Post by Johnkenn on Mar 20, 2017 20:25:23 GMT -6
As I get in touch with inner (skinnier) John, I find that the more I have to hassle with shit, the less I use it. I don't know how many times I've just said "screw it" on that second mic for recording stereo because I didn't want to deal with jacking around with my cheap stands. Been thinking I might knock it out with one really nice one for LDC's and maybe another arm for an sdc. It would be nice to clear up some floor space.
Anyway, there are only 763 options with triad orbit...could someone tell me what I need for a ldc. I guess I would need a boom. I'd like to be able to quickly attach and detach and be able to turn the mic upside down and around without a hassle.
Post by mdmitch2 on Mar 20, 2017 21:05:53 GMT -6
I bought the "Triad-Orbit T3 Triad Large Articulating Microphone Stand" and the "Triad-Orbit Micro 1 M1 Long Stem Orbital Hanging Mic Adaptor." I bought them from Dale Pro Audio on reverb.com, where they accept offers....
It's a really nice setup, but IME the orbital arm isn't quite strong enough for heavier LDCs... it might droop depending on the angle. I've only experienced this issue with a full size u47 clone.... smaller mics have been fine. Hopefully someone else can chime in... pretty sure there's some other triad orbit users on here.
Post by Martin John Butler on Mar 20, 2017 21:16:38 GMT -6
Those Triad Orbit's are pretty cool. I've wanted one since 2013 AES, but you know, priorities.
Post by m03 on Mar 20, 2017 21:23:17 GMT -6
I have a T3 with the regular single Triad-Orbit boom arm...SE Space reflection filter attached to the upper portion, and we use the boom to support a U87. The stand is very heavy-duty and handles the top-heavy setup without any lean/bowing, and can take a minor push without worrying about it tumbling over. The only complaint I have is that the boom has a little side-to-side play, but it's not a deal-breaker.
IMHO, the best part of the Triad Orbit stuff are the quick-detach fittings/adapters, which are available for purchase individually.
Post by Ward on Mar 21, 2017 6:12:27 GMT -6
I really love their stuff, but don't own any because it is just WAY too expensive! I keep searching for deals on the stuff too. So thanks mdmitch2 I'll check with Dale Audio on Reverb.com!
Post by Johnkenn on Mar 21, 2017 8:00:41 GMT -6
I bought the "Triad-Orbit T3 Triad Large Articulating Microphone Stand" and the "Triad-Orbit Micro 1 M1 Long Stem Orbital Hanging Mic Adaptor." I bought them from Dale Pro Audio on reverb.com, where they accept offers.... It's a really nice setup, but IME the orbital arm isn't quite strong enough for heavier LDCs... it might droop depending on the angle. I've only experienced this issue with a full size u47 clone.... smaller mics have been fine. Hopefully someone else can chime in... pretty sure there's some other triad orbit users on here. Damn...that's a REAL bummer. I thought this was supposed to be their strong suit. I saw them at NAMM and was really impressed. I was thinking about the T2 and the OB Mini...or maybe OB1
Post by mdmitch2 on Mar 21, 2017 10:51:04 GMT -6
I really love their stuff, but don't own any because it is just WAY too expensive! I keep searching for deals on the stuff too. So thanks mdmitch2 I'll check with Dale Audio on Reverb.com! Sure thing -- I made very reasonable offers, and they accepted... like 10% off maybe. Of course that was around the holidays, so they may have been more willing to close the deal.
Post by mdmitch2 on Mar 21, 2017 11:21:47 GMT -6
I bought the "Triad-Orbit T3 Triad Large Articulating Microphone Stand" and the "Triad-Orbit Micro 1 M1 Long Stem Orbital Hanging Mic Adaptor." I bought them from Dale Pro Audio on reverb.com, where they accept offers.... It's a really nice setup, but IME the orbital arm isn't quite strong enough for heavier LDCs... it might droop depending on the angle. I've only experienced this issue with a full size u47 clone.... smaller mics have been fine. Hopefully someone else can chime in... pretty sure there's some other triad orbit users on here. Damn...that's a REAL bummer. I thought this was supposed to be their strong suit. I saw them at NAMM and was really impressed. I was thinking about the T2 and the OB Mini...or maybe OB1 I'll test it again later today, more thoroughly.... just to confirm.
Post by mdmitch2 on Mar 21, 2017 15:23:51 GMT -6
So I tested the ball adapter again with the u47 clone, and it's actually better than I thought. I think my problem before was that I wasn't cranking the knob hard enough. As long as you really crank it down hard, it seems to hold just fine at any position... I wish the little knob was larger and easier to grip... I think that would solve the problem completely.
Post by Johnkenn on Mar 21, 2017 15:49:27 GMT -6
That's the extender orbit thingy too, right? Don't think that comes with it, right?
Post by mdmitch2 on Mar 21, 2017 16:07:05 GMT -6
Post by nobtwiddler on Mar 21, 2017 20:26:06 GMT -6
I've slowly been replacing every stand with the Orbit stuff. Very $$$. At this point I own about 8 stands, and at least 2 or more of everything as far as options that they make... yes really! Spent a small fortune, and I'm far from done. Anyhow, for your needs John, a simple T-2 Stand (unless you need the three tier, and or wheels? Then order a T-3) And one short or long boom. (A short boom would probably work?) Short = Orbit Mini / OM or the Orbit 1 I have many of each! And a Micro-M2 (the short stem) or a Micro M-1 (longer stem) mic adapter will let you position the mic safely at any possible angle you desire. Great thing is I've been using a Orbit T-2 stand with a Orbit -1 boom, and the add a Clamp with a Orbit Mini to record Vocal and guitar takes simultaneously with one stand. Endless possibilities with placement and no fear of a mic or stand falling. As a matter of fact I recently did a session using 1 x T-2 Stand, and 6 x assorted Booms / or Arms attached to it, extending from it using their IO-C Clamps. 1 x stand to record 2 x vocalist, 2 x acoustic guitars, (sitting at 90 degree angle to each other) a stereo room mic, and a live Video camera all mounted from the one stand ! While not perfect, they do offer a lot of options for almost any setup. That being said, I've just placed a order for another $1200 in stands, booms and more adapters. So I guess, I'm a fan! Attachments:
Post by matt on Mar 21, 2017 21:11:55 GMT -6
Post by Johnkenn on Mar 21, 2017 22:00:41 GMT -6
I've slowly been replacing every stand with the Orbit stuff. Very $$$. At this point I own about 8 stands, and at least 2 or more of everything as far as options that they make... yes really! Spent a small fortune, and I'm far from done. Anyhow, for your needs John, a simple T-2 Stand (unless you need the three tier, and or wheels? Then order a T-3) And one short or long boom. (A short boom would probably work?) Short = Orbit Mini / OM or the Orbit 1 I have many of each! And a Micro-M2 (the short stem) or a Micro M-1 (longer stem) mic adapter will let you position the mic safely at any possible angle you desire. Great thing is I've been using a Orbit T-2 stand with a Orbit -1 boom, and the add a Clamp with a Orbit Mini to record Vocal and guitar takes simultaneously with one stand. Endless possibilities with placement and no fear of a mic or stand falling. As a matter of fact I recently did a session using 1 x T-2 Stand, and 6 x assorted Booms / or Arms attached to it, extending from it using their IO-C Clamps. 1 x stand to record 2 x vocalist, 2 x acoustic guitars, (sitting at 90 degree angle to each other) a stereo room mic, and a live Video camera all mounted from the one stand ! While not perfect, they do offer a lot of options for almost any setup. That being said, I've just placed a order for another $1200 in stands, booms and more adapters. So I guess, I'm a fan! Really think I could get away with the T2 and the Orbit Mini
