Post by Johnkenn on Nov 17, 2016 13:51:57 GMT -6
Hmmm...seems like my unit has a balance problem.
Dummy alert
Post by Johnkenn on Nov 17, 2016 14:07:57 GMT -6
Right side seems to be about 6 db softer than the left. I've run a test tone...doesn't happen when I patch in anything else - like two VP28s...It's happening when the compressor is in and out. Any ideas?
Double dummy alert
Post by indiehouse on Nov 17, 2016 14:17:47 GMT -6
Right side seems to be about 6 db softer than the left. I've run a test tone...doesn't happen when I patch in anything else - like two VP28s...It's happening when the compressor is in and out. Any ideas? I've had this happen when my TRS plugs aren't fully seated.
Post by ericn on Nov 17, 2016 14:17:54 GMT -6
Right side seems to be about 6 db softer than the left. I've run a test tone...doesn't happen when I patch in anything else - like two VP28s...It's happening when the compressor is in and out. Any ideas? Awe man this is begging to get comical!
Post by wiz on Nov 17, 2016 14:19:12 GMT -6
6dB sounds like balanced vs unbalanced. (cable type , loose connection etc)
check cables.. then maybe crack the top and have a look see.... are you running through patch bay? try going direct
Post by Martin John Butler on Nov 17, 2016 14:21:33 GMT -6
Bummer, hope it's an easy fix.
Post by stam on Nov 17, 2016 15:57:34 GMT -6
The unit is fine....already spoke with John, problem was at his end.
Post by kcatthedog on Nov 17, 2016 16:08:59 GMT -6
All's well, that ends well !!
Post by wiz on Nov 17, 2016 16:09:43 GMT -6
I am sooooo hanging out for mine... its on its way... its tough to tell where it is from the tracking info....
I am holding off running off some mixes to use it... 8)
Post by Johnkenn on Nov 17, 2016 16:41:41 GMT -6
YES! COMPLETELY MY FAULT!
Sorry, I had to go pick up my kid and my dog that just got spayed today.
My patch bay was set to normal - not denormal. That was the issue.
Post by Johnkenn on Nov 17, 2016 16:43:32 GMT -6
I'll do a more complete review in the review section, but man, just the short time I've gotten to play with it - and put it on drum bus, it's pretty fabulous. It gives a great bloom and euphonic-ness...Can't wait to try it on the master bus.
Post by Guitar on Nov 17, 2016 17:55:07 GMT -6
whoo!
Post by sozocaps on Nov 17, 2016 19:18:15 GMT -6
And might I add... PHUCK stam , are you some kind of voodoo witchy warlock? Are you just ripping out SSL comps and putting them in your own cases? When you orderers get yours, you'll know what I mean. No secrets here mano, just follow the original schematic without changing anything, it should sound the same as an SSL, source the best parts, use your ears and above all use quality capacitors, particularly here where no transformers nor tubes nor other variants come in play. I use Panasonics on the SA4000, Vishay's on the 1073 and SA87 and Solen Fast or Vishay's SA-2A. I will never place chinesse capacitors on the audio path. Thanks for the nice feedback, I am very happy that you guys are happy! Yummmm... I like capacitors.... ! SoZo
Post by Johnkenn on Nov 17, 2016 19:34:28 GMT -6
Damn...so this thing is really good. I'd highly recommend it...
Post by indiehouse on Nov 17, 2016 19:53:53 GMT -6
Damn...so this thing is really good. I'd highly recommend it... Yeah man. Totally digging mine. You ever used the Serpent stuff?
Post by Johnkenn on Nov 17, 2016 19:58:17 GMT -6
No - but I met Mike this summer. Need to get that Chimera
Post by forgotteng on Nov 17, 2016 20:28:09 GMT -6
Good news. Now I'm getting excited. I paid my invoice but haven't got tracking numbers yet.
Post by ericn on Nov 17, 2016 21:19:42 GMT -6
YES! COMPLETELY MY FAULT! Sorry, I had to go pick up my kid and my dog that just got spayed today. My patch bay was set to normal - not denormal. That was the issue. Good to hear it was you not the comp! Had a well known engineer, who I won't name to protect the guilty, who bought a DBX 1066 loved it except one channel was really really quite. He and his tech tried everything sent it back a bit pissed this was serial number #9! Well he sends it in, I walk in to service , beg Rick the service manager to look at it right away! Well on the back there are a pair of -10, +4 switches! One is set -10 the other +4! This guy has all the big awards and been in all the magazines and misses the level switches so John your in very good company! I never told him,so if he reads this I might be in big. Trouble!😱
Post by ChaseUTB on Nov 18, 2016 2:54:52 GMT -6
Good news. Now I'm getting excited. I paid my invoice but haven't got tracking numbers yet. Same here... Good news is the Correos Chile ( Stam's parcel service ) is no longer on strike and the parcel service has upped his shipping limit to 30 units a day...
Post by ChaseUTB on Nov 18, 2016 2:55:25 GMT -6
Damn...so this thing is really good. I'd highly recommend it... Very happy for you
Post by forgotteng on Nov 28, 2016 19:36:08 GMT -6
Got my tracking numbers today. I have a mastering session scheduled for Saturday. Not sure if it will make it for this project.
Post by jeremygillespie on Nov 29, 2016 9:34:37 GMT -6
Got my number yesterday - really excited to start using it with my home rig.
I'm going to try and post some clips of this thing in direct comparison to the bus comps on the J and K series I have access to.
Post by jdc on Nov 29, 2016 13:12:03 GMT -6
Got mine yesterday too, messed around with it on a drum buss and it's perfection
Post by Johnkenn on Nov 29, 2016 15:20:36 GMT -6
I'm sooooo used to working in the box with the Drums that committing to burning a 2 track down has gotten me kinda bummed. I will often decide late in a mix that there's just a tad too much verb on the snare...or OHs need to come down...or something. So, I'm learning how to get this thing in my workflow.
Post by sozocaps on Nov 29, 2016 15:48:59 GMT -6
That's why I have 2 ! One on the drum bus one on the mix...
