Post by jacobamerritt on Nov 26, 2020 12:22:14 GMT -6
Any Black Friday deals coming on hardware besides IAA?
Post by jcoutu1 on Nov 26, 2020 12:24:58 GMT -6
Any Black Friday deals coming on hardware besides IAA? Kush, CAPI, Tonelux, and Trident right now.
Post by jacobamerritt on Nov 26, 2020 12:27:13 GMT -6
Kush, CAPI, Tonelux, and Trident right now. Where do you see the Tonelux and Trident deals?
Post by superwack on Nov 26, 2020 12:37:24 GMT -6
Just curious, how can you tell? The bx_consoles sounded too similar in my demos with them so I put them into plugin doctor and it’s a waveshaping function like those In freeclip, kclip, inflator, and true iron. They’re still decent plugs. I just think the THD and TMT are a bit of false advertising and the dynamics are a bit dysfunctional. That’s interesting that it’s just a waveshapper. Didn’t know that about true iron either! Any recommendations for distortion/saturation plugins that actually model the circuits? TMT is a great concept but I don’t know why they “model” channels instead of just randomizing SLIGHTLY like within the component tolerance specified by the original manufacturer like +/- 1% or 2% or whatever value wouldn’t have made you patch around that channel or call the tech to fix it. PA didn’t put any THD in the original console and people went crazy so they added some and I don’t recall them ever claiming it’s accurate to the particular model. They have also always said ALL of the bx_consoles use the same “distortion” obviously the Lindell-80 is a different thing (although I don’t know if it is done differently)
Post by subspace on Nov 26, 2020 12:39:22 GMT -6
Post by jcoutu1 on Nov 26, 2020 12:51:35 GMT -6
Kush, CAPI, Tonelux, and Trident right now. Where do you see the Tonelux and Trident deals? 500 series is 25% off on the PMI Audio website.
Post by jcoutu1 on Nov 26, 2020 12:59:53 GMT -6
Some vendors might do you a favor if you ask, not sure, maybe worth a short message. I emailed. I'm sure Sweetwater would have taken care of me. Not sure about Best Service. We'll see. They refunded the difference for me. Kick ass.
Post by Deleted on Nov 26, 2020 13:38:57 GMT -6
The bx_consoles sounded too similar in my demos with them so I put them into plugin doctor and it’s a waveshaping function like those In freeclip, kclip, inflator, and true iron. They’re still decent plugs. I just think the THD and TMT are a bit of false advertising and the dynamics are a bit dysfunctional. That’s interesting that it’s just a waveshapper. Didn’t know that about true iron either! Any recommendations for distortion/saturation plugins that actually model the circuits? TMT is a great concept but I don’t know why they “model” channels instead of just randomizing SLIGHTLY like within the component tolerance specified by the original manufacturer like +/- 1% or 2% or whatever value wouldn’t have made you patch around that channel or call the tech to fix it. PA didn’t put any THD in the original console and people went crazy so they added some and I don’t recall them ever claiming it’s accurate to the particular model. They have also always said ALL of the bx_consoles use the same “distortion” obviously the Lindell-80 is a different thing (although I don’t know if it is done differently) You have to consider what is good in theory vs good in practice and works in the real world. Also the build up vs the stand out. the stuff that sounds good built up in a mix might not be the stuff to make something stand out that's receding back. The same is true with modeling. Analog modeling sounds nice but lets take an 1176. Sure UAD, DMG, and Slate did a lot more modeling of the real deal than everyone else but their plugs don't work like an 1176 at all. They can't do the same thing. Boxtone, yeah but who cares? They can't get the job done. Otherplugs like Softube FET, Overloud 76 V2, and U-he Presswerk will get the job done all day with phase shift from unreported latency when you enable the lookahead to stop the clicks in the softube and minimum phase oversampling that will mess up a lot of stuff tonally. So you're stuck with PSP Fetpressor, Brainworx Purple MC77, and TDR Molot GE (use insane mode) which don't even try to sound like an 1176 at all and I'm sure they did not attempt to circuit model nearly as much as the hyped up guys. I'm sure Brainworx threw in their tanh(x) somewhere and the only thing Tokyo Dawn modeled only the SSL 4000 channel tolerances for the mid eq (same as slick eq dual mono mode) and Zvukofor's hardware tanh(x) saturatator hahaha. The PSP installer looks like a Windows 98 computer game, it doesn't oversampling, has aliasing, and a soft and weird knee, but use the high pass filter, dig in and offensive transients gone without issues but it's not even close to an 1176. Goodhertz Faraday will work too sometimes and sound cool but it's a lookahead limiter with a lot of nice dirty color. With distortion gear, use what works. I like the Ray Dratwa plugs (Fuse everything, Neold v76, Black Rooster 73, Plugin Alliance Acme Opticom. Blackbox and Phil's Cascade are too pop/edm drum sounding for me to use but are cool as hell), Tokyo Dawn Slick EQ GE output stages, PSP vintage warmer very gently, PSP Infinistrip pre amps (even the 12-bit ADC) used gently, Goodhertz stuff, Klanghelm SDRR 2 in HQ+ mode, U-he Satin on everything, Waves Kramer HLS very lightly on everything gainstaged into (the funnest Waves dirt ime), Waves Kramer Tape on master bus (Waves dirt + tube dirt). I hate every API plugin I've tried and I hate the build up from the Soundtoys stuff but the Soundtoys are great special effects on one or two tracks. They're all one sale now. Decapitator is too pop and the build up kinda sucks. Sonnox Oxford Inflator and Kazrog True Iron are very static but sound good. I wouldn't buy them but they sound good. I now trim and use the VPRE-376 on everything as the first insert if I want some class a push and transistor grit to stuff not tracked through good pres or without uniform pres. Lots of muddy metal stuff that needs some grit and balls when the Neve plugs (there are a bunch of them that will get you in the ball park) wouldn't be appropriate. I'm about to try the Kush stuff now and melt my brain. Silika sounds so cool.
Post by tasteliketape on Nov 26, 2020 14:38:59 GMT -6
Audioscape 150$ off 500 series tonight
Post by Quint on Nov 26, 2020 15:16:12 GMT -6
Audioscape 150$ off 500 series tonight So, does that mean $150 off the V108 price I see on the website now ($599)? In other words, will the sale price be $449 for the V108, or am I already seeing the sale price at $599?
Post by kcatthedog on Nov 26, 2020 15:23:28 GMT -6
That is sale price, in the promo email you can see regular price and sale price.
V3a 899 to 649 V108’s 849 To 599
while supplies last.
Post by boostudio on Nov 26, 2020 19:06:17 GMT -6
Just snagged 2 V108’s .... Woohoo!!!!
Dude ... I have a lot of AS stuff ...
ASAF
Post by the other mark williams on Nov 26, 2020 20:00:21 GMT -6
Some vendors might do you a favor if you ask, not sure, maybe worth a short message. I emailed. I'm sure Sweetwater would have taken care of me. Not sure about Best Service. We'll see. My Sweetwater rep wouldn’t have taken care of me. That guy’s a minor jerk.
Post by m03 on Nov 26, 2020 20:14:28 GMT -6
The newest RME AVB-equipped converters are on sale via the usual suspects. As such, I snagged an M-1610.
That new filter module looks interesting.
Post by ChaseUTB on Nov 26, 2020 20:23:58 GMT -6
Is auto tune on sale anywhere? Lol
Post by gwlee7 on Nov 26, 2020 20:35:13 GMT -6
I emailed. I'm sure Sweetwater would have taken care of me. Not sure about Best Service. We'll see. They refunded the difference for me. Kick ass. That’s good news. I felt bad when I first read what happened bc I shared the link to them. They have always been a pleasure to deal with and this just makes me feel better that they took care of you.
Post by subspace on Nov 26, 2020 21:19:27 GMT -6
Harrison AVA plug-in bundle for $39: Harrison
Post by ericn on Nov 26, 2020 22:13:55 GMT -6
I emailed. I'm sure Sweetwater would have taken care of me. Not sure about Best Service. We'll see. My Sweetwater rep wouldn’t have taken care of me. That guy’s a minor jerk. If you don’t like your rep call SW ask for Jeff Radtke and tell him you want a new rep!
Post by the other mark williams on Nov 26, 2020 23:47:16 GMT -6
My Sweetwater rep wouldn’t have taken care of me. That guy’s a minor jerk. If you don’t like your rep call SW ask for Jeff Radtke and tell him you want a new rep! I’ve asked to switch before, but they seemingly won’t honor the request. They just push me down to one of my guy’s direct underlings, so I’m still dealing with the same guy at the end of the day. No matter. I pretty much solved the problem: I just don’t shop there anymore!
Post by Johnkenn on Nov 26, 2020 23:53:43 GMT -6
If you don’t like your rep call SW ask for Jeff Radtke and tell him you want a new rep! I’ve asked to switch before, but they seemingly won’t honor the request. They just push me down to one of my guy’s direct underlings, so I’m still dealing with the same guy at the end of the day. No matter. I pretty much solved the problem: I just don’t shop there anymore! Mine certainly doesn’t like to give deals. So I really only buy stuff there when I need to put it on 48 months or whatever.
Post by spindrift on Nov 27, 2020 1:28:34 GMT -6
I’ve asked to switch before, but they seemingly won’t honor the request. They just push me down to one of my guy’s direct underlings, so I’m still dealing with the same guy at the end of the day. No matter. I pretty much solved the problem: I just don’t shop there anymore! Mine certainly doesn’t like to give deals. So I really only buy stuff there when I need to put it on 48 months or whatever. My experience and same with VK too...there are enough un-savvy buyers out there to keep these giant operations deep into the black. They aren’t interested in dealing with professionals who have multiple dealer options and can negotiate. Oh well, it’s the buyer’s money.
Post by junior on Nov 27, 2020 2:29:21 GMT -6
Sononym sample management software is 50% off right now. New update, too. www.sononym.net
Post by kcatthedog on Nov 27, 2020 4:21:32 GMT -6
Post by mike on Nov 27, 2020 10:52:42 GMT -6
Years ago I asked to switch sales rep and they reluctantly did,....but as the years went by, the reasons I used to buy at SW that seldom offered deals, was for getting tech support and no sales tax that have now changed to sales tax most places now, and their tech support experience on average has gone noticeably downhill, to the point that I do the same and just don't shop there anymore.
Post by Guitar on Nov 27, 2020 10:55:51 GMT -6
I talked trash (whoops) about my "sales representative" on a thread on the purple forum and sweetwater found my post and changed them for me. It was kind of weird, but it happened. The new one is straight to the point, which is fine with me. I'm not looking for a "relationship" just a decent deal, if and when I am ready to buy something.
