Post by drew571 on May 4, 2018 21:23:33 GMT -6
So can one assume that the meter is GR only? yes, the description on Stam's website is more detailed and this is the case.
Post by stam on May 5, 2018 6:06:46 GMT -6
Guys
Important question. I am about to order the PCB's for these and wanted to know if you rather have the 2:1 ratio option over the 12:1
The 1176 Anniversary Edition had 2:1, 4:1, 8:1 and 20:1 ratios The 1176 standard ratio is 4:1, 8:1, 12:1 and 20:1 ....
Would 2:1 be more appealing? Thanks
Post by indiehouse on May 5, 2018 6:37:30 GMT -6
Guys Important question. I am about to order the PCB's for these and wanted to know if you rather have the 2:1 ratio option over the 12:1 The 1176 Anniversary Edition had 2:1, 4:1, 8:1 and 20:1 ratios The 1176 standard ratio is 4:1, 8:1, 12:1 and 20:1 .... Would 2:1 be more appealing? Thanks Yes, I find 2:1 more useful. I had a custom Rev A that had the 2:1 instead of the 12:1, and I found it useful. Just my opinion.
Post by mikec on May 5, 2018 6:51:05 GMT -6
My opinion would be to have the 2:1 over the 12:1.
Post by avgatzeblouz on May 5, 2018 7:10:45 GMT -6
I concur. 2, 4, 8, 20, and ALL IN !!
Post by stam on May 5, 2018 8:02:29 GMT -6
Done
Post by drew571 on May 5, 2018 8:13:23 GMT -6
Does the 2:1 ratio have any effect on the all buttons in effect? Does it sound different because it's 2:1 and not 12:1?
Post by Johnkenn on May 5, 2018 8:24:46 GMT -6
Guys Important question. I am about to order the PCB's for these and wanted to know if you rather have the 2:1 ratio option over the 12:1 The 1176 Anniversary Edition had 2:1, 4:1, 8:1 and 20:1 ratios The 1176 standard ratio is 4:1, 8:1, 12:1 and 20:1 .... Would 2:1 be more appealing? Thanks Definitely 2:1 for me.
Post by matt@IAA on May 5, 2018 8:45:05 GMT -6
Does the 2:1 ratio have any effect on the all buttons in effect? Does it sound different because it's 2:1 and not 12:1? It will some, because the all buttons in or multiple buttons is kind of an average. So if you press four and eight you get around six. With 4,8,12,20 all buttons in is kind of 11:1. 2,4,8,20 it would be something like 8.5. But it’s wonky and it doesn’t really work exactly like that, so I’m not sure you’d notice anyway.
Post by ragan on May 5, 2018 8:46:38 GMT -6
Guys Important question. I am about to order the PCB's for these and wanted to know if you rather have the 2:1 ratio option over the 12:1 The 1176 Anniversary Edition had 2:1, 4:1, 8:1 and 20:1 ratios The 1176 standard ratio is 4:1, 8:1, 12:1 and 20:1 .... Would 2:1 be more appealing? Thanks Definitely. I hardly ever use 12:1 but I use the 2:1 on my Hairball all the time.
Post by drew571 on May 5, 2018 9:14:43 GMT -6
Does the 2:1 ratio have any effect on the all buttons in effect? Does it sound different because it's 2:1 and not 12:1? It will some, because the all buttons in or multiple buttons is kind of an average. So if you press four and eight you get around six. With 4,8,12,20 all buttons in is kind of 11:1. 2,4,8,20 it would be something like 8.5. But it’s wonky and it doesn’t really work exactly like that, so I’m not sure you’d notice anyway. I see. Well if i don't notice then I guess I'm in for 2:1, but if I do notice, then 12:1. 😂
Post by ragan on May 5, 2018 9:52:33 GMT -6
Definitely should be traditional 1176 fast/slow orientation.
Post by avgatzeblouz on May 5, 2018 10:04:00 GMT -6
+1 for the traditionnal layout
Post by shoe on May 5, 2018 10:05:05 GMT -6
I am also in for 2:1 ratio and traditional attack and release orientation.
With 2:1 I actually might consider a second one as well...but my wallet....
Post by Johnkenn on May 5, 2018 10:09:20 GMT -6
Also in for the traditional fast/slow
Post by Quint on May 5, 2018 10:32:51 GMT -6
Does the 2:1 ratio have any effect on the all buttons in effect? Does it sound different because it's 2:1 and not 12:1? It will some, because the all buttons in or multiple buttons is kind of an average. So if you press four and eight you get around six. With 4,8,12,20 all buttons in is kind of 11:1. 2,4,8,20 it would be something like 8.5. But it’s wonky and it doesn’t really work exactly like that, so I’m not sure you’d notice anyway. And you could push in the 8:1 and 20:1 to get an "average" of 14:1, which isn't far from 12:1 anyway. So I'm definitely in for the 2:1.
Post by matt@IAA on May 5, 2018 10:35:06 GMT -6
It will some, because the all buttons in or multiple buttons is kind of an average. So if you press four and eight you get around six. With 4,8,12,20 all buttons in is kind of 11:1. 2,4,8,20 it would be something like 8.5. But it’s wonky and it doesn’t really work exactly like that, so I’m not sure you’d notice anyway. And you could push in the 8:1 and 20:1 to get an "average" of 14:1, which isn't far from 12:1 anyway. Or 4 and 20 to get even closer
Post by Quint on May 5, 2018 10:39:01 GMT -6
And you could push in the 8:1 and 20:1 to get an "average" of 14:1, which isn't far from 12:1 anyway. Or 4 and 20 to get even closer Ha, yeah you're right. I was just thinking about the two buttons next to one another. Other than ABI, I've never really messed around much with button combinations other than the occasional two buttons next to one another. But, yes, 4:1 and 20:1 would average to exactly 12:1. One more reason the 2:1 is the better option.
Post by shoe on May 5, 2018 12:02:53 GMT -6
Ordered a second...I have no willpower when it comes to low ratio compressors lol.
Post by lcr on May 5, 2018 14:20:04 GMT -6
In, stoked.
Post by lcr on May 5, 2018 14:21:39 GMT -6
And you could push in the 8:1 and 20:1 to get an "average" of 14:1, which isn't far from 12:1 anyway. Or 4 and 20 to get even closer “I’ve done the math enough to know..”
Post by wiz on May 5, 2018 15:12:08 GMT -6
2:1
Cheers
Post by the other mark williams on May 5, 2018 15:33:55 GMT -6
Shoot. I was hoping to not get this, but the more of you who jump in, I'm feeling the inexorable pull. Like I'm on the event horizon, and all it takes is one final nudge...
Post by Ward on May 5, 2018 18:24:37 GMT -6
That is so freaking cool and L O N G overdue!! Now, how about a switchable La2a/LA3a?
Post by lcr on May 5, 2018 18:26:09 GMT -6
That is so freaking cool and L O N G overdue!! Now, how about a switchable La2a/LA3a? This
