Post by brucerothwell on Jan 13, 2017 16:28:34 GMT -6
I have a Sonic Studio 302, which is a Sonic Studio-branded Metric Halo ULN-2.
It also has the 2D + DSP card, and along with all the embedded Metric Halo plugins in the firmware, it also offers the acclaimed Sonic Studio Mastering EQ.
I am interested in taking full advantage of the 302 for mastering & mixing, and would appreciate hearing any advice on others use the same gear (including any of the Metric Halo gear).
Thanks, Bruce
Post by ChaseUTB on Jan 14, 2017 4:29:52 GMT -6
Channel strip and character ( to taste on a parallel for a master ) are going to good uses as well as the multiband dynamics plug ( has limiter on output )
Channel strip 3 also has the freq. analyzer and also has a limiter; don't know if it's brickwall. I haven't tested it thoroughly. One of the listed features of the plug says "now can be used as an all in one mastering plugin due to the added limiter". Also the ChStrip3 comp has a couple different modes/ color....
The mio console offers 80 bit summing, however I assume that's routing audio from daw to mio console. I have not used the Mio or SS version, however researched the whole system pretty thoroughly ( chose apollo instead ) as well use the MH native plugs.
