Post by christopher on Sept 22, 2021 15:44:27 GMT -6
I’ll add that they are probably always passing it on to a mastering engineer who WILL analog it up. Tape, tubes, inductor EQs etc the mastering guys have the best. And the idea that you lose resolution going out and back in is mostly not an issue because the way digital is.. it’s digits out >to a wav made from digits> back to digits in, it’s already butchered and retains the butchered-ness. but we can add some meat back on before butchering it again at ADC
Post by Deleted on Sept 22, 2021 16:16:17 GMT -6
Yeah, I agree with Bill that the effect of ADDA is being overstated by Dan (sorry, Dan!). It's been years now, but I've done some loopback tests that illustrate just how transparent modern conversion is. Maybe I'll do another one today and share the results...I'm kinda curious now... I don’t know man. The average multichannel converter still messes with the sound too much for me. When I was using all MOTU, man the DA was good yet a little colored but the AD was lofi that could build up. Added warmth and dulled the tracks. It wasn’t painful but wasn’t worth hitting the AD again at all. The RME Firefaces are the opposite with awful treble and dirty power supplies. Why go through it twice? Now I’m on an Apogee Symphony Desktop, which is great but only 2 in 2 out like most good converters. I will upgrade when I get a new computer.
Post by bgrotto on Sept 22, 2021 16:23:02 GMT -6
Yeah, I agree with Bill that the effect of ADDA is being overstated by Dan (sorry, Dan!). It's been years now, but I've done some loopback tests that illustrate just how transparent modern conversion is. Maybe I'll do another one today and share the results...I'm kinda curious now... I don’t know man. The average multichannel converter still messes with the sound too much for me. When I was using all MOTU, man the DA was good yet a little colored but the AD was lofi that could build up. Added warmth and dulled the tracks. It wasn’t painful but wasn’t worth hitting the AD again at all. The RME Firefaces are the opposite with awful treble and dirty power supplies. Why go through it twice? Now I’m on an Apogee Symphony Desktop, which is great but only 2 in 2 out like most good converters. I will upgrade when I get a new computer. I suppose we're all just balancing the deficiencies we hear against the needs we have in a given moment. Not sure if you noticed the loopback test i posted on the first page of this thread, but it reinforces for me the idea that what i gain by using hw far outweighs the hit i take from conversion. But someone (such as you!) could just as easily listen to the same files i shared and come to the opposite conclusion.
Post by drbill on Sept 22, 2021 16:37:07 GMT -6
Noise? I don't' think that is even a reason anymore. Since I haven't had tape machines in the fray, and since I've had pro level gear - noise has been a non issue. I'm using 20-100 pieces of PROPERLY WIRED and GROUNDED and properly GAIN STAGED hardware in a hybrid mix situation and noise has NEVER been an issue. Never. Well, mathematically, 100 pieces of gear adding no additional noise through gain should increase the noise floor by 20dB by simply adding uncorrelated noise power back to the system. Perhaps, but math doesn't get my mixes done. For what it's worth, I'm using my ears to make the judgment. I've worked all kinds of systems from ITB to big consoles to hybrid, and I have zero issues with noise in my current hybrid setup. Definitely quieter than most larger console setups.
Post by drbill on Sept 22, 2021 16:40:37 GMT -6
Noise? I don't' think that is even a reason anymore. Since I haven't had tape machines in the fray, and since I've had pro level gear - noise has been a non issue. I'm using 20-100 pieces of PROPERLY WIRED and GROUNDED and properly GAIN STAGED hardware in a hybrid mix situation and noise has NEVER been an issue. Never. If you deal with guitars and gainstaged wherever drums trying not to clip a deafeningly loud band, noise is more of an issue. Especially if they did not track their record through well-maintained pro (not prosumer!) gear. Sure. Of course. But you're going to have the same noise issues ITB or Hybrid or OTB in those circumstances IME.
Post by drbill on Sept 22, 2021 16:59:23 GMT -6
Noise? I don't' think that is even a reason anymore. Since I haven't had tape machines in the fray, and since I've had pro level gear - noise has been a non issue. I'm using 20-100 pieces of PROPERLY WIRED and GROUNDED and properly GAIN STAGED hardware in a hybrid mix situation and noise has NEVER been an issue. Never. Understood. My micro-rant was about things you can't ground or gain-stage your way out of. Like hissy mics or preamps. I've sold mics because they were too noisy. As soon as you bring up that track, you get SSSSSSSSSSSS. Or maybe I could market it as tape hiss and then it would be cool! When you're tracking things like classical solo pieces or chamber music, noisy mics become quite obvious. -09 Agreed completely - but as I mentioned earlier, this is not an ITB vs. Hybrid noise argument. You'll still have those noise issues ITB. My comments on the Hybrid brings noise with it comments were that for me, those issues are moot if you properly wire your studio and have proper gain staging. Cheers, bp
Post by Deleted on Sept 22, 2021 17:02:43 GMT -6
I agree. For me, I don’t get paid enough to use a bunch of hardware when 95% of people can’t hear the difference. ITB, I don’t get (as) pissed when someone has me doing a third revision to “just bring the eg down 1db… (eyeroll emoji) Dude, right now I’m not even using the new hotness plugs because if I stack em I have to freeze. Big sessions can have 10 gb folders then even at 44.1. The 2 minutes to adjust every track leads to worse decisions. So my most used plugs are Oxford EQ and Oxford Dynamics. Still good 1990s DSP. I was using PSP infinistrip before but I don’t like the dynamics in it. Too dirty and grainy.
Post by Blackdawg on Sept 22, 2021 17:06:38 GMT -6
It’s personal and subjective. I love turning knobs, hearing transformers, and tubes, and analog components. I love the tactile feel, and the imperfections. I love how electricity interacts with acoustically captured sound. I just love it. It’s more expensive, imperfect, adds a small amount of noise, and takes time to recall, and just generally takes more time overall. I just love it. Did I mention, I LOVE it And that’s where I’m at. Many others aren’t in that place and it’s all good. Great music can be made either way. So why go fully ITB rather than Hybrid? I wouldn’t completely. Hybrid gives me the best of both worlds IMO. But maybe someday I will. And if I had to record and mix fully ITB, I could. And maybe someday I will. But not today This is what its about right here for me! I just love doing it. Even on the mixes where i have to work fast and know I'll make tweaks. I still bare minimum use my Silver Bullet. But certainly lean on plugins a lot for some projects.
Post by Blackdawg on Sept 22, 2021 17:08:00 GMT -6
I agree. For me, I don’t get paid enough to use a bunch of hardware when 95% of people can’t hear the difference. ITB, I don’t get (as) pissed when someone has me doing a third revision to “just bring the eg down 1db… (eyeroll emoji) Dude, right now I’m not even using the new hotness plugs because if I stack em I have to freeze. Big sessions can have 10 gb folders then even at 44.1. The 2 minutes to adjust every track leads to worse decisions. So my most used plugs are Oxford EQ and Oxford Dynamics. Still good 1990s DSP. I was using PSP infinistrip before but I don’t like the dynamics in it. Too dirty and grainy. Sounds like you need a better computer. I work in sessions 100Gb-1Tb+ all the time with no issues.
Post by gwlee7 on Sept 22, 2021 17:08:33 GMT -6
I also hate noise, I'm with you! (sorry about that loud exclamation point) Lol. Sorry. Had to do it.
Post by Deleted on Sept 22, 2021 17:12:36 GMT -6
Dude, right now I’m not even using the new hotness plugs because if I stack em I have to freeze. Big sessions can have 10 gb folders then even at 44.1. The 2 minutes to adjust every track leads to worse decisions. So my most used plugs are Oxford EQ and Oxford Dynamics. Still good 1990s DSP. I was using PSP infinistrip before but I don’t like the dynamics in it. Too dirty and grainy. Sounds like you need a better computer. I work in sessions 100Gb-1Tb+ all the time with no issues. The problem is not the size, it’s the freezing. I can’t run Tupe, Satin, and Molot on insane on almost every track without it. I’m going to buy the second gen of ARM Mac chip when it comes out and then a new Windows Laptop when this breaks. computer market sucks now. Now that I have the money for new hardware, both analog and computer, it’s just not smart to buy and I still can’t buy what I wanted to buy early last year due to Covid.
Post by mrholmes on Sept 22, 2021 18:16:55 GMT -6
Yeah, I agree with Bill that the effect of ADDA is being overstated by Dan (sorry, Dan!). It's been years now, but I've done some loopback tests that illustrate just how transparent modern conversion is. Maybe I'll do another one today and share the results...I'm kinda curious now... I don’t know man. The average multichannel converter still messes with the sound too much for me. When I was using all MOTU, man the DA was good yet a little colored but the AD was lofi that could build up. Added warmth and dulled the tracks. It wasn’t painful but wasn’t worth hitting the AD again at all. The RME Firefaces are the opposite with awful treble and dirty power supplies. Why go through it twice? Now I’m on an Apogee Symphony Desktop, which is great but only 2 in 2 out like most good converters. I will upgrade when I get a new computer. I doubt big time that RME uses dirty PSUs. And the new UFX or the 802 just sounds right to me. Clean HF range but not awful at all… But teach me wrong. Show me a measurement video of an 802 dirty PSU. I bet the staff at RME will freak out and would love to join the discussion. I am out guys…
Post by drbill on Sept 22, 2021 18:32:25 GMT -6
I love turning knobs, hearing transformers, and tubes, and analog components. I love the tactile feel, and the imperfections. I love how electricity interacts with acoustically captured sound. I just love it. It’s more expensive, imperfect, adds a small amount of noise, and takes time to recall, and just generally takes more time overall. I just love it. Did I mention, I LOVE it And that’s where I’m at. Many others aren’t in that place and it’s all good. Great music can be made either way. So why go fully ITB rather than Hybrid? I wouldn’t completely. Hybrid gives me the best of both worlds IMO. But maybe someday I will. And if I had to record and mix fully ITB, I could. And maybe someday I will. But not today YES!! So eloquently put Darren!! Agree completely.
Post by seawell on Sept 22, 2021 19:33:29 GMT -6
I have been all ITB for years at a time in the past and have gotten results I was very happy with. Having said that, I have more outboard gear now that I ever have and like others have mentioned, I just enjoy it. I also personally work faster on a hybrid set up.
Post by Tbone81 on Sept 22, 2021 19:38:29 GMT -6
This might be all vanity, but when someone is paying me to work on their music it’s nice when they see the racks of outboard gear in my studio. It looks cool. It has a vibe. And in a weird psychological way it helps justify the expense of them paying me. If I was just tinkering away in an iMac and Apollo Duo (nothing wrong with that btw) there’s more of a “I can do that myself in my bedroom” mentality.
Also, I just enjoy it more.
Post by OtisGreying on Sept 22, 2021 20:06:53 GMT -6
I have been all ITB for years at a time in the past and have gotten results I was very happy with. Having said that, I have more outboard gear now that I ever have and like others have mentioned, I just enjoy it. I also personally work faster on a hybrid set up. This is my thing. The analog gets me the right sound WAY faster than plugins. But everyone’s bar for “the right sound” is different. I’m constantly referencing 70s records, records I know we’re done with great engineers and equipment, as my benchmarks. So that bar may definitely be lower for someone hired to work at a minimum rate. But I do think the great sonics come out of analog gear much faster with less margin for error, IME, so I feel mixes come together much simpler and faster so I can focus on the music. Which is why it puzzles me as to someone in the same room mixing wouldn’t at least incorporate some static mix buss chain if it sounds better? But I guess literally everyone is happy with Serbans skills for example and so there’s no urge to do that sort of thing.
Post by bgrotto on Sept 22, 2021 20:14:51 GMT -6
There are mixers whose talents transcend whatever gear they're using (Brauer, Tchad, Manny, Serban, etc). I.... am not one of them. 🤣 So I use hardware.
Post by ericn on Sept 22, 2021 20:25:46 GMT -6
There are mixers whose talents transcend whatever gear they're using (Brauer, Tchad, Manny, Serban, etc). I.... am not one of them. 🤣 So I use hardware. I love this answer, but I know some Ben Folds and Magnetic Fields fans who would disagree 😎
Post by prene1 on Sept 22, 2021 20:30:23 GMT -6
Hi,
My name is Patrick and I’m addicted to analog equipment.
I once fell into the plug-in trap starting off. Then I got into the acustica audio wormhole ( don’t get me started ). Then I was strung out on protools.
Well I finally was able to get clean and have amassed quite a great rig of analog chains.
I’m not hindered by CPU power. Updates. New OS making my system obsolete.
Now I will say some gear is noisy, some pots are scratchy, and awww man that hiss……
But I love it. I wouldn’t trade it for the world.
That’s my story. Thanks.
Post by yotonic on Sept 22, 2021 20:44:46 GMT -6
Dr. Bill & John nailed it. Time is money. Artists & Producers are in short supply of both.
However, classic analog gear is a good investment. I have some pieces that have appreciated in value enough to buy several Mac computers and a pile of plugins.
Post by chessparov on Sept 22, 2021 20:45:12 GMT -6
It's nice to know it's possible for me to make nice demos, even staying totally ITB in a nice/simple DAW (like Multitrack Studio or Bandlab). And my low end "Hybrid" hardware, are things like a Soyuz Launcher/Scarlett 3 "Air Button"/SP VTB-1 Pre/etc. But... If/when a time comes for anything really "important"... I'd prefer to go to an excellent "Hybrid" Studio, and book time there. Chris P.S. Although a close friend has a nice Apollo/Logic set up, he always runs through an Avalon M5 and Atomic Squeezebox first.
Post by bgrotto on Sept 22, 2021 21:39:52 GMT -6
There are mixers whose talents transcend whatever gear they're using (Brauer, Tchad, Manny, Serban, etc). I.... am not one of them. 🤣 So I use hardware. I love this answer, but I know some Ben Folds and Magnetic Fields fans who would disagree 😎 Aw, shucks. Thanks
Post by OtisGreying on Sept 22, 2021 23:31:04 GMT -6
Dr. Bill & John nailed it. Time is money. Artists & Producers are in short supply of both. However, classic analog gear is a good investment. I have some pieces that have appreciated in value enough to buy several Mac computers and a pile of plugins. It really is if you buy the good stuff. And most of my stuff I’ve purchased in excellent-mint second hand condition. So it’s like 95% of my investment is still there, some may even appreciate, and it gets me better sounds faster! Speed in mixing/production is like #1 for me so that’s the biggest thing. Option fatigue with plug-ins and trial and error phase is huge for me ITB on vocals, and analog makes it so much easier so I dig it.
Post by christopher on Sept 23, 2021 10:04:39 GMT -6
Yeah, I agree with Bill that the effect of ADDA is being overstated by Dan (sorry, Dan!). It's been years now, but I've done some loopback tests that illustrate just how transparent modern conversion is. Maybe I'll do another one today and share the results...I'm kinda curious now... I don’t know man. The average multichannel converter still messes with the sound too much for me. When I was using all MOTU, man the DA was good yet a little colored but the AD was lofi that could build up. Added warmth and dulled the tracks. It wasn’t painful but wasn’t worth hitting the AD again at all. The RME Firefaces are the opposite with awful treble and dirty power supplies. Why go through it twice? Now I’m on an Apogee Symphony Desktop, which is great but only 2 in 2 out like most good converters. I will upgrade when I get a new computer. I don’t have much gear at home, I do have 1x 73EQjr and an old RME fireface, 90s broadcast board, MCI jh110 .. the console VCA compressors was hard to tell whether I was gaining very much for a long time vs plug-ins (after decades of doubt, yes it’s helping final answer ha), but the 73 is different. I’ve experimented beyond any sane point whether it’s worth the effort to run stuff through the 73. Every time I go through it, it’s like it’s reversing a generation loss.. as in it sounds ‘closer’ to source*. The highs have less hash, the lows are tighter and cleaner, the mids are glassy. I have had the experience of printing tracks through it and forgetting to name them. Then months later wondering why those tracks sound so clear, only to find there are two of the same tracks in the project, a quick AB I realized easily what happened. I wish I had more channels. I do always at at least slightly adjust the Eq, really makes the lows silky and worth it. (*the only time I really felt there was generation loss on the 73 was full mix after tape, then 73.. obvious damage…still sounds musically interesting though)
Post by deaconblues on Sept 23, 2021 18:10:56 GMT -6
I love how electricity interacts with acoustically captured sound. For me with hybrid, it's the electricity. I spent a looong time ITB, started adding external gear again and am actually enjoying my new patching and calibration and gain staging rituals. The extra work actually makes me a bit more diligent / driven. Shrug
