Post by Johnkenn on Feb 17, 2014 12:22:56 GMT -6
Hey Bob - was it you that was talking about a way to record the vocal in front of the monitors and then somehow using phase cancelation to get the bleed out? Or am I making that up?
Post by tonycamphd on Feb 17, 2014 12:51:49 GMT -6
Hey Bob - was it you that was talking about a way to record the vocal in front of the monitors and then somehow using phase cancelation to get the bleed out? Or am I making that up? I think that was me? It's an old trick, take 2 monitors triangulated with the vocal mic, set up a stereo balanced mix, set one speaker 180 out of phase, monitor the vocal mic, use one of ur tracking monitors stereo faders to adjust volume till the mix disappears from the vocal mic.... Or some shit?? It's been about 20 years since I did it, but I'm pretty sure that's right 8)
Post by popmann on Feb 17, 2014 12:54:34 GMT -6
he has. I have.
There's always going to be bleed. There's really no phase stuff I've ever found that particularly helped. But, it's not MUCH bleed...I mean, you don't want do have all kinds of crazy loud stuff you don't want in the mix...but...it's not functionally that much of an issue. The keys (IME):
--One speaker. This is easy with powered monitors--turn one off and hit the mono button. --the mic needs to be a dynamic faced completely AWAY from the speaker...ie with it's BACK to the speaker....or an LDC in Fig8 with the SIDE to the speaker. --I pull bass guitar lower in the mix than I normally would...because, IME, low frequencies are the biggest source of the bleed.
For me...I grew up in studios singing in headphones...IF I have an analog feed, I don't really do much better...but, if it's digital or doing this? All day I'll take the little bleed. Bleed and noise are not the enemy for me. I think Bob likes a little bleed...I tolerate it if it makes a better track. I do all demos with no phones. I can tell my demo tracks from final that way--if I solo them I can hear a little bleed in the background...but, I mean-that's the level we're talking about...you have to solo it.
It's cheap to give it a shot. You know? Do it. Do it. tell us if you can tune it. I never really considered that the bleed might get in the way of that...cause...I own my off key-ness. It's ALL I own. Ha.
Post by Johnkenn on Feb 17, 2014 13:00:46 GMT -6
I was actually just thinking about trying it to see if it was easier to sing that way...so I wouldn't have to tune
Post by popmann on Feb 17, 2014 13:35:44 GMT -6
Yeah...I know...I'm just saying--since the thread is about that...that's something I've never checked.
Post by cowboycoalminer on Feb 17, 2014 14:43:25 GMT -6
The problem is can you fix the pitch without screwing up attitude and timing? If you fix the out of tune stuff in the tracks and have the singer perform it again listening on speakers instead of headphones, you'll often beat the previous vocal by a surprising amount. This is true with even the most experienced professional singers. I did a demo of this at the summer NAMM show a few years back and enjoyed watching the entire room gasp. Is there a link to a video of this or any example of this? I'm very curious about this technique.
Post by jazznoise on Feb 17, 2014 15:56:49 GMT -6
The two points at which you'll struggle to remove bleed is the low end - the sub 250 Hz stuff - and anything around the diaphragm resonance - your usual presence peak between 3 and 7Khz depending on the capsule of the microphone.
Post by matt on Feb 17, 2014 17:27:50 GMT -6
What about judiciously tuning a vocal take or comp, and have the vocalist perform fresh takes while monitoring the tuned "guide" vocal? Anyone ever done this?
Post by Deleted on Feb 17, 2014 23:37:36 GMT -6
Back in tbe days, we experimented and i got lots of good hints from experienced musicians. One was even: Put away the U87 and let the singer sing into a supercardiodid mike like e.g. a 441 (like he was used to do live) And the second: Try tracking without headphones / to monitors or directly live with the band in the full take. Forget about the bleed, you might get a great performance still usable and upgrading the track. Lot's of great live performers have incredibly better tone without headphones, absolutely true, some even need their hands on a microphone or mic stand (a psychological thing) to sing to their full capabilities. Hands down i would try that with great live performers if they somehow seem to be not as good in the studio situation or seem to have pitch/intonation probs. Great, @bob Ohlsson brought this up!
Very good discussion by the way many good points made. Not the average A-Tune bashing. A while ago i tested a vst plug that tries to eliminate bleeding and low second signal problems, i guessed by fft spectral analysis somehow. Forgot it's name, but the concept would be good for tracking like this. Hadn't time to fully test it. Some kind of de-verberate plugin it was...
BR, M.
Post by Bob Olhsson on Feb 18, 2014 0:22:54 GMT -6
I played with out of phase auratones years ago but it wasn't worth the trouble. A better approach is to do one pass with no singing and mix that in out of phase. On the other hand just letting it bleed can sound great. I recorded the lead and two passes of backgrounds for Rare Earth's "I Just Want to Celebrate" using just one handheld Shure SM53 with the mains up pretty loud. It sounded real live and exciting.
Post by keymod on Feb 18, 2014 5:22:25 GMT -6
What about judiciously tuning a vocal take or comp, and have the vocalist perform fresh takes while monitoring the tuned "guide" vocal? Anyone ever done this? I have read of someone using the Antares Hardware unit to tune, " in real time", through the headphones/monitors while the singer was doing the take. The singer then tried to hit the tuned notes they were hearing, and that was the take that was recorded, not what was coming out of the hardware device. Seemed like a great idea to me.
Post by henge on Feb 18, 2014 6:42:45 GMT -6
I played with out of phase auratones years ago but it wasn't worth the trouble. A better approach is to do one pass with no singing and mix that in out of phase. On the other hand just letting it bleed can sound great. I recorded the lead and two passes of backgrounds for Rare Earth's "I Just Want to Celebrate" using just one handheld Shure SM53 with the mains up pretty loud. It sounded real live and exciting. Yes, it did sound exciting.Loooove that track!
Post by Ward on Feb 18, 2014 7:22:54 GMT -6
What about judiciously tuning a vocal take or comp, and have the vocalist perform fresh takes while monitoring the tuned "guide" vocal? Anyone ever done this? I've often used a voice sample or wind sample to play the melody that a singer can sing to, which is effective. I must say, the idea you present is new to me and definitely has great merit to it!
Post by Johnkenn on Feb 18, 2014 7:56:39 GMT -6
Maybe the "Tuned guide vocal" would work with headphones off, I know when I'm doubling harmonies, if the other vocal is too loud when I'm wearing headphones, I will go out of tune like CRAZY. I guess it's because you're brain doesn't know which voice it's hearing back. Most of the time, I'll just mute the first take and just sing the same thing a second time.
Post by donr on Feb 18, 2014 22:40:42 GMT -6
I always sing into a mic with one headphone behind my ear, usually the right. A technique taught me by David Lucas, a NYC jingle guy who co-produced a few of our records. He had another great tip, and that was when singing to "think sharp." If you imagine you're singing just a bit sharp, you generally will be right on in playback. Try it, it works.
Post by tonycamphd on Feb 19, 2014 4:26:14 GMT -6
I played with out of phase auratones years ago but it wasn't worth the trouble. A better approach is to do one pass with no singing and mix that in out of phase. On the other hand just letting it bleed can sound great. I recorded the lead and two passes of backgrounds for Rare Earth's "I Just Want to Celebrate" using just one handheld Shure SM53 with the mains up pretty loud. It sounded real live and exciting. Yes, it did sound exciting.Loooove that track! This track is just awesome!!
Post by Johnkenn on Feb 19, 2014 8:49:47 GMT -6
Thanks, Don! I'll occasionally throw one ear off when I'm not hearing something well, but usually prefer to sing with them both on. BTW - I would say donr knows what he's talking about. He told me it was ok to say this - Don is Buck Dharma - founding member of Blue Oyster Cult! Welcome, Don!
Post by Martin John Butler on Feb 19, 2014 9:25:19 GMT -6
Hey Don, good to see you here. We probably met briefly in the late 70's at some point, I'm a good friend of Andy Shernoff's.
Post by donr on Feb 19, 2014 9:29:52 GMT -6
I run into Andy every once in a while. I'm enjoying this board. I finally found it after wondering wtf happened to John Kenn at GS. I'd PM'ed him because I liked a tune he'd posted during a gear discussion.
Post by Martin John Butler on Feb 19, 2014 9:40:19 GMT -6
Cool, Andy's in Brooklyn now, and he just got engaged !
John's songs are good.
Post by matt on Feb 19, 2014 11:39:13 GMT -6
BTW - I would say donr knows what he's talking about. He told me it was ok to say this - Don is Buck Dharma - founding member of Blue Oyster Cult! Welcome, Don! Just made my day, JK! Welcome Don! Queuing up my BOC playlist on Grooveshark (I know, I know, it's Spotify junior) in celebration.
Post by donr on Feb 20, 2014 0:03:45 GMT -6
Hi all. I'm glad to be here. I'm semi-pro at best as an engineer and mixer, but I've been privileged as an artist to work with and learn from many of the greats in the recording business. And I dig recording and mixing, almost as much as performing.
Post by Johnkenn on Feb 20, 2014 10:01:32 GMT -6
Maybe we can get a question and answer with you sometime, Don...I don't fancy myself a journalist, but would love to hear some stories about your success and I'm sure there are some funny road stories along the way.
Post by cowboycoalminer on Feb 20, 2014 16:17:37 GMT -6
Glad your here, Don. Like to hear war stories myself!
