Post by c0rtland on Mar 22, 2017 8:30:14 GMT -6
This may just be a case of close enough, use your ears. But let's be honest. This thing we do is an antipobe of technicality and artistry so.
Where the &@#% are the stupid diaphragm faces in common dynamic mics.
57 Sm7 Re20 Nd468 421
You get the picture.
I want a cross section diagram of every mic right next to the frequency chart in the documentation. Would be useful when using multiple mics on a single source. (Clearly)
So far I've found this.
Grill to diaphragm spacing SM57 - 9 mm
Beta 57A - 15 mm
SM7B - 45 mm
Post by jeremygillespie on Mar 22, 2017 22:14:21 GMT -6
57 is right about where the writing is on the front grill. If you line that up with the 2 lobes on a 121 you'll be perfectly in phase.
Post by Johnkenn on Mar 23, 2017 11:53:10 GMT -6
That's what Sound Radix Auto Align is for
