Post by joey808 on Apr 23, 2015 13:56:13 GMT -6
I think joey808 works with a Clasp system. Hi Jeff! haven't used it in a quite a while, still no AAX plugin for it, very slow development.
Post by Johnkenn on Apr 23, 2015 16:30:27 GMT -6
Can't remember who it was, but I remember someone complaining about clasp the other day, talking about how it never works blah blah. I have no experience with it though.
Post by joey808 on Apr 23, 2015 16:32:22 GMT -6
yea its a boat anchor.
Post by ericn on Apr 23, 2015 16:47:34 GMT -6
That sucks ! Nothing like a big expensive rack filler!
Post by gouge on Apr 23, 2015 17:48:15 GMT -6
I was tracking through my atr-700 for ages until it stopped making a noise. similar to clasp in concept except I wasn't using any latency delay. there's a vid going around of how to use latency delay when tracking through tape but I didn't spend a lot of time sorting that out.
to get around the latency issue I would take a digital feed and use that for overdubs.
I would have liked to get a higher tape track count to make it more flexible.
Post by jsteiger on Apr 24, 2015 12:04:00 GMT -6
Cobb had/has Clasp. I'm not sure if he uses it or not since he bought the portable Stephens machine.
Post by donr on Apr 24, 2015 12:49:57 GMT -6
Cobb had/has Clasp. I'm not sure if he uses it or not since he bought the portable Stephens machine. I took it to mean Cobb was using the Stephens as the tape machine for the CLASP. How hard would it be for a DAW to record assigned analog input(s) to a buffer, then write the audio into the session offset to a pre determined (by tape head gap) latency? Call it "LATCH" You could do it manually now for complete passes. Punches would be a pain.
Post by gouge on Apr 24, 2015 16:43:06 GMT -6
you use a latency delay plug.
Post by drbill on Apr 24, 2015 21:16:45 GMT -6
you use a latency delay plug. Yup. Brad's had it dialed for years - no clasp. I think Clasp is more elegant, but also a lot more $$$.
