orig 91 and E 602-II Kick Out D112 and home made sub kick Room U87 or Cad179
Post by schmalzy on May 9, 2016 13:51:57 GMT -6
I'm quite a bit lower end on the gear scale than a lot of you guys are. My mic locker is useable but not near some of the prices of some of the other mics kicking around in this thread. I have a total of 16 inputs. Depending on the tracking day input requirements, I'll subtract mics.
I'm always starting with my overheads. Typically it's two or three mics - spaced pair much of the time and sometimes x/y (I'd love to get a mic stand that would allow me to suspend an M/S pair 7' up over the kit...that's the next purchase). The third overhead is over the ride pointing at the snare (generally the same distance from the snare as the stereo overheads). I really try to use this mic as much as possible and - if this is used with a spaced pair - try to use the space pair for width and spice while I use the middle mic to concentrate on punch and tone. It's oftentimes a ribbon. Many of my mic choice decisions are based off my stereo overhead selection: the LDCs are a little wider cardioid and sound less detailed than the SDCs while the ribbons are nicely subdued up top.
I like having stereo rooms. Often behind gobos. I'll go to mono if I need to (but I'll never go without a room mic).
I also really like having another mic that is trying to get as much personality as possible out of the snare and kick. It's sometimes over the kick pointing at the snare, it's sometimes under the snare pointing at a piece of wood on the floor, it's sometimes a couple feet in front of the kick pointed under the rack tom at the snare.
From there it's all pretty standard placements.
OHs - AKG Perception 400 LDCs or M-Audio Pulsar II SDCs for the stereo mics and a modded Apex 205 or Cascade Fathead for the middle. Every now and then I'll use Fatheads as a spaced pair and an AT4040 in the middle if the cymbals need to be tamed. Rooms - Cascade Fatheads in mono or stereo or Perception 400s in Mid/Side Personality mic - AT4040 or Shure PE45 (early 80s handheld dynamic mic) Kick In - SM7B or Heil PR40 depending on needs Kick Out - AKG Perception 400 if not used somewhere else Snare Top - SM7B, Heil PR40, or SM57 depending on what's on the kick drum Snare Bottom - Cascade M39 (random Chinese SDC) or SM57 or Shure PE45 Toms top (no bottom) - Cascade M39 or Sennheiser e604
I'm looking at a couple mic purchases in the not-too-terribly-distant future. I'd like to get another AT4040 but I'm most interested in a legit pair of SDCs. I'm really digging what I've heard of the Mojave MA-100 tube SDCs. Anyone have experience with those?
Post by indiehouse on May 9, 2016 13:52:54 GMT -6
Anyone doing recorderman with their OH's?
Post by sozocaps on May 9, 2016 14:07:34 GMT -6
Anyone doing recorderman with their OH's? Tried Recorderman , XY, ORTF Glenn Johns, etc... I keep going back to a good spaced pair where I get draw a line through the kick and snare and adjust overheads accordingly for a good strong center image.
Post by sozocaps on May 9, 2016 14:09:27 GMT -6
On the cheap side of things the CAD e70 are bad ass... Almost as good as my km184's I use the e70 for HH and Ride...
Post by jazznoise on May 9, 2016 14:18:36 GMT -6
Never enjoyed Recorderman or Glynn Johns. In particular the panning across the kit feels really lumpy.
Post by drbill on May 9, 2016 14:35:49 GMT -6
I've been blessed with two great rooms to record drums, and a drummer who is a great friend that is a monster player and knows how to tune his kits...
First :
Drummer Drums Room Mics
Then :
Me. :-)
If you get the first things right, it's kind of hard to screw things up. I mean, you CAN, but if you have a decent degree of experience, it will be pretty easy.
I always start with OH's first. I like em fairly high and prefer an ambient sound as part of the "kit" sound. I have a distant memory of a pair of C12's from OHenry's that I LOOOOOVED. But for me, the $30k+ of getting real C12's will never happen. So....I've been searching for the holy grail OH mics for a couple of decades. At this point I have a pretty large mic locker, and I ALWAYS come back to Gefell UM70's or M71's in spaced pair on OH's. The sound is alive, 3 dimensional and exciting. What else do you need?
After that, Kick is generally a UM70 on the outer resonant head in Fig8 with the null facing HH, Snare and/or cymbals. Depends on the kit. Inner mic is generally a Audix D6 near the beater.
At this point I should be able to "stop". The sound is there. If the drummer is balanced in his performance, the Gefell's get as much of the snare and toms and cymbals as I need. The kick mics are there for the beef. But I almost always keep going anyway for safety.....
Snare changes a bit, but I tend to start off with an old Shure 545 unidyne and a KM84 on the SIDE of the shell. No underneath mic. Other top of head mics include Audix i5's, Beyerdynamic M201, various 57 variants, and the 441 gets use as much as all the others combined. KM84 is also awesome on the top of the snare, but I rarely risk putting one in harms way. If you want a condenser tone, the MXL 991/603/604 is surprisingly good, and I don't care if they get wrecked. I don't have any anymore, but they are definitely useable.
Toms are generally Michael Joly 219PE's, with CAD M177/179's as a backup if it's a more "modern" sound. I HATE, HATE, HATE 421's as their off axis ruins my drum sound if left open. I like leaving the tom mics open if they sound good, and the way I do it, it always sounds more "alive" leaving them open with not being played.
I don't generally go for a stereo "room" sound, but always have at least one mic in the room and often have 2 or more mics up. The Joly 205's are awesome and have seen a lot of use here. HUGE sounding and flat (-3db) down to 8Hz. Big sound. Condensers get used less. Currently my fave is my RCA 77DX. Something magical about that mic, and it just compresses so much more elegantly and sweetly than anything else. I guess I need another.
I'll often put ether a 205 or my MK47 out in front of the kit 6 feet or so and balance K/Sn in that mic. It's a great sound if your room is good.
Come mix, this combo generally just "sits" without any serious EQ or compression. I never track the drums with compression unless the drummer sucks, and honestly, I haven't had to do that for a loooong time. The rooms will get compressed eventually for "that" sound.
Preamps are Silver Bullets (my new go-to) as I have 4 of them now, CAPI VP28's/26's, AML 1073's, D&R's occasionally, Purple Biz's occasionally, and the ACMP 73/84's often The Silver Bullets on cascaded mode of API into Neve is unbelievably awesome for that trashy alt rock / hip hop sound. Something I'd looked for for years, but could never quite attain.
Come mix time it's more Silver Bullets, old API EQ's, Chop Shops, 528's, SA3A's, Varimu (sometimes), Serpent Splices and on Bus (if I go there) a 4001, and LilPEQr's (the gold originals) to sometimes brighten up the OH's, but generally Brad's killer EQ on the SB has taken over that chore....
Simple right? hahaha!
Post by jcoutu1 on May 9, 2016 14:47:18 GMT -6
FWIW, here's what I'm looking at for the upcoming session... 1
| Kick In | API 1 | Beta 52 or D4 | 2 | Kick Out | Daking 1 | Aston Origin | 3 | Snare Up | VP28 | SM57 | 4 | Snare Down | NightPro 1 | Audix i5 | 5 | Rack | API 2 | E604 | 6 | Floor 1 | API 3 | E604 | 7 | Floor 2 | API 4 | E604 | 8 | Hats | NightPro 2 | MK012 | 9 | Over Hats Side | RND 1 | BeesNeez Lulu | 10 | Over Ride Side | RND 2 | BeesNeez Lulu | 11 | Room 1 Blum | Chandler Germ 1 | Fathead | 12 | Room 2 Blum | Chandler Germ 2 | Fathead | 13 | Front of Kit | NightPro 3
| BeesNeez Frank | 14 | Bass DI | Daking 2 | SVTDI | 15 | Bass Cab | API 5 | Heil PR40 | 16 | Guitar DI | Daking 3 | Countryman | 17 | Guitar 2 DI
| Daking 4 | Countryman | 18 | Vox | NightPro 4 | SM7B |
Post by schmalzy on May 9, 2016 15:14:53 GMT -6
Toms are generally Michael Joly 219PE's, with CAD M177/179's as a backup if it's a more "modern" sound. I HATE, HATE, HATE 421's as their off axis ruins my drum sound if left open. I like leaving the tom mics open if they sound good, and the way I do it, it always sounds more "alive" leaving them open with not being played. Awesome info, drbill! (I'm about 100% that's not going to tag you in the post like I'd like...hmmmm...). Thanks for detailing your thought process. I agree with you about 421s on toms. They "sound" good but their bleed is terrible. If you're getting good isolation, your drummer is great at really blasting the shells and laying off the cymbals, and you're gating (manual "gating" is what I prefer) the non-tom stuff out then 421s can be super useful - but their off-axis is gross. That's why I've settled on mostly using some SDCs on toms. They're not the best sounding SDCs to be honest but their polar pattern is fairly tight, these can take the level (something like 137db), the top end is hyped from the factory, and the bottom end is there (but needs some boosting)...plus, since it's a condenser, it seems like the transient response is quick and I find I like big transients for toms. I've also used a 205 in front of the kit (that 6' distance seems great) before, too - I always try it when I'm tracking drums outside my studio. I really dig it. My room doesn't seem to like that position as much - must be something in the acoustics. What are you hearing in the API preamps (Silver Bullet front end and the CAPI stuff) that makes you like them?
Post by Deleted on May 9, 2016 16:01:28 GMT -6
Kick in - Beta 52 Kick Sub - Solomon LoFreq Snare Top - SM57 Rack - Sennheisser 905 clipon Floor - " Overheads (spaced pair, recently went back to this and I love it) - Josephson C42 Stereo 12guage as a room mic Hi Hat - SM7B
All these hit VCC and Kramer Tape on the way in plus whatever EQ I may add. It's this configuration 90% of the time.
Post by drbill on May 9, 2016 16:20:40 GMT -6
Toms are generally Michael Joly 219PE's, with CAD M177/179's as a backup if it's a more "modern" sound. I HATE, HATE, HATE 421's as their off axis ruins my drum sound if left open. I like leaving the tom mics open if they sound good, and the way I do it, it always sounds more "alive" leaving them open with not being played. Awesome info, drbill ! (I'm about 100% that's not going to tag you in the post like I'd like...hmmmm...). Thanks for detailing your thought process. What are you hearing in the API preamps (Silver Bullet front end and the CAPI stuff) that makes you like them? Thanks. No problem. I used to use API's (mostly on consoles) exclusively for drums. Then I found Neve. LOL The API's and CAPI's can't match the Neves for huge bottom on kick. But they are PUNCHY. That's why I like them. Plus they are a little brighter. I'll often use the Neve's for snare too if I'm looking for phat sound over punch. Downside for 500 series API's - you can't gain stage effectively, and the pad SUCKS. CAPI's are much better. No need to use the pad as you've got the output attenuator and they saturate so nicely. I like the Silver Bullets because of their versatility - I can easily switch back and forth with the flick of a switch between aPI or NEVE. (best pf both food groups.) The sonics are large and smooth. The metering is AWE-SOOOME. They saturate oh so nicely. The gain staging possibilities are exponentially better than any other mic pre out. The EQ is Sweet for simple touches. (not carving huge holes). It's nice to have a recallable, gain matched stereo preamp. That's pretty much it. Oh yeah.....its got my name on it. :-)
Post by gouge on May 9, 2016 16:33:22 GMT -6
Depends on what I'm recording.
The constants are sm57 => vp28 snare top and a pair of ev635a room mics on the floor in xy through sytek pre.
After that it depends on the session. If only drums for heavy stuff I add Ksm137-vp28 snare bottom Jolly mod mk012-lola rack tom Jolly mod ntk-daking floor tom M380-ma5 inside lick Atm450-ma5 batter M160-sytek spaced pair over the centre of cymbals RCA sk46-Lola mono room.
If doing entire band I drop out the double mics and run both rack toms into 1 ksm137
For roots/ighter music the ksm137 move to toms, the overheads are jolly mod mk012 in ortf centred through kick snare axis, the kick gets akg d202
For big trashy sound I put m/s low and in front.
I never mic hats.
Post by wiz on May 9, 2016 16:34:20 GMT -6
I am pretty basic
KM184s overheads D6 Kick Beyer M201 Snare SM57s Rack And Floor
Preamps
TG500 Kick Capi VP28 Snare JLM 99NV500 Rack JLM NV500 Floor JLM BA2 Overheads
EQ is Delta Console
Comps DBX160,1176, 54As,STA's (kick, snare. Toms, overheads)
Post by joseph on May 9, 2016 19:03:08 GMT -6
I experiment a lot, but one thing I always have that I think is absolutely key is a good mono picture of the kit. I spend the most time getting this one mic right, usually a tube condenser out front or a U87 overhead or both as options. If I can I'll use this one mic and kick and that's it.
If I do Glyn Johns, I still like a mic out front as a fall back, same with Massenburg spaced pair or whatever. Then sometimes I'll have a room mic or mics farther back.
Lately I've been using one mic on kick rather than bothering with an inside and an outside. M88 or RE20 typically. Just seems to mix better. So I usually spend a long time on this mic and retuning the heads to control the boominess. I'm not a big fan of clicky or unnaturally bass heavy kicks because they can fuck with the groove too much.
Otherwise I use thin cymbals and close mics mainly for reinforcement. I don't usually mic the rack tom(s). Actually I really don't like the sound of more than one rack tom.
E22s or m201 on snare generally. Sometimes I put a ring of keys in the hihat to dampen it, and I force myself not to use more than one or half a moongel on each skin, just kill the ring a bit but that's it.
If I need a lot of rejection or they complement the cymbals (namely ride) I'll use m160s as overheads.
If the room and cymbals are sounding better more open, then sometimes KM84s, or U87 on floor tom side or sorta behind the drummer and something reliable overhead. Again, I try to have one mono source where the whole kit sounds good that I can fall back on.
Post by jcoutu1 on May 9, 2016 19:32:13 GMT -6
I experiment a lot, but one thing I always have that I think is absolutely key is a good mono picture of the kit. I spend the most time getting this one mic right, usually a tube condenser out front or a U87 overhead or both as options. If I can I'll use this one mic and kick and that's it. If I do Glyn Johns, I still like a mic out front as a fall back, same with Massenburg spaced pair or whatever. Then sometimes I'll have a room mic or mics farther back. Lately I've been using one mic on kick rather than bothering with an inside and an outside. M88 or RE20 typically. Just seems to mix better. So I usually spend a long time on this mic and retuning the heads to control the boominess. I'm not a big fan of clicky or unnaturally bass heavy kicks because they can fuck with the groove too much. Otherwise I use thin cymbals and close mics mainly for reinforcement. I don't usually mic the rack tom(s). Actually I really don't like the sound of more than one rack tom. E22s or m201 on snare generally. Sometimes I put a ring of keys in the hihat to dampen it, and I force myself not to use more than one or half a moongel on each skin, just kill the ring a bit but that's it. If I need a lot of rejection or they complement the cymbals (namely ride) I'll use m160s as overheads. If the room and cymbals are sounding better more open, then sometimes KM84s, or U87 on floor tom side or sorta behind the drummer and something reliable overhead. Again, I try to have one mono source where the whole kit sounds good that I can fall back on. You must be doing jazz or folk styles? Natural stuff?
Post by joseph on May 9, 2016 19:47:02 GMT -6
A little harder than that usually, but yes, I would say I prefer a more natural drums in a room sound, at least as a starting point.
Post by Randge on May 9, 2016 23:03:56 GMT -6
I am a very organic natural drum sound guy. I just don't care for the soggy, slow, wet Kellogg's box snare sounds or the overly smack-y, basketball bouncing (5K boosted 15 db) kicks that are en-vogue at the present. Here is what I track with. I rarely use all the mics, but it's nice to have the options and not need them than the other way around for me. Kick in Beta 52 RTZ 9762A preamp, RTZ 1549 eq, Neve 543 comp Kick Out Cascade phantom powered Fathead 2, nulled from the snare and hat bleed RTZ 9762A, Harrison 32 eq and Empress 519 comp Snare top PM-9 Miktek RTZ 9762A RTZ 1549 eq and great River PWM 501 comp Snare Btm Sennheiser 441 RTZ 9762A RTZ 1549 eq and great River PWM 501 comp hi-hat Shannon Roads hot rodded MA-101 Mojave RTZ 9762a pre, RTZ 1549 eq and Capi 526 comp Tom 1 Miktek PM 10 RTZ 9762a pre, Electra Eq, usually wait till post to compress Tom 2 vintage 421 RTZ 9762A pre, Electra eq, usually wait till post to compress Tom 3 Miktek PM 11 RTZ 9762A pre, Harison 32 Eq, usually wait till post to compress. if it's a 2 tom session, I will use the Hippo comp occasionally. Overheads Spaced Mojave MA-201's and a Stereo Royer ribbon above the drummers right ear and angled at the kit RTz 9762a's, Elysia X-filter and X-pressor comp Rooms stock K2 Rode's with Mullard tube upgrade RTZ 9762 19" rack preamps straight in with no eq or comp. I move these room mics a lot and they are always a huge part of my sound. In post the Capi 526's will be my go to here. Extra ambience mics 4 PZM mics placed as needed for song I use all kinds of different preamps and outboard depending on the music in the session with these mics. I love the telefunken V-72's, Edwards Audio preamps are great as well, or sometimes I go squeaky clean and use Radial pres or AEA 500 series preamps. Most of the time I wait for post work to do any carving and compressing with these. Lo fi grunge mics Grundig stereo tabletop mics Ampex 350 preamps and I push the input stage to gnarly and depending on the session, I make them prominent (or not) while tracking to give some edgy vibe when needed. 20 mics all capturing interesting things that I can take or leave at mix time. My kit is a Tama Star Classic bubinga with a full compliment of Ufip cymbals and is one of the most versatile sets I have ever heard. I was very surprised when I got to Europe with Kenny Aronoff cause he had the exact same kit over there with Zildjian cymbals. He has 4 toms and my kit has the same, but few drummers want to play the 10" tom, so I got it out of the way and placed safe in storage. It all starts with a great player, a great kit and decent gear to capture it. Here is a pic of Kenny's kit and a pic of Wes Little (Robben Ford's drummer) playing mine.
Post by sean on May 9, 2016 23:34:59 GMT -6
I've been using an AEA R88 into an AEA RPQ a lot lately for overheads. I have SM57 with the AMI transformer that I like on snare. Bass drum is an e602 inside. Toms I often use 421's but like a lot of people I hate the way cymbal bleed sounds in them so I try to avoid them with people who hit the cymbals hard in particular. I prefer 414's if they aren't being used somewhere else. 421's sound better on rack toms to me than floor toms, hard to get the right balance of boom and smack on floor toms. Bottom snare another 57, outside kick sometimes a RE20...I don't have a great microphone for that application at the moment honestly. I'd like to get a Bock 195 or FET 47 at some point. Hi-hat sometimes a 451, sometimes as a SM81, sometimes a 57. API/CAPI I like on toms and snare, AML often on bass drum. AML also sounds nice on snare, a little thicker sounding. GML works well on snare too, especially if want a little more top end. But those are usually on acoustic instruments. I try to do something different every session with drums. A different mic, compressor, position...always trying to improve. 90% of the time drummers use my kit, which is a 60's Ludwig 22/13/16. I had the bearing edges evened out and it has a really wide tuning range. Some people are weird about having that done on vintage drums but after 50 years they aren't going to be level, and when they're not it's impossible to get even tension. People are always trying to buy those drums off me. I highly recommend these for floor tom legs: www.musiciansfriend.com/drums-percussion/pearl-r-40-3-floor-tom-rubber-tip--3-pack?cntry=us&source=3WWRWXGP&gclid=CJy95dbjzswCFdgUgQodybkAqQ&kwid=productads-adid%5E83738188347-device%5Ec-plaid%5E131990096427-sku%5E447972000000000@ADL4MF-adType%5EPLAAnd one of these for your rack tom: www.sweetwater.com/store/detail/DWCP9399?adpos=1o2&creative=87424044361&device=c&matchtype=&network=g&gclid=CP-t0OjjzswCFUY6gQodrT0ICwThe increase in sustain is worth it. Especially with vintage drums, those old mounting system really chock your drums.
Post by Ward on May 10, 2016 7:41:17 GMT -6
Default go-to quick set-up.
Kick In = Telefunken M82, kick switch on, Focusrite 220, limiter engaged at 0 Kick Out = Neumann U47FET, ƒ220, limiter at 0 Front of Kick, 3-5 feet out, Blue Kiwi Snare top, T.Funk M80 or Beta 57, or 57, Focusrite Red 6. Snare top2, AKG C460, CK1 capsule and adapter, Vintech X73 Snare bottom, Senn 441, EQ flat, Vintech X73 Toms: tops, CAD M179s into APIs. Bottoms, Senn 421s into focus rite 428s Ride and Hats: Neumann TLM102s into Neve 1272/33041s Overheads: (Neumann) Gefell M930s matched pair usually in ORTF or AB into Never 1073s Rooms: Neumann U87s into Toft channel strips.
That's usually the starting point and then I change things up from there, depending on what the kit, song, artist, genre, arrangement calls for.
Post by swurveman on May 10, 2016 9:37:11 GMT -6
I have a small room
Kick: EV N/D868 + Yamaha sub kick-> API 3124 Snare: Sm57 top and bottom-> API 3124 Toms- Sennheiser 421- API 3124 Overheads: Schoepps CMC 64 spaced pair plus AT 4050 mono-> Vintech X73i Rooms: Bricasti Reverb
Post by schmalzy on May 10, 2016 10:25:30 GMT -6
Kick: EV N/D868 + Yamaha sub kick-> API 3124 Oh, man, I love those N/D 868s on kick and floor toms. I've only been able to use them when I was doing mobile recording (one of the bands I worked with had a couple of 'em laying around) - they worked great! They didn't sound too scooped (like a lot of kick mics do) but were definitely getting me moving towards a finished drum sound before I even had the input gain fine-tuned.
