Post by Johnkenn on Feb 1, 2021 20:43:04 GMT -6
Had a client tell me a song that averaged about -10LUFS wasn’t loud enough. But I definitely hear distortion when I ram it beyond that. What the hell are people doing to get these songs so loud?
Post by svart on Feb 1, 2021 20:54:36 GMT -6
Had a client tell me a song that averaged about -10LUFS wasn’t loud enough. But I definitely hear distortion when I ram it beyond that. What the hell are people doing to get these songs so loud? Got any way to convert that into real numbers, like dB? I have zero understanding of LUFS and how they equate to dB. Otherwise, it's all about small amounts of limiting at each stage, either through direct limiting or through saturation.
Post by tkaitkai on Feb 1, 2021 21:08:29 GMT -6
A lot of my masters are around -7 LUFS or so. For me, distortion usually means one of two things: 1. Too much low end, or 2. Transients are too loud.
If it's too much low end, EQ + multiband compression usually solves it. Leave the master limiter engaged and play around with the low end until the distortion goes away. If the transients are too loud, clip/limit the kick, snare, drum bus, and stereo bus in series. You can usually do a few dB pretty transparently on each. It adds up.
Other stuff:
- FreeClip from Venn Audio is my favorite clipping plugin hands down - Going past a certain point is probably always going to result in some distortion; I try to shape the distortion in a way that doesn't sound obvious - I like the sound of clipping my Aurora. I can get more transparent level out of it than I can from any plugin
Post by drbill on Feb 1, 2021 21:20:50 GMT -6
For me, distortion usually means one of two things: 1. Too much low end, or 2. Transients are too loud. This ^^^. Especially very low sub information in the signal. Get the Chop Shop plugin, and learn how to use the bump control. You'll get rid of the unusable extreme LF signal while still getting the LF sounding huge on the "bottom end / bass". <thumbsup>
Post by nick8801 on Feb 1, 2021 21:22:18 GMT -6
Cut bass....I’ve noticed that any mix I send to pro mastering engineers who feel like they need to impress me with a stupid loud master, always send it back kinda wimpy down low but loud as ****. I’ve learned to mix a little leaner in the low end. Also, mixing with a limiter on helps. It’s all just balancing it out. Loudness is mostly in the mix anyway.
Post by svart on Feb 1, 2021 21:22:47 GMT -6
One of the mixers I follow usually starts with his mix bus. Ssl buss, some saturation, L1. Each bus like guitars, drums usually getting some saturation and clipping. Snare and kick always getting some clipping and saturation.
Post by the other mark williams on Feb 1, 2021 21:33:09 GMT -6
Johnkenn, is this all ITB? I nearly always achieve higher RMS when going OTB on the 2-bus, and usually not even on purpose. Whether it’s hardware saturation or clipping your converters on the way back in, it just seems like things get louder with less fuss. Having said that, IMO -10LUFS really ought to be loud enough. If people don’t listen to that guy’s record, it won’t be because it was “only” -10LUFS.
Post by Blackdawg on Feb 1, 2021 21:40:03 GMT -6
Yeah -10LUFS is pretty damn loud. It's louder than most streaming services will allow anyways and it'll just get turned down. Unless it's going to CDs which still can demanding -8 or higher even then -10 is plenty loud.
Post by timcampbell on Feb 1, 2021 22:18:58 GMT -6
Well a lot of european mastering houses use this to sqeeze the last bit of loudness out of a source without destroying it.
GYRATEC G21: MAGNETO-DYNAMIC INFUNDIBULUM
I think their US distributor has one he'll loan for demo onefsound.com/
Post by Johnkenn on Feb 1, 2021 22:51:09 GMT -6
A lot of my masters are around -7 LUFS or so. For me, distortion usually means one of two things: 1. Too much low end, or 2. Transients are too loud. If it's too much low end, EQ + multiband compression usually solves it. Leave the master limiter engaged and play around with the low end until the distortion goes away. If the transients are too loud, clip/limit the kick, snare, drum bus, and stereo bus in series. You can usually do a few dB pretty transparently on each. It adds up. Other stuff: - FreeClip from Venn Audio is my favorite clipping plugin hands down - Going past a certain point is probably always going to result in some distortion; I try to shape the distortion in a way that doesn't sound obvious - I like the sound of clipping my Aurora. I can get more transparent level out of it than I can from any plugin Or maybe it’s just too ****ing loud with no dynamics.
Post by Johnkenn on Feb 1, 2021 22:53:28 GMT -6
Yeah -10LUFS is pretty damn loud. It's louder than most streaming services will allow anyways and it'll just get turned down. Unless it's going to CDs which still can demanding -8 or higher even then -10 is plenty loud. That’s what I’m saying - it’s already too loud for streaming
Post by lpedrum on Feb 1, 2021 22:53:31 GMT -6
Am I the only one to find it ironic that music lost the loudness wars only to find that there’s no money to be made from these loud records? I’m thinking of starting a label that releases “mixed but not mastered” recordings and calling it Dynamic Records. Maybe it will start a hip new trend. If you think that’s far fetched remember that in 2021 sea shanties are all the rage.
Post by Bat Lanyard on Feb 1, 2021 23:07:28 GMT -6
I do like the Overstayer SVC for this reason. You can get it to whatever edge you'd like and the EQ is really great, IMHO. Very easy to F it all up though with this unit.
Post by tkaitkai on Feb 2, 2021 0:37:19 GMT -6
A lot of my masters are around -7 LUFS or so. For me, distortion usually means one of two things: 1. Too much low end, or 2. Transients are too loud. If it's too much low end, EQ + multiband compression usually solves it. Leave the master limiter engaged and play around with the low end until the distortion goes away. If the transients are too loud, clip/limit the kick, snare, drum bus, and stereo bus in series. You can usually do a few dB pretty transparently on each. It adds up. Other stuff: - FreeClip from Venn Audio is my favorite clipping plugin hands down - Going past a certain point is probably always going to result in some distortion; I try to shape the distortion in a way that doesn't sound obvious - I like the sound of clipping my Aurora. I can get more transparent level out of it than I can from any plugin Or maybe it’s just too ****ing loud with no dynamics. You're probably right. I'm in the minority here, but I really love super loud/squashed masters. The stuff I reference (American Idiot, for example) is smashed to bits, but still sounds massive. It's a tall order to try and replicate that ITB, but it's what I aim for regardless... the tricks I mentioned above have helped me get closer. At the same time, I see no reason why folk, jazz, or singer-songwriter stuff would ever need to be as loud as a Katy Perry song.
Post by Deleted on Feb 2, 2021 0:59:15 GMT -6
I've gotten louder from quiet mixes but it involved a ton of high pass filtering out low bass, eqing away bass from the limiter, compression, clipping off stray high frequency transients, and then limiting and making the limiter avoid the bass. It's a stupid dance to a fatiguing and wimpy master.
Post by lpedrum on Feb 2, 2021 1:46:38 GMT -6
I've gotten louder from quiet mixes but it involved a ton of high pass filtering out low bass, eqing away bass from the limiter, compression, clipping off stray high frequency transients, and then limiting and making the limiter avoid the bass. It's a stupid dance to a fatiguing and wimpy master. I feel like this is the only discussion we have on RGO that asks “What gear will make my music sound worse?”
Post by Deleted on Feb 2, 2021 2:17:00 GMT -6
I've gotten louder from quiet mixes but it involved a ton of high pass filtering out low bass, eqing away bass from the limiter, compression, clipping off stray high frequency transients, and then limiting and making the limiter avoid the bass. It's a stupid dance to a fatiguing and wimpy master. I feel like this is the only discussion we have on RGO that asks “What gear will make my music sound worse?” Yep. Here’s something that works and hurts the sound but always leads to more loud. Before doing anything, stick a barely moving fast attack fast release, functional compressor (no clicking plugs!) to smash down anything that pokes out. If it uses or emulates tubes with upward compression and lots of nice transformers to dull the signal a bit, all the better. Premptive EQ + Fairchild type plug (UAD, MJUC) is your friend. The Neold V76U73 works splendidly too. As do cleaner hardware VCA and FET comps.
Post by askomiko on Feb 2, 2021 6:17:55 GMT -6
Try out Airwindows NC17.
Post by jcoutu1 on Feb 2, 2021 8:45:05 GMT -6
Had a client tell me a song that averaged about -10LUFS wasn’t loud enough. But I definitely hear distortion when I ram it beyond that. What the hell are people doing to get these songs so loud? Sonnox Oxford Inflator before your limiter.
Post by svart on Feb 2, 2021 9:09:19 GMT -6
Reading a bit about LUFS, apparently the frequency weighted averaging is done over a short time and a long time and integrated together. Apparently you can fool the LUFS measurement by having breaks in your songs every few seconds and it will average lower LUFS than a mix that's dense throughout but it will be louder sounding overall. Also apparently people are using this knowledge to write songs that have a lot of breaks to fool the LUFS systems on the streaming platforms and getting songs that are just a bit louder than their peers. It's kinda funny that folks have already gamed the system designed to keep them from making things louder. Anyway, from what I read the biggest reason for having high LUFS but low apparent loudness is low end below about 40hz. I'd prescribe to the missing fundamental trick (like RBass) to make it seem like there's more bass and then cut the real deep stuff from the mix. Also, tkaitkai , I agree 100%. Louder is better for me as well, but most folks don't understand that getting a great loud mix is MUCH HARDER than getting a good soft mix. It's not anywhere as simple as just compression and limiting the soft mix, which is why so many have a hard time getting good loud mixes.. You have to build the mix to be loud from the ground up. you can't just send a soft and dynamic mix to a mastering engineer and expect a great loud mix either. The hardest mix to do is a solid sounding loud mix.
Post by Johnkenn on Feb 2, 2021 9:15:05 GMT -6
I've gotten louder from quiet mixes but it involved a ton of high pass filtering out low bass, eqing away bass from the limiter, compression, clipping off stray high frequency transients, and then limiting and making the limiter avoid the bass. It's a stupid dance to a fatiguing and wimpy master. When I say distortion, I’m just talking about things just getting “crunchy”...not overt distortion, it’s just not as clean as it should be. I usually hpf with a pretty steep slope around 35-40 Hz.
Post by Tbone81 on Feb 2, 2021 10:20:11 GMT -6
It's not anywhere as simple as just compression and limiting the soft mix, which is why so many have a hard time getting good loud mixes.. You have to build the mix to be loud from the ground up. you can't just send a soft and dynamic mix to a mastering engineer and expect a great loud mix either. The hardest mix to do is a solid sounding loud mix. ^^^ This
Post by Omicron9 on Feb 2, 2021 10:41:28 GMT -6
I love the USE WITH CAUTION warning alert on the front panel. -09
Post by Ward on Feb 2, 2021 10:43:15 GMT -6
I know a guy who can help. He can make your masters REALLY loud without losing all dynamics or introducing/inducing much distortion. But it's what he does.
A lot of people don't get the masters they want because of what they neglect to do in the mixing stage. HPF @ 29-30hz LPF @ 16.1Khz
99.999% of people can't even hear below 40hz or above 12khz anyhow. Why waste all the sonic real estate for your pets?
Post by jcoutu1 on Feb 2, 2021 11:15:13 GMT -6
I know a guy who can help. He can make your masters REALLY loud without losing all dynamics or introducing/inducing much distortion. But it's what he does. A lot of people don't get the masters they want because of what they neglect to do in the mixing stage. HPF @ 29-30hz LPF @ 16.1Khz 99.999% of people can't even hear below 40hz or above 12khz anyhow. Why waste all the sonic real estate for your pets? Most people can't hear the difference between an mp3 or a Wav. Why waste the storage space with wavs? 😂😂
