Post by Mister Chase on Oct 6, 2017 21:53:47 GMT -6
I know you were not =) We tested 11 transformers, 7 capsules, 5 tubes... it all come down to the best combination. Components are not made the same as they were made 50 years ago, materials have changed, the laminations on transformers are not the same, the mylar, transistors, caps, they only thing that is left are NOS tube, which we use on the 47. The only way to make a mic these days sound the same as the old ones is to find which capsule works with which tube and transformer the best to emulate the same curve, we ended up going with Dany´s D7 capsule, NOS Telefunken EF800 tube and the AMI BV8 output transformer. After month of testing this sounded the best of all configurations, I then rented several original U47´s and tested endless hours. We feel we got 95% there and at a fraction of the price. We might do further research but I am very happy on how this mic sounds, all credit to Olvier and Dany of course Josh Yes. I have encountered the same in pickup building for guitars. The raw ore is different, the processes, regulations etc. You can get close, but you simply cannot duplicate. Looks like you did a very fine job. Those are great components you are using. Dany's capsule is a great quality capsule. Save
Post by kcatthedog on Oct 7, 2017 4:44:12 GMT -6
The stam certainly sounds fine but when I watch tihs again I think there are differences due to the position and the singer is typically singing much more into the stam than the N47
he is mostly singing off the top of the inverted neumann capsule
I don't think this is deliberate just what happened.
my experience with my mk-u47 with the Thiersch blue cap tells me this focus can change sound a lot.
I am intersted to know if the capsule mount height is the same ? Not a big deal just curious to understand elements that could be affecting the sonics.
Post by Vincent R. on Oct 7, 2017 7:01:10 GMT -6
Having done a few shootouts on my channel and in general just for myself on my voice and the voices of others I have found mic position definitely influences the sound. It's less noticeable when you're using differnet mics. A U87, M49, U47, and ELA M251 are different enough that you'll still know pretty quickly which works and which doesn't. Sometimes when things are close you need to just do a couple of takes individually and sing in the sweet spot of each mic.
Post by Martin John Butler on Oct 7, 2017 8:06:12 GMT -6
I've tried a few variations when doing shootouts, and there is no ideal. I had six high end mics lined up next to each other on individual mic stands, and moved over for each one, but stayed exactly the same distance. But just by standing in a slightly different position, the sound in the room changed. I settled on using only four mics because being further to the sides reacted too differently with the room sound.
I've tried two mics right next to each other, and stood back enough that my voice hit them equally, but even that is slightly off axis. Of course, having the same take to compare mics seems like a no-brainer, but I've found I prefer doing separate takes, singing as close to the same way as possible. I keep the mic stand where it was and mark the floor where I stood. Although I lose the chance to hear the exact same part that emphasizes a particular quality of the mic, like handling hard transients, I've found I can tell which sound I prefer best that way.
In the shootout I did at The Barbershop Studios with Jeremy Gillespie in the summer of 2016, I did individual takes with a U 47, M49, U67, C12, Soyuz 0-19 and Blackspade UM-17. Although the levels are a little hotter for the U67, which was technically "not fair" or scientific, it was perfectly obvious the 67 took the gold media and was the better fit for my voice. The U47 took the silver, and the Soyuz 0-19 FET, the bronze.This is why I try to cut anyone putting a shootout together a little slack.
I also like to hear a mic with another instrument, like an acoustic guitar and a slight touch of reverb. I like shootouts to be direct, no EQ, no compression, but honestly, I hate plain flat mic sounds. I've heard $12,000 mics sound mediocre in that context. I do think it's necessary if you plan to post your results, but I also try to include a track with the vocal and a single instrument or a band with the vocal in a mix context.
Post by ragan on Oct 7, 2017 8:06:39 GMT -6
Also being further off the mic would help a lot.
Post by EmRR on Oct 7, 2017 8:31:25 GMT -6
The impossible correct standard would be each mic in it's best position, ignoring all others. Which is individual tests that can't be A/B.
Post by Vincent R. on Oct 7, 2017 11:35:51 GMT -6
I also prefer to hear a mic within the context of a mix. Sometimes the mic that sounds perfect when soloed is too thick to really shine in a mix. It can be funny that way.
Post by Martin John Butler on Oct 7, 2017 16:47:23 GMT -6
I just watched this Sweetwater shootout between vintage Telefunkens. The ELA-251, U47 and C12. They did it the same way as Stam did, and it clearly showed how close they were, you could hear the subtle differences. I thought the 251 was different, the 47 quite close, but a little leaner, and the C12 was practically indistinguishable. The Telefunken copies cost 5-9X what Stams costs, and the Stam holds up just about as well.
U47
Post by stam on Oct 7, 2017 20:14:50 GMT -6
We are using NOS Telefunken EF800 tube. I will repeat the test and invert the mics The point of the test was to portrait how close or not we got the original U47 vibe We were at the studio and could use both takes without being able to tell which was which so I think we are 95% there Thanks for the support guys
Post by stam on Oct 7, 2017 20:16:05 GMT -6
I have to say the Stam SA47 sounds great and at that price really exceptional. I have been emailing you sir!
Post by Martin John Butler on Oct 7, 2017 20:35:11 GMT -6
I'm so glad this is working out so well. It puts something of great quality within reach.
Post by Guitar on Oct 7, 2017 20:39:51 GMT -6
I guess that's the stam thing, innit?
Post by Martin John Butler on Oct 7, 2017 20:42:34 GMT -6
Yes! He overcomes obstacles because he's dedicated to making something really really good. I love that quality in people. Great musicians are like that. They could be the most successful musician on earth, and they're still trying to get it right.
Post by Vincent R. on Oct 8, 2017 11:05:52 GMT -6
I gotta say, between clips of the SA87 and SA47, if there was an SA49 in the same price range I probably would've picked it up.
Post by johneppstein on Oct 8, 2017 12:19:14 GMT -6
I often suggest someone try making one of these videos themselves. Their reviews of shootouts get a lot kinder, quickly It's impossible to do a perfect shootout, that's why I don't like them, generally speaking. However the ones done by people here are generally better than the ones found in the "usual sources". Attention to detail means a lot. Also, here I often find the comments as interesting as the shootouts themselves. This one has piqued my interest.
Post by wiz on Dec 22, 2017 15:56:15 GMT -6
Here is a video with the same singing bit, but drums at the end
Cheers
Post by indiehouse on Jan 3, 2018 15:50:25 GMT -6
Here is a video with the same singing bit, but drums at the end Cheers Wiz Pretty close! Especially considering the price.
Post by ragan on Jan 3, 2018 16:42:14 GMT -6
That is pretty close. Doesn't sound quite as close as the SA-87 did in the shootout or two I heard, but still pretty dang close.
Post by indiehouse on Jan 3, 2018 20:21:32 GMT -6
I think I'd find it more interesting to hear this up against a Flea47. Don't know why. Maybe because it's easy for me to dismiss any differences given the huge price difference between the Telefunken and the Stam. Perhaps I'd be more discerning up against the price of a Flea instead? Maybe.
Post by indiehouse on Jan 7, 2018 8:14:28 GMT -6
Hey stam, the preorder price is 1290, right? It's what it says on your website.
Post by jcoutu1 on Jan 7, 2018 9:32:26 GMT -6
I'm still bitter about not getting my mic in September. What a bummer.
Post by timcampbell on Jan 7, 2018 11:38:03 GMT -6
I posted in the wrong thread.
