Post by cowboycoalminer on Apr 22, 2015 13:11:19 GMT -6
Seems like a cool idea but the choice of converters would still leave a footprint so not really "tape" in and of itself. Any real world experience out there?
Post by jsteiger on Apr 22, 2015 13:13:05 GMT -6
I think joey808 works with a Clasp system.
Post by Ward on Apr 22, 2015 13:19:00 GMT -6
The supposed advantage is to get the sound of tape into Pro Tools, right? So why not just track on your analog 24 and dump it into PT? Then sync up the 24 track to PT and fill up another 23 tracks? Then dump those 23 into PT in sync, and repeat with as many more as you need? - 23 at a time.
Post by yotonic on Apr 22, 2015 13:32:43 GMT -6
You can do that too and manually sync everything up. But Clasp learns your setup and then keeps everything in sync so you can have a truly multiformat system running at the same time.
Post by ericn on Apr 22, 2015 14:01:26 GMT -6
The supposed advantage is to get the sound of tape into Pro Tools, right? So why not just track on your analog 24 and dump it into PT? Then sync up the 24 track to PT and fill up another 23 tracks? Then dump those 23 into PT in sync, and repeat with as many more as you need? - 23 at a time. R Keeping the sync is the hard part!
Post by wiz on Apr 22, 2015 15:50:46 GMT -6
I think basically, everything goes into pro tools via tape , so when recording or over dubbing it gets printed via tape. But everything you are hearing that has been previously tracked, is coming out of the daw.
Knopfler uses it.
Cheers
Post by donr on Apr 22, 2015 18:09:34 GMT -6
I think basically, everything goes into pro tools via tape , so when recording or over dubbing it gets printed via tape. But everything you are hearing that has been previously tracked, is coming out of the daw. Knopfler uses it. Cheers Wiz Seems like a DAW could build into software what a CLASP system does. That would be a cool feature.
Post by mrholmes on Apr 22, 2015 18:38:37 GMT -6
And I thought some Tape sims are that good that something like clasp is no longer needed?? Anyone who still works wit tape can answer this dump question?
Post by ericn on Apr 22, 2015 18:46:00 GMT -6
I think basically, everything goes into pro tools via tape , so when recording or over dubbing it gets printed via tape. But everything you are hearing that has been previously tracked, is coming out of the daw. Knopfler uses it. Cheers Wiz Seems like a DAW could build into software what a CLASP system does. That would be a cool feature. DAW company and analog is pretty much a contradiction my friend! Plus not a lot of money in it thus the cost of CLASP.
Post by donr on Apr 22, 2015 18:50:41 GMT -6
Of course you could record to multitrack tape, then copy over to ProTools or whatever. As long as you could sync, you could do it as many times as you need.
The CLASP lets you work essentially like you would with a DAW, but the tracks were first recorded to the tape recorder, then played and copied into the DAW without the user having to fuss with it. It just happens, and the tracks are lined up and the time gap compensated automatically. It lets you overdub exactly the way you do in a DAW, but with the tape sound included.
Sort of a Jules Verne (Rube Goldberg?) version of a tape sim. : )
Post by cowboycoalminer on Apr 22, 2015 19:38:21 GMT -6
Of course you could record to multitrack tape, then copy over to ProTools or whatever. As long as you could sync, you could do it as many times as you need. The CLASP lets you work essentially like you would with a DAW, but the tracks were first recorded to the tape recorder, then played and copied into the DAW without the user having to fuss with it. It just happens, and the tracks are lined up and the time gap compensated automatically. It lets you overdub exactly the way you do in a DAW, but with the tape sound included. Sort of a Jules Verne (Rube Goldberg?) version of a tape sim. : ) Yes exactly. Which is why I can't see how it can be the full benefit of tape as we do have to go to digital in the end. It would be much like a tape sim. I'm guessing it's better but by how much would be a matter of personal experience I guess. I personally love the sound of tape. It's without a doubt better sonically to me. But after using digital, it's a pain in the ass. Can we ever have it all? I doubt it.
Post by donr on Apr 22, 2015 19:54:05 GMT -6
CLASP is a tape sim that actually uses tape. It all goes digital at some point these days. I can't imagine using a 2" machine to make a whole record with today, unless it was one pass, everybody at once like in the golden age.
Post by wiz on Apr 22, 2015 20:21:55 GMT -6
CLASP is a tape sim that actually uses tape. It all goes digital at some point these days. I can't imagine using a 2" machine to make a whole record with today, unless it was one pass, everybody at once like in the golden age. oh ... how I wish it were so 8) cheers Wiz
Post by ericn on Apr 23, 2015 7:50:18 GMT -6
The best DAW / TAPE sync / clock devices are The Rosendahl Nano sync and The older Arrdsync neither is perfect but both can result in useable results. Everybody thinks its easy because compared to analog digital has no speed issues, but when you realize your trying to make a system with built in drift sync to a clock you want perfect the reality can be pretty messy! Then you add in how few care you see why systems like CLASP cost so much. As much as I love the sound of tape, I hate the work involved and when I realized in the 90s that many tape diehards where switching to digital when AVID. gave them PT rigs, I also realized how often it was BS or people being invested in a system!
Post by ericn on Apr 23, 2015 7:53:40 GMT -6
CLASP is a tape sim that actually uses tape. It all goes digital at some point these days. I can't imagine using a 2" machine to make a whole record with today, unless it was one pass, everybody at once like in the golden age. Don this is why I saved my Ampex 440-8 and 440-1/4 from ending up in a landfill and still want a 2in machine for the very rare times when real musicians that can play together are in the same room ! That or Ill just breakdown and buy a Radar and pretend its tape!
Post by Ward on Apr 23, 2015 7:59:54 GMT -6
The best DAW / TAPE sync / clock devices are The Rosendahl Nano sync and The older Arrdsync neither is perfect but both can result in useable results. Everybody thinks its easy because compared to analog digital has no speed issues, but when you realize your trying to make a system with built in drift sync to a clock you want perfect the reality can be pretty messy! Then you add in how few care you see why systems like CLASP cost so much. As much as I love the sound of tape, I hate the work involved and when I realized in the 90s that many tape diehards where switching to digital when AVID. gave them PT rigs, I also realized how often it was BS or people being invested in a system! One thing we should point out here is that in any sync situation, the tape usually controls the speed of the session and is 'the master'. The SMTPE code off track 24 feeds into the sync and controls the playback speed of the computer. And yes, some advanced synchronizers (in theory) can vary the speed of the multitrack machine's capstan motor to compensate for tape stretch but in reality it works so slowly (compared to the reaction time of the computer) that it is almost useless. For me, the only effective way to use a 24 track and PT together is to track the beds (14 tracks for drums, 2 for bass, 8 for any other essential instruments that benefit from it) on tape and dump the whole thing into PT without time code sync, create the tempo map and do all edits in there and then add the other tracks in Pro Tools and have the best of both worlds. i mean seriously, does anyone want tape noise, hiss, wow and flutter on acoustic instruments such as acoustic guitar, mandolin, fiddle and piano? And vocals? Please. The better the signal you start with, the better the end results. And above all else, in songs (which are sung, after all), the vocal is critical.
Post by Randge on Apr 23, 2015 8:21:14 GMT -6
What you aren't taking into consideration is that tape hiss and wow and flutter create dimension and depth. Crosstalk, too. Sadly, those nuances are rarely needed when all the mix engineer gets to do is slam everything and make everything in your face to please brainwashed clients and a label that only cares about sounding competitive instead of being the leader.
Post by ericn on Apr 23, 2015 8:32:26 GMT -6
The best DAW / TAPE sync / clock devices are The Rosendahl Nano sync and The older Arrdsync neither is perfect but both can result in useable results. Everybody thinks its easy because compared to analog digital has no speed issues, but when you realize your trying to make a system with built in drift sync to a clock you want perfect the reality can be pretty messy! Then you add in how few care you see why systems like CLASP cost so much. As much as I love the sound of tape, I hate the work involved and when I realized in the 90s that many tape diehards where switching to digital when AVID. gave them PT rigs, I also realized how often it was BS or people being invested in a system! One thing we should point out here is that in any sync situation, the tape usually controls the speed of the session and is 'the master'. The SMTPE code off track 24 feeds into the sync and controls the playback speed of the computer. And yes, some advanced synchronizers (in theory) can vary the speed of the multitrack machine's capstan motor to compensate for tape stretch but in reality it works so slowly (compared to the reaction time of the computer) that it is almost useless. For me, the only effective way to use a 24 track and PT together is to track the beds (14 tracks for drums, 2 for bass, 8 for any other essential instruments that benefit from it) on tape and dump the whole thing into PT without time code sync, create the tempo map and do all edits in there and then add the other tracks in Pro Tools and have the best of both worlds. i mean seriously, does anyone want tape noise, hiss, wow and flutter on acoustic instruments such as acoustic guitar, mandolin, fiddle and piano? And vocals? Please. The better the signal you start with, the better the end results. And above all else, in songs (which are sung, after all), the vocal is critical. Ward have you tried the Rosendahl ? I was very surprised In multiple situations.
Post by ericn on Apr 23, 2015 8:33:46 GMT -6
What you aren't taking into consideration is that tape hiss and wow and flutter create dimension and depth. Crosstalk, too. Sadly, those nuances are rarely needed when all the mix engineer gets to do is slam everything and make everything in your face to please brainwashed clients and a label that only cares about sounding competitive instead of being the leader. Often wondered if it was a sycho acustical analog version of Dither?
Post by donr on Apr 23, 2015 8:56:26 GMT -6
What you aren't taking into consideration is that tape hiss and wow and flutter create dimension and depth. Crosstalk, too. Sadly, those nuances are rarely needed when all the mix engineer gets to do is slam everything and make everything in your face to please brainwashed clients and a label that only cares about sounding competitive instead of being the leader. Often wondered if it was a sycho acustical analog version of Dither? Ha. Tape has a sound. Audiophile direct to disk cutter vinyl records sounded different, more immediate. My dad had a couple LP's that were recorded on 35mm mag film, and they sounded pretty awesome from memory. Randy has a point. I'm listening to Rival Son's "Great Western Valkyrie," which Dave Cobb has said was recorded using a CLASP. (At least tracks done at his home studio.) I like the way that record sounds, with the possible exception of too much distortion on the vocal. We're talking about Alison Kraus and Union Station in another thread, there's an article where Mike Shipley talks about recording "Paper Airplane." www.soundonsound.com/sos/jul11/articles/it-0711.htmThat record is all digital, and was mixed using lots of [gasp] plug-ins, and maybe it's a bit too pop sounding for the genre, but the sound is faultless IMO. You can make a good digital record. I still have a pristine Ampex ATR-700 ¼" half track. I haven't turned it on in ten years, but I'm still keeping it.
Post by jimwilliams on Apr 23, 2015 9:21:05 GMT -6
Back in the tape days I would spend hours tweeking the machines, moding EQ networks and amplifiers, fine tuning tape paths, replacing motor and guide bearings with expensive grade 9 aerospace bearings, different lubes, etc.
I got Studer and MCI machines to record at +9 on Scotch 996 while lowering THD from .55% down to .15% at 1k. I would spend hours with the Audio Precision aligning and fine tuning the record/play cards. In the end, when excellent converters were developed, I gave up on analog tape recorders, sold them all off.
I've realized in my older age that I don't like the sound of analog tape. It's dirty, noisy and limits dynamics. THD is ok at 1k hz, if .15% is acceptable, but look at 100 hz or 10k hz and it's really 4% THD. Cymbals break up badly, hi hats don't sound like metal but rather like a sample of timed white noise. Try and record a bell tree, you can't, it won't 'stick'.
Others can recall about Ye Olde Tymes, but tape alignment is a PITA. Losing my top end and seeing it on the ends of q-tips every morning gives me little faith it will all be there by mix time. I do miss the smell.
Nostalgia ain't what it used to be.
Post by donr on Apr 23, 2015 9:30:06 GMT -6
". . . I do miss the smell. Nostalgia ain't what it used to be. Me too! Control rooms in the day had a distinct and pleasing aroma. Studer A800's with tape reels on it smelled nice.
Post by EmRR on Apr 23, 2015 11:13:52 GMT -6
Coffee and 3M! Is there a scented candle replacement?
Post by drbill on Apr 23, 2015 13:10:45 GMT -6
THD is ok at 1k hz, if .15% is acceptable, but look at 100 hz or 10k hz and it's really 4% THD. Others can recall about Ye Olde Tymes, but tape alignment is a PITA. Losing my top end and seeing it on the ends of q-tips every morning gives me little faith it will all be there by mix time. I do miss the smell. I do agree with Jim about these issues. I like tape for some things, but it does have it's shortcomings - just like AD/DA conversions do. So......you learn to use your tools and do the best you can. All the younger guys who never worked with tape as they came up thru the ranks don't really "get" how hard we tried to overcome tapes shortcomings. Really, it was no different than working with a DAW. Both have problems, and both require tricky engineering to make it sound as good as it can. Both medium's have/had crappy engineers, and both have guys engineering who seem to be able to float over either medium's "issues" to produce some stellar MUSIC. Really, at this point we have the best of both worlds. You can use tape AND dig on the same project to achieve even better results. The only issues are that tape machine maintainence and tweeking ala what Jim was talking about is rarer than hens teeth. You just don't see places with full time tape machine specialists on staff anymore.
Post by drbill on Apr 23, 2015 13:11:56 GMT -6
I WANT me some 3M / Coffee candles!!!!!!!!
