Post by OtisGreying on Sept 22, 2021 3:30:54 GMT -6
I wonder why some top engineers or mid-level for that matter are insistent on not incorporating ANY hardware into their set up.
I’ve incorporated hardware as inserts, and they are relatively static in their settings to where it’s hardly a pain to switch 1-2 knobs per session, if that.
I’ve done many many plug-in to hardware comparisons and come away feeling hardware is definitely worth it to me for my own music sonically and workflow wise.
But putting that aside and assuming you can get very close ITB with a certain set of skills, what is the point of being completely ITB if you’re able to incorporate hardware in an easily recallable fashion that perhaps will get you your sound faster?
Even with UAD you need to lug around SOME dsp boxes to mix so I can’t see it being strictly a travel thing... and btw.. Serbian Ghenea? Guy mixes in the same room everyday, why not have any hardware at all even a static mix bus if it sounds better?
Post by skav on Sept 22, 2021 4:00:32 GMT -6
What hardware do you find it neccessary to use to achieve your best result?
Just curious!
Post by OtisGreying on Sept 22, 2021 4:19:29 GMT -6
What hardware do you find it neccessary to use to achieve your best result? Just curious! Compressors and color devices. 1176 for instance - and I’m talking light settings on it - every time I compare it’s obvious the plug-ins shortcomings. Other compression as well, but the 1176 is the most obvious to me. Other than that - saturation, harmonic distortion built up from transformers/circuits and EQ boosts. Here I use Silver Bullet, Electrodyne and Capi EQs. Analog I find smoother, and hard to make sound bad, especially with boosts. It almost always sounds good. Easy to make this sound bad in the digital world - to me. So natural sounding compression and excitement from harmonic distortion/color (Sb, Elec 511, CAPI EQ) are the big things I lean on analog for as it achieves what I want quickly and without a lot of work. And my 1176s for instance don’t change settings. I just gainstage the insert plug-in and leave as is.
Post by Deleted on Sept 22, 2021 6:20:14 GMT -6
The distortion is unwanted and they think it sounds unnatural because it is when you ab it. There’s no such thing as transparent analog to digital and back again conversion either. You’re always getting a phase shift from the adc at best even if your DACs and ADCs have a similar voicing.
For dynamics processing, the hardware id like to use is very modern, usually expensive, and behaves better than the classics. The classic compressors were very primitive and masked their action in distortion. Ever heard a Daking FET vs an 1176? It’s like that but for everything. Tons of guys would rather have Kotelnikov or a GML 8900 than an 1176 + la2a. There’s going to be tracks where old stuff just doesn’t work. At all. Ever had to edit out breaths from vocals because the “leveler” was pumping? When you’ve worked on records where the drum sound was killed by being tracked through an 1176 or clone on the way in, you wonder what’s the point? Plugins could’ve done a less offensive job almost 20 years ago: Waves Renaissance Compressor, Oxford Dynamics, Blockfish if you wanted to get nasty. Now we have stuff like Molot GE and Drum Leveler.
Look at what the developers of many of the better behaving plugs are rocking gear wise: Crane Song comps, Retro 176, stuff that just sounds money and not like the 70s.
Post by Deleted on Sept 22, 2021 7:29:53 GMT -6
Also recall is huge. Down time hurts mix decisions. Even 30 seconds to a minute or two to unfreeze and freeze again hurts workflow and effects results. Instant recall is a tweaking curse yet not having it is worse with the (lack of) quality of raw tracks today.
Post by mcirish on Sept 22, 2021 9:04:08 GMT -6
I don't think many of the plugins sounds "exactly" like what they are intended to. But, I just look at them as tools and work with them in a way that works best. The results are very good IMHO. Instant recall of a mix session is way more important to me. I switch between projects all the time. I can't imagine wanting to do any manual recalls with outboard gear anymore. While not identical, I find there are plugins that do a fine job at handling dynamic, adding a little saturation or anything else I need. I suppose it all comes down to what you are familiar with and how you like to work. I'm personally glad to be away from consoles, tape machines and racks of outboard gear. A good converter and a couple dozen quality preamps is all I really need to get my mixes done (not including monitors and room correction). Just my take on it.
Post by svart on Sept 22, 2021 9:19:48 GMT -6
Let me tell you why I've gone mostly ITB after decades of mostly OTB or hybrid..
Ease of use. Lets face it, everything is at you fingertips with a keyboard and mouse.
Recall. I can just save versions as I go and if I get backed into a corner, I just open a different version or select an earlier history point.
NOISE. One of the biggest things I always fought was noise. No matter how low the noise floor of your devices, they aggregate and build up. After all the compression and gain I got tired of hearing hiss only 30-40dB down.
Power/heat. The room is cooler, my power bill is slightly less. I used to have to run the AC even in the winter when I had sessions..
Repair. I don't have to maintain and repair gear regularly like I used to.
Costs.. One good plugin that I can use across a bunch of channels costs WAAAAY less than having actual hardware across a bunch of channels.
Space. I had 3 full racks full of gear and another closet full of gear that I would trade in and out depending on what I was doing. Now I select it from a menu.
Sound. I can't tell the difference between the hardware and software anymore and I don't care to A/B for tiny little differences that you can't hear in a mix. I put the plugs on the tracks and do my thing.
Speed. I just reuse my templates and adjust whatever I need to adjust for the next session. I can reroute or change things in seconds instead of minutes or hours.
But I still use some hardware on the inputs, but so far it's patched for the task at hand. Bass will always get a tube pre, EQ and 1176. vocals will always get neve preamp and 1176, etc.
Post by Guitar on Sept 22, 2021 9:34:24 GMT -6
In a nutshell: Recall, render time, speed in general.
Post by drbill on Sept 22, 2021 11:19:17 GMT -6
Recall and Money. That's the only reason. Both good reasons, but neither pointing towards true art.
IME, the DA/AD thing is a non issue. A non starter. I have no issues going out and back in multiple times. Once a signal is digitized for the first time, there is minimal degradation with modern conversion. IMO.
Post by bgrotto on Sept 22, 2021 11:23:36 GMT -6
Yeah, I agree with Bill that the effect of ADDA is being overstated by Dan (sorry, Dan!). It's been years now, but I've done some loopback tests that illustrate just how transparent modern conversion is. Maybe I'll do another one today and share the results...I'm kinda curious now...
Post by Omicron9 on Sept 22, 2021 11:56:23 GMT -6
Let me tell you why I've gone mostly ITB after decades of mostly OTB or hybrid.. Ease of use. Lets face it, everything is at you fingertips with a keyboard and mouse. Recall. I can just save versions as I go and if I get backed into a corner, I just open a different version or select an earlier history point. NOISE. One of the biggest things I always fought was noise. No matter how low the noise floor of your devices, they aggregate and build up. After all the compression and gain I got tired of hearing hiss only 30-40dB down. Power/heat. The room is cooler, my power bill is slightly less. I used to have to run the AC even in the winter when I had sessions.. Repair. I don't have to maintain and repair gear regularly like I used to. Costs.. One good plugin that I can use across a bunch of channels costs WAAAAY less than having actual hardware across a bunch of channels. Space. I had 3 full racks full of gear and another closet full of gear that I would trade in and out depending on what I was doing. Now I select it from a menu. Sound. I can't tell the difference between the hardware and software anymore and I don't care to A/B for tiny little differences that you can't hear in a mix. I put the plugs on the tracks and do my thing. Speed. I just reuse my templates and adjust whatever I need to adjust for the next session. I can reroute or change things in seconds instead of minutes or hours. But I still use some hardware on the inputs, but so far it's patched for the task at hand. Bass will always get a tube pre, EQ and 1176. vocals will always get neve preamp and 1176, etc. Well-said, svart. Side note/mild rant: Noise is a big one. I always feel like the odd man out in this regard. Any time I mention self-noise of gear (mics especially), I just get weird looks of confusion. I've concluded that self-noise in gear doesn't seem to bother most people, or maybe they don't notice it. It's refreshing to know that I'm not alone. Quietly yours, -09
Post by Guitar on Sept 22, 2021 12:01:31 GMT -6
I also hate noise, I'm with you! (sorry about that loud exclamation point)
Post by Omicron9 on Sept 22, 2021 12:17:18 GMT -6
I also hate noise, I'm with you! (sorry about that loud exclamation point) Thanks, monkeyxx. <----said very quietly
Post by bgrotto on Sept 22, 2021 12:31:13 GMT -6
Just tried a quick loopback test, using my humble internally-clocked Avid IOs. The drum loop is a little 4-bar thing from something i was recently working on. The crash cymbal indicates the beginning of each new loop. First loop is no DAAD. Each subsequent loop adds eight roundtrip loopbacks through my converters, up to the final loop which is 48 roundtrips. Listening through the loops serially, I start to notice *what is for me* an appreciable difference at 16 loopbacks. The HF starts to attenuate and get a little crunchy, and by the 48 loopbacks, it's pretty obvious. That said, if you download the file, cut em onto different tracks, and solo between them, you *can* detect a difference even at 8 loopbacks, with the HF attenuating ever so slightly. I can't upload the file directly here, so i put it on Swan; feel free to take a listen and report your thoughts. tinyurl.com/ygqat8qv
Post by drbill on Sept 22, 2021 12:31:39 GMT -6
Noise? I don't' think that is even a reason anymore. Since I haven't had tape machines in the fray, and since I've had pro level gear - noise has been a non issue. I'm using 20-100 pieces of PROPERLY WIRED and GROUNDED and properly GAIN STAGED hardware in a hybrid mix situation and noise has NEVER been an issue. Never.
Post by Deleted on Sept 22, 2021 13:14:05 GMT -6
Noise? I don't' think that is even a reason anymore. Since I haven't had tape machines in the fray, and since I've had pro level gear - noise has been a non issue. I'm using 20-100 pieces of PROPERLY WIRED and GROUNDED and properly GAIN STAGED hardware in a hybrid mix situation and noise has NEVER been an issue. Never. If you deal with guitars and gainstaged wherever drums trying not to clip a deafeningly loud band, noise is more of an issue. Especially if they did not track their record through well-maintained pro (not prosumer!) gear. But the noise issues with that are more the track needs compression and it can’t take that many rounds of it as necessary without bringing up the noise floor than what (analog or digital) you are compressing it with. Especially if you need to use a treble shelf afterwards. I’m constantly notching out tube shit and random fizz spikes when processing distorted guitars.
Post by svart on Sept 22, 2021 13:16:17 GMT -6
Noise? I don't' think that is even a reason anymore. Since I haven't had tape machines in the fray, and since I've had pro level gear - noise has been a non issue. I'm using 20-100 pieces of PROPERLY WIRED and GROUNDED and properly GAIN STAGED hardware in a hybrid mix situation and noise has NEVER been an issue. Never. Well, mathematically, 100 pieces of gear adding no additional noise through gain should increase the noise floor by 20dB by simply adding uncorrelated noise power back to the system.
Post by Deleted on Sept 22, 2021 13:19:19 GMT -6
Noise? I don't' think that is even a reason anymore. Since I haven't had tape machines in the fray, and since I've had pro level gear - noise has been a non issue. I'm using 20-100 pieces of PROPERLY WIRED and GROUNDED and properly GAIN STAGED hardware in a hybrid mix situation and noise has NEVER been an issue. Never. Well, mathematically, 100 pieces of gear adding no additional noise through gain should increase the noise floor by 20dB by simply adding uncorrelated noise power back to the system. Especially when a lot of the cleanest modern compressors only have noisefloors of -90 or so. And old stuff is usually wtf noisy because it’s old.
Post by svart on Sept 22, 2021 13:53:33 GMT -6
Well, mathematically, 100 pieces of gear adding no additional noise through gain should increase the noise floor by 20dB by simply adding uncorrelated noise power back to the system. Especially when a lot of the cleanest modern compressors only have noisefloors of -90 or so. And old stuff is usually wtf noisy because it’s old. One of the biggest reasons people arguing over whether or not their A/DD/A has 120dB or 132dB of SNR/SINAD is complete BS.
Post by Johnkenn on Sept 22, 2021 14:02:26 GMT -6
I agree. For me, I don’t get paid enough to use a bunch of hardware when 95% of people can’t hear the difference. ITB, I don’t get (as) pissed when someone has me doing a third revision to “just bring the eg down 1db… (eyeroll emoji)
Post by mrholmes on Sept 22, 2021 14:11:59 GMT -6
In the end, I was back to ITB for many reasons. But the main reason was the songs which I did ITB were the more creative ones, and the ones which I like more. I don't miss anything, ITB I can sound like I want it - this song 70s alike the next more 80s.... etc. Meanwhile, with the Slate Raven, I LOVE IT. My work gets often interrupted, live is more complicated compared to the 90s.
It's a huge plus for me, and it frees my creative mind. Changes are extremely fast to do.
Suddenly I hated to waste LIVE TIME soldering gear.
One example for outstanding, work in developing plug ins.
The FLA stuff by Ray. Jesus, you need to walk a long way to find hardware sounding sweet like Rays work. You can push it like hardware and things change like with hardware.
The times when software sounded flat and boring are long gone. Every compressor Ray does has a different flavor, one is more open and wide, another one is round and pushes the midrange etc. Ray just knows how to do it. dan is right to mention over and over again the TDR Molot GE a Swiss-Army knife in compression.
It's a story I told myself that hardware is the king. It has a lot to with psychology, I may have had a feeling that psychologist would call: entitled, feeling special with the racks full of gear....??
You asked for big names:
My mentor for example mixes hybrid, but he uses to 90% plug ins. If plugs ruin a song, my mentor would lose customers; - he works for big names. No one complains, and no one ever asked him to go back in time. He mixes with the same 80s attitude, and he is well known for his work.
Post by drsax on Sept 22, 2021 14:59:43 GMT -6
It’s personal and subjective. I love turning knobs, hearing transformers, and tubes, and analog components. I love the tactile feel, and the imperfections. I love how electricity interacts with acoustically captured sound. I just love it. It’s more expensive, imperfect, adds a small amount of noise, and takes time to recall, and just generally takes more time overall. I just love it. Did I mention, I LOVE it And that’s where I’m at. Many others aren’t in that place and it’s all good. Great music can be made either way. So why go fully ITB rather than Hybrid? I wouldn’t completely. Hybrid gives me the best of both worlds IMO. But maybe someday I will. And if I had to record and mix fully ITB, I could. And maybe someday I will. But not today
Post by Omicron9 on Sept 22, 2021 15:13:50 GMT -6
Noise? I don't' think that is even a reason anymore. Since I haven't had tape machines in the fray, and since I've had pro level gear - noise has been a non issue. I'm using 20-100 pieces of PROPERLY WIRED and GROUNDED and properly GAIN STAGED hardware in a hybrid mix situation and noise has NEVER been an issue. Never. Understood. My micro-rant was about things you can't ground or gain-stage your way out of. Like hissy mics or preamps. I've sold mics because they were too noisy. As soon as you bring up that track, you get SSSSSSSSSSSS. Or maybe I could market it as tape hiss and then it would be cool! When you're tracking things like classical solo pieces or chamber music, noisy mics become quite obvious. -09
Post by Blackdawg on Sept 22, 2021 15:36:02 GMT -6
Noise? I don't' think that is even a reason anymore. Since I haven't had tape machines in the fray, and since I've had pro level gear - noise has been a non issue. I'm using 20-100 pieces of PROPERLY WIRED and GROUNDED and properly GAIN STAGED hardware in a hybrid mix situation and noise has NEVER been an issue. Never. Understood. My micro-rant was about things you can't ground or gain-stage your way out of. Like hissy mics or preamps. I've sold mics because they were too noisy. As soon as you bring up that track, you get SSSSSSSSSSSS. Or maybe I could market it as tape hiss and then it would be cool! When you're tracking things like classical solo pieces or chamber music, noisy mics become quite obvious. -09 Why I'm married to denoising software of all kinds. All the time. Never do a recording where it isn't used. (chamber music)
Post by ericn on Sept 22, 2021 15:44:22 GMT -6
For a number of people it’s the perceived value think about it for the price of 2 CAPI 553’s I can get anybody’s API bundle and have 550’s or 560’s plus 225’s and 2500 across the bus. Through in Recall and it’s a no brainer for many.
