Post by drbill on Jan 8, 2017 23:06:53 GMT -6
As someone making their own cables, which are installed in a fixed installation - the Neutrik's are SOOOOO much easier to deal with. On a variety if assembly fronts.
Post by EmRR on Jan 8, 2017 23:27:29 GMT -6
Having built a bunch of both, I prefer the Switchcraft. I don't find them any harder to assemble. I've had problems with the Neutrik pressure grip on some fatter wire types. I like the build of the Neutrik TRS/TS better, but they are harder to solder up, AND they don't always play well with Switchcraft hi-Z instrument outputs.
Post by Ward on Jan 9, 2017 8:03:48 GMT -6
Having built a bunch of both, I prefer the Switchcraft. I don't find them any harder to assemble. I've had problems with the Neutrik pressure grip on some fatter wire types. I like the build of the Neutrik TRS/TS better, but they are harder to solder up, AND they don't always play well with Switchcraft hi-Z instrument outputs. And that's really good point. Ease of soldering should be a consideration, as should the quality of a solder joint you can make and depend on. I've melted a few Neutrik's trying to get the solder points hot enough to tin!
