Post by notneeson on Sept 30, 2018 9:39:57 GMT -6
Really, the problem I’m having is jumping into a session that has been mixed on another interface and already has Aux's and sends assigned...if you were to go into IO and remove the old bus routing by deleting and defaulting to the new interface, it would completely wipe out all the sends and panning. I’ve found you can just hit default and it adds the new routing in addition to the old, but still has all the old routing when you click on Outputs or busses. Not a huge deal, it would just be nice if you could wipe out the old interface, but the sends and panning remain the way it is... This is my work around - open session and do then “Save as” with the new interface in the name - change your I/O for your new interface - do “import session data” and make it so you import volume and automation, bus assignments, input and output assignments. Everything should then be back to how your old session was, but with the I/O of your new interface. Kind of a weird work around, but it should work and will be the easiest way to deal with your situation. Great tip! I use "import session" a lot. Never thought about trying it for this.
Post by drbill on Sept 30, 2018 11:23:02 GMT -6
Yes, the import function of PT is incredible!!!
