Post by Johnkenn on Dec 19, 2017 10:53:53 GMT -6
Post by donr on Dec 19, 2017 12:28:08 GMT -6
JK, I have no idea how to use that file. My fav L-R settings are about -2dB gain reduction and parallel mix of about 60% Wet/Dry.
Post by Johnkenn on Dec 19, 2017 15:39:05 GMT -6
Just download the file, move it to Library-Application Support-Universal Audio-presets-Manley variable mu folder then it should show up in presets...or just download it, click on "Load" on your Vari-mu plugin and go to your download folder and choose it.
Post by Johnkenn on Dec 19, 2017 15:41:04 GMT -6
Basically turns the left side to Mid and right side to Side...and you can dial in the output to taste - more mid or more side. I usually use the input knobs to knock off about -2db of transients.
Post by Johnkenn on Dec 19, 2017 15:43:04 GMT -6
I used to try and use some of the widener plugs...but could never get happy. When I close my eyes with this thing, it seems to bring the center snare hits more to the front while making the stereo field of the sides wider.
Post by donr on Dec 19, 2017 21:33:39 GMT -6
I used to try and use some of the widener plugs...but could never get happy. When I close my eyes with this thing, it seems to bring the center snare hits more to the front while making the stereo field of the sides wider. Ever try Waves' Vitamin? I also have used Nomad Factory's Cosmos with good results. But I never tried UAD Manley Vari-Mu in M/S. Gotta try it. BTW, the Vari-Mu is often an enhancement to whatever I'm doing on the 2bus, but not always. Gotta set the gain, close your eyes and flick/click the bypass until you don't know if it's on or off. Then listen blind.
Post by Johnkenn on Dec 19, 2017 23:18:17 GMT -6
Totally what I do too. More often than not I choose with the vari mu. But it’s really dependent on the song. I should really do more blind listening.
Post by Martin John Butler on Dec 20, 2017 22:04:24 GMT -6
I thought I had the Vari-Mu, but I have the Massive Passive. Oh well..
Post by Johnkenn on Dec 21, 2017 11:58:28 GMT -6
You should just sell the MP and buy the...oh...right.
Post by Martin John Butler on Jan 11, 2018 22:19:50 GMT -6
I never use the MP anymore, but would enjoy having the option to use the Vari-Mu plug. I sometimes find different compressors work better on different tracks. Believe it or not, of the dozen or so compressor plug-ins I have, the Logic DBX 160 works better than all of them on the 2 bus, including Slate, Waves and UAD!
