Post by mrholmes on Nov 14, 2017 7:29:55 GMT -6
Anyone had this issue too?
Some kind of crazy.
I used the Logic i/O Plug In a million times on mono tracks and it always worked flawless. I use already 3 in a rock pop mix.
Engaging the third one on a mono eguitar track changes the pan postion from hard right to 10° right. Waht is going wrong here?
No more mono support for the I/O plug in?
EDIT:
If I listen in solo mode with the hardware the pan postion stays fine. As soon sole is switched off the positon changes.
Post by stormymondays on Nov 14, 2017 7:47:20 GMT -6
I use the I/O plugin daily and never had that issue. Try to restart Logic first of all, if you haven't done so already.
Is the track mono? Is everything fully mono, including all plugins? Can you post a screenshot? Are you sending more than one track through the same I/O (input or output)?
Post by joseph on Nov 14, 2017 9:03:23 GMT -6
I always restart both Logic and my interface when I have issues with i/o plugin. For me mainly latency values that don't seem right and change upon restart.
Post by stormymondays on Nov 14, 2017 9:18:06 GMT -6
I always restart both Logic and my interface when I have issues with i/o plugin. For me mainly latency values that don't seem right and change upon restart. Please tell me more about your setup. Interface only, ADAT expansion? Which model/brand?
Post by mrholmes on Nov 14, 2017 13:04:34 GMT -6
I always restart both Logic and my interface when I have issues with i/o plugin. For me mainly latency values that don't seem right and change upon restart. Jupp helped... first I only restartet Logic .... thane the whole system inclusive the RMEs .... For a reason I do not know its gone now. I hope it stays this way. THXs
Post by joseph on Nov 14, 2017 13:14:18 GMT -6
I always restart both Logic and my interface when I have issues with i/o plugin. For me mainly latency values that don't seem right and change upon restart. Please tell me more about your setup. Interface only, ADAT expansion? Which model/brand? Apogee Symphony MKI over usb. 8x8x8 card
Post by stormymondays on Nov 14, 2017 15:50:00 GMT -6
Please tell me more about your setup. Interface only, ADAT expansion? Which model/brand? Apogee Symphony MKI over usb. 8x8x8 card Thanks. I'm having a problem with a Focusrite Clarett Octopre (discussed on another thread), where the D/A ping values change randomly, although there is a known "good" value that's the most frequent one. How often does your ping value get weird?
Post by joseph on Nov 14, 2017 17:44:16 GMT -6
I dunno, seems to be if I have a session open for a while for editing and then I start adding i/o plugins.
If I reopen fresh, seems fine. But don't quote me on that.
