Post by Drew @ UA on Aug 6, 2019 11:17:06 GMT -6
Post by Mister Chase on Aug 6, 2019 11:37:20 GMT -6
Hole. E. Shit.
Post by Drew @ UA on Aug 6, 2019 11:57:40 GMT -6
Wait til you hear it. Or perhaps you have?
Post by kcatthedog on Aug 6, 2019 11:58:50 GMT -6
I saw Drew made a comment on FB today that UA may have changed how console accesses chips for tracking ?
Post by joey808 on Aug 6, 2019 12:01:32 GMT -6
Drew, what are the major updates to console?
Post by Quint on Aug 6, 2019 12:05:04 GMT -6
I saw Drew made a comment on FB today that UA may have changed how console accesses chips for tracking ? I was just reading the article about channel DSP sharing. That is a legitimate upgrade to Console. Great move UA. help.uaudio.com/hc/en-us/articles/360030068452
Post by Drew @ UA on Aug 6, 2019 12:06:04 GMT -6
Two big things....
Channel DSP sharing: the 1 chip per input has been removed.
+12dB on faders in Console: solves the issue many users had about not having enough gain in Mon and Cues to "get up over" a hot track coming out of the DAW.
Post by Quint on Aug 6, 2019 12:06:50 GMT -6
Two big things.... Channel DSP sharing: the 1 chip per input has been removed. +12dB on faders in Console: solves the issue many users had about not having enough gain in Mon and Cues to "get up over" a hot track coming out of the DAW. Drew, does the DSP sharing in any way affect latency?
Post by joey808 on Aug 6, 2019 12:07:21 GMT -6
Two big things.... Channel DSP sharing: the 1 chip per input has been removed. +12dB on faders in Console: solves the issue many users had about not having enough gain in Mon and Cues to "get up over" a hot track coming out of the DAW. Nice!
Post by kcatthedog on Aug 6, 2019 12:09:02 GMT -6
UniversalAudio said: 3 Minutes Ago Quote Originally Posted by DanButsu View Post What's the added latency when this feature is engaged? Channel DSP Pairing Latency * When Channel DSP pairing is active, input latency is slightly increased across all Apollo inputs. The amount of latency increase depends on the Apollo model: * Apollo rack and desktop models (except X Series HEXA models): 69 samples * All Apollo X Series HEXA models: 74 samples * Multi-Unit with HEXA DSP (e.g., Apollo x, when connected in multi-unit configurations, input latency is increased by 74 samples across all connected models. Note: Input latency is only increased when DSP is actually paired. Multi-Quote This Message
Post by Mister Chase on Aug 6, 2019 12:16:04 GMT -6
Haven't even heard it yet. I just know it'll be great.
Post by Drew @ UA on Aug 6, 2019 12:20:19 GMT -6
Two big things.... Channel DSP sharing: the 1 chip per input has been removed. +12dB on faders in Console: solves the issue many users had about not having enough gain in Mon and Cues to "get up over" a hot track coming out of the DAW. Drew, does the DSP sharing in any way affect latency? kcat beat me.
Post by Johnkenn on Aug 6, 2019 12:20:58 GMT -6
Well. Well. Well
Post by Drew @ UA on Aug 6, 2019 12:27:00 GMT -6
Just when you thought you'd seen it all huh John!!?!!
Post by seawell on Aug 6, 2019 12:27:25 GMT -6
Oh boy....The Retro 176 is one of my all time favorites for vocals. Can't wait to try this out!
Post by Johnkenn on Aug 6, 2019 12:33:20 GMT -6
So - if I keep it just set to default, DSP pairing would only occur if I put enough plugs on the input channel to cause it to go into DSP pairing? And the latency isn't affected until it passes that threshold? This will only affect what we hear back from console? The DAW should account for putting it in the right place, correct?
Also - did PT ever fix the IDC issue?
Post by Johnkenn on Aug 6, 2019 12:33:56 GMT -6
Just when you thought you'd seen it all huh John!!?!! When's the HW coming?
Post by Drew @ UA on Aug 6, 2019 12:43:15 GMT -6
So - if I keep it just set to default, DSP pairing would only occur if I put enough plugs on the input channel to cause it to go into DSP pairing? And the latency isn't affected until it passes that threshold? This will only affect what we hear back from console? The DAW should account for putting it in the right place, correct? Also - did PT ever fix the IDC issue? Correct. PT fix was slated for a Fall fix. That's in Avid's court.
Post by Drew @ UA on Aug 6, 2019 12:43:55 GMT -6
Just when you thought you'd seen it all huh John!!?!! When's the HW coming? When enough people want it to make it profitable beyond a one man company.
Post by Drew @ UA on Aug 6, 2019 13:49:59 GMT -6
In addition to the 175/6 and the DSP Pairing already mentioned, Console now has +12dB faders throughout. This is a big improvement when overdubbing and you need to get something up and over a hot track coming out of the DAW.
Post by Quint on Aug 6, 2019 14:19:16 GMT -6
In addition to the 175/6 and the DSP Pairing already mentioned, Console now has +12dB faders throughout. This is a big improvement when overdubbing and you need to get something up and over a hot track coming out of the DAW. This is a pretty great update. The DSP sharing will really open up some possibilities for guitar sim chains with pedals, fx, etc.
Post by Johnkenn on Aug 6, 2019 14:59:51 GMT -6
It’s definitely colored. Just mixed a super sparse/spacey tune and used it on vocals and crushing a loop. Seems like the 175 really shines crushing. Beautiful attack on this.
Post by shoe on Aug 6, 2019 15:23:22 GMT -6
In addition to the 175/6 and the DSP Pairing already mentioned, Console now has +12dB faders throughout. This is a big improvement when overdubbing and you need to get something up and over a hot track coming out of the DAW. This is awesome. I'm always having trouble hearing myself over tracks unless i turn them way down. Of course, I also have a quiet voice and some not very loud outboard preamps that will distort too much if I crank them up high enough to hear better.
Post by Quint on Aug 6, 2019 16:28:17 GMT -6
Drew, does the DSP sharing in any way affect latency? kcat beat me. So since DSP sharing was apparently something that was possible all along with the older Apollos, what were the roadblocks and/or what was the reason that UA just now finally decided to make this a reality?
Post by Drew @ UA on Aug 6, 2019 16:55:40 GMT -6
life.
