Post by Johnkenn on Nov 10, 2017 9:43:43 GMT -6
www.sweetwater.com/store/detail/RAMsys2000
Really nice solution for a lot of us.
Enhanced Mastering-grade Monitoring for Your Studio
Over two years of intensive research and development went into the Heritage Audio Reference Audio Monitoring systems, and it shows. Sharing the same state-of-the-art circuitry and core analog audio path, the three RAM systems deliver audiophile-quality sound and feature sets tailored for project studios, commercial recording facilities, and post-production houses who deliver in 5.1 surround. The middle entry in the series is the RAM System 2000, designed for the studio that needs enhanced, mastering-grade stereo monitoring capabilities.
Feature-packed console-style stereo monitor controller
The System 2000 features generous I/O, with three pairs of +4dBu balanced analog inputs and three stereo outputs, an independent pre-fader MIX OUT, independent stereo CUE I/O, a S/PDIF coax input, and pro-audio-quality Bluetooth input for easy mobile device integration. The 2000's two audiophile-grade diamond-buffer-based headphone amplifiers are capable of driving any headphones without noise or coloration. For easy recall of common settings, two user-assignable preset levels are provided. For communicating with talent, there's a built-in Talkback with console-style management. Lastly, Heritage Audio equipped the RAM System 2000 with an independent Subwoofer output that lets you effortlessly share your sub between different speaker pairs.
Audiophile-quality monitoring for any size studio
All three RAM systems employ state-of-the-art analog circuitry for superior transparency and ultra-low noise and distortion. The units are fitted with 64-step, gold-plated relay ladder attenuation for master level control — a feature usually found only on high-end large-format consoles. They also support Bluetooth connectivity for convenient wireless input from mobile devices. And with its classic RAF-gray cosmetics and prominent red Marconi knob, your RAM system will add a touch of class to your control room. At Sweetwater, we're very excited about Heritage Audio's RAM systems. Whether you record at home or work in a world-class studio, mastering-grade monitoring has never been more accessible.
Heritage Audio RAM System 2000 Features:
Desktop-format monitor controller with classic looks
Designed for the studio that needs enhanced, mastering-grade stereo monitoring capabilities
All functions on high-quality illuminated engraved buttons
64-step relay ladder attenuation for master level control in 1dB steps
3 pairs of +4dBu balanced analog inputs (input 3 is configurable for -10dBu unbalanced signals)
Independent stereo CUE I/O for cue-mix distribution to artists
S/PDIF coax input with Burr-Brown 24-bit/192kHz D/A conversion
Pro-audio-quality Bluetooth input for easy mobile device integration
3 stereo outputs
Independent MIX output (pre-fader; follows Input)
Independent Subwoofer output facilitates sub sharing between different speaker pairs
DIM function; MUTE/SOLO for individual speakers
2 user-assignable preset levels for easy recall of common settings
Built-in Talkback with console-style management, including Talkback to Cue, Talkback to Mix, and Talkback to All
2 high-level, ultra-high-current, audiophile-grade diamond-buffer-based headphone amplifiers, capable of driving any hi- or lo-Z headphones without coloration or noise
Headphone source selectable between mix and cue signals
State-of-the-art analog circuitry for superior transparency and ultra-low noise and distortion
All gold-plated relay-based switching for every function, including inputs and outputs
www.gearslutz.com/board/attachments/aes-2017-new-york-ny-usa-18-21-october-javits-center/700450d1508762157-heritage-audio-r-m-monitor-controllers-heritage-audio-ram-system-2000-top__44494.1508598203.1280.1280.jpg
www.gearslutz.com/board/attachments/aes-2017-new-york-ny-usa-18-21-october-javits-center/700453d1508762258-heritage-audio-r-m-monitor-controllers-heritage-audio-ram-system-5000-remote-top__04664.1508599239.1280.1280.jpg
3 stereo outputs
