Post by rickcarson on Sept 16, 2015 8:17:18 GMT -6
Ill start.
SSL Duende Comp or Hardware Focusrite Red 3. Depending on the song. Flickinger 419 pair (eqp-1a) DMG Essence TB La Limiter
Post by tasteliketape on Sept 16, 2015 8:30:16 GMT -6
Shadow hills equinox summing with iron api 550b Capi vc528 smart c1 electrodyne 511 (sometime) Cory Miller one the RGO members gave me some basic settings that so far have been killer on all most everything just to add that extra once of sweetness like summing Suttle but just a pinch
Post by kevinnyc on Sept 16, 2015 8:35:24 GMT -6
Pair of Manley pultecs Pair of the original single channel Manley Vari-Mus Pair of Capi VP28's (In a moment of financial weakness I almost sold all my Manley gear...which also includes an elop and dual mono pre.....all serial numbers within the first 10 of production.....thank god I didn't let those pieces go, I cherish them so
Post by ericn on Sept 16, 2015 8:43:07 GMT -6
Mines naked!
Post by swurveman on Sept 16, 2015 8:50:20 GMT -6
Slate VTM Smart C2 GML 8200 Arc 2 (I know, I know....)
Post by EmRR on Sept 16, 2015 9:05:35 GMT -6
Western Electric 111-C's FCS P4DMS Dolby 740
Post by tonycamphd on Sept 16, 2015 9:18:12 GMT -6
Post by matt on Sept 16, 2015 9:23:04 GMT -6
SSL Sigma into:
Smart CL1A A-Designs EM-PEQ x2 Neve 542 Tape Emulator x2 Sonic Farm Creamliner Burl B2 AD
Post by svart on Sept 16, 2015 9:30:47 GMT -6
Hardware SSL bus comp on master bus.
Hardware 2254 clone on drum bus.
Post by dandeurloo on Sept 16, 2015 9:37:19 GMT -6
Just a little SB4001.
Post by Johnkenn on Sept 16, 2015 10:10:30 GMT -6
I'm all in the box.
VCC MusEQ UAD Ampex AOM Limiter
Post by bluenoise on Sept 16, 2015 10:19:44 GMT -6
Default vp28, usually gssl (though klanghelm has been taking its spot now and then) followed by waves j37. I rarelly feel the need for eq.
Post by jcoutu1 on Sept 16, 2015 10:53:46 GMT -6
Normally...
Drum Buss Tonelux TX5C Pair Thermionic Culture Rooster
2 Buss RJR SSL style comp Summit EQP-200 Thermionic Phoenix Mastering
Post by unit7 on Sept 16, 2015 11:03:30 GMT -6
Always Steve Jackson's Pultecs and AnalogueTube AT-101, then Slate VTM and Brainworx M/S eq.
Post by Gustav on Sept 16, 2015 11:15:46 GMT -6
"left at default" avatars can do odd things for visual types like myself....I thought the first three post were from the same guy trying to make up his mind until I got around to checking the names.
Ill have pictures of my 2bus in a few days.
Gustav
Post by mrholmes on Sept 16, 2015 13:32:03 GMT -6
Post by tasteliketape on Sept 16, 2015 13:52:02 GMT -6
"left at default" avatars can do odd things for visual types like myself....I thought the first three post were from the same guy trying to make up his mind until I got around to checking the names. Ill have pictures of my 2bus in a few days. Gustav That's my brother Darryl and my other brother Darryl (sorry couldn't help myself)
Post by wiz on Sept 16, 2015 15:22:11 GMT -6
Bob Olhsson
8)
Post by gouge on Sept 16, 2015 15:29:25 GMT -6
Drawmer 1968 Lilpqr Lola
Post by joey808 on Sept 16, 2015 16:08:36 GMT -6
Protools HD/IO into B32, Neve MBP, Burl B2 Bomber.
Post by Deleted on Sept 16, 2015 17:46:31 GMT -6
OTB - empty!
ITB: for the actual project Harrison Mixbus Bus emu, filter and Compressor/Limiters not used, VoS BaxterEQ, very slight use, if at all 1-3 dB GR of Klanghelms MJUCjr. (love this one right now, although it's a bit special, project is TripHop/Electro)
Post by jazznoise on Sept 16, 2015 18:41:56 GMT -6
None at the moment, but I'll probably end up with a little bit of the Tokyo Dawn/VOS Slick EQ and some of VOS' Density MK3 at the end. I don't really like to mix into processors.
Post by popmann on Sept 16, 2015 20:26:26 GMT -6
For the longest, my two buss sat various Mid/Side EQs to remove lows from the side in order to band aid floating point summing....when I retired the external reverbs, I set the RME Totalmix up to sum. Imaging issues solved. No need for two bus processing.
So, at 88.2, I think I have 5 stereo and 4 mono outs to the RME. While the difference is subtle, grand scheme....it finally means I can remove my bandaid. And when you do a null test....it's stuff panned out....funny--because you HEAR it as better center channel clarity--but, the center 100% nulls. It's the stuff panned out that makes up the difference AND results in not mushing into the center.
Lovely. If I can now figure out if there's a way to pass thru Mackie control buttons to Totalmix.....so I can enable the Loopback and mono collapse and such without calling up Totalmix, I'd be super happy.
I do currently have the Avenson in here so I could stick the mid/side analog EQ on there....but, I simply don't feel any need.
Post by jcoutu1 on Sept 16, 2015 20:34:25 GMT -6
Post by ericn on Sept 16, 2015 21:14:00 GMT -6
M/S decoder and M/S Coder lets you convert LR to M/S EQ it then Convert it back.
