Post by Deleted on Dec 28, 2016 20:36:35 GMT -6
This will be the last of my inane threads, but would like some feedback. I whipped out a session that was done by a decent mix engineer a while back ago, I use it to test out limiters etc.
I put on UAD's Ampex ATR-102 and it didn't half mess with the stereo field, I spent about 2 hours taking it on / off and messing around with settings / input gain etc. if I can be bothered I might run a spectral analyser on it. But suffice to say I'll not be using it.
What about Slate VTM? Any funky behaviour going on there? Also anyone tried out UAD's 2500?
Finally after all the hype of VCC when I remember it coming out, is it still the go to channel preset?
Post by mrholmes on Dec 28, 2016 21:23:33 GMT -6
Slate VTM sometimes works and sometimes is NG. To me VTM sounds best when the VU needle moves very subtle, sometimes it just what it needs to get a diffrent vibe, a more 3 D image.
Post by popmann on Dec 28, 2016 22:02:54 GMT -6
I own and use both....but, I use VCC's busses on most any mix (and various ones on different subs)....I rarely use VTM. It's a specific thing--it's 456 does a nice job of making dirty guitar "whole again" after notching a bunch of stuff unnaturally.
As to the channels....I do use VCC some--but mostly on client work where they used some cheap ADA and/or mic preamp--it sorta smears that "Mackie residue" off the track....on my own stuff, I don't use it much. But, I've got nice mics and preamps and ADA....I'm a little more meticulous than most during tracking, maybe.
Post by popmann on Dec 28, 2016 22:05:06 GMT -6
I see you said "mastering"....with a tape sim? No thanks. But, in 1990 I was the one in the studio who didn't bother hooking up the 1/4" for mixdown. 48khz DAT sounded MUCH more like the board output to my ear.
Post by Deleted on Dec 28, 2016 22:27:06 GMT -6
I see you said "mastering"....with a tape sim? No thanks. But, in 1990 I was the one in the studio who didn't bother hooking up the 1/4" for mixdown. 48khz DAT sounded MUCH more like the board output to my ear. After 15 years I should know better, but I do get caught up in the hype .. I've seriously reduced over the years, but I wouldn't say anythings particularily "low-end" as such. At the moment I'm using Daking Pre's / for Vox / Bass I had a UA 1176 which I sold and got a WA76's which I sold then got a WA2A . Mic's are generally Mojave Fet's or I reach for the SM7B if I'm going all out "METALLL" (57 / MD421 for cabs (standard really)) and AD / DA is an MOTU 1248 which from ample research in theory at least shouldn't be too far away from the apogee symphony I got rid of.. So with that said, seems a case of don't bother.. Which is mighty cool, less is more as they say. Thanks for the advice, always appreciated.
Post by popmann on Dec 29, 2016 15:32:45 GMT -6
Cut at nominal levels....double sampel rate....you won't be able to tell the difference in most any line level ADA. It will be subtle at best. The difference comes when you cut too hot and at 44.1....the the Symphony will walk all over the run of the mill boxes.
Post by ChaseUTB on Dec 29, 2016 20:32:31 GMT -6
I didn't come from tape so I can't help, I can tell you VCC was 2.0 ( improved ) recently and people are loving it. I don't use Slate stuff aside from Monster and looking forward to his distressor.
The UAD 2500 is been calling my name, however I'm doing just fine with my waves API SW.... ($49) 😠I like tape style distortion on 808s and synth basses, other than that sorry I can't be more help! Softube new Chandler UAD plugs are getting amazing reviews as well.
I'm trying to figure two plugs to get myself. May upgrade my rob papen bundle, may go for a mastering app, may grab sonnox V2 limiter from UAD. Maybe a Valhalla plate verb idk haha I'm lost 🤣ðŸ˜
I like Tokyo dawn labs Kotelnikov for mix bus compression. Can do peak and rms and have full varivale control between the two, or one or the other. Has a delta feature which lets you hear what you are compressing which can help you learn to hear compression on different sound sources. Oh ya they have a full featured free version. The plug also has a $50 maxed out super featured version! Limiter no6 by vlad g, is a great rms comp, clipper, brickwall limiter and ISP limiter, 4 modules in one and its free! It's about to be t " 2.0'd" soon too!
Post by Guitar on Dec 30, 2016 8:41:24 GMT -6
The UA tape sims are the only ones I like and own. The U-He Satin is also very good. Slate and Waves, etc. didn't do anything for me. I use them on about 40% of my mixes, just when it feels right. I will sometimes lately use Oxide on the master buss instead of Ampex.
Compression I would use on maybe 20% of my mixes, depending on the material. A lot of good ones have been mentioned here but also take a look at the Cytomic Glue it's like an SSL with extra features.
Channel compression is more and more just LA2As and 1176 from UAD for me, sometimes MJUC or the Fairchild. Sometimes SSL Channel Strip on everything, I like the dbx compressors also for channels. I'm sure the Slate stuff would work equally well in this manner.
Post by Deleted on Dec 30, 2016 10:55:44 GMT -6
The UA tape sims are the only ones I like and own. The U-He Satin is also very good. Slate and Waves, etc. didn't do anything for me. I use them on about 40% of my mixes, just when it feels right. I will sometimes lately use Oxide on the master buss instead of Ampex. Compression I would use on maybe 20% of my mixes, depending on the material. A lot of good ones have been mentioned here but also take a look at the Cytomic Glue it's like an SSL with extra features. Channel compression is more and more just LA2As and 1176 from UAD for me, sometimes MJUC or the Fairchild. Sometimes SSL Channel Strip on everything, I like the dbx compressors also for channels. I'm sure the Slate stuff would work equally well in this manner. Yeah I tend to only use the LA2A's and 1176's, I use outboard for tracking and only use them for touch up's.. I love UAD's Cooper Time Cube, as said the Ampex doesn't half mess with sound field (not in a good way). As popmann says, probably less is more.
Post by Johnkenn on Dec 30, 2016 11:07:45 GMT -6
I will occasionally use the UA Ampeg on the master. I'll often start with the .5 inch 15ips linear preset and then set the input and output and maybe pull up the treble bias. But then I will close my eyes and click on the bypass a bunch to where I can't tell which is which (level matched)...sometimes there's a nice sheen and punch and sometimes not. If it's not adding anything, I take it off. The Slate VTM starts out so bass heavy that it feels like a gimmick to me. Once I take that away, I can't hear it really doing anything.
Post by donr on Dec 30, 2016 11:55:49 GMT -6
I will occasionally use the UA Ampeg on the master. I'll often start with the .5 inch 15ips linear preset and then set the input and output and maybe pull up the treble bias. But then I will close my eyes and click on the bypass a bunch to where I can't tell which is which (level matched)...sometimes there's a nice sheen and punch and sometimes not. If it's not adding anything, I take it off. The Slate VTM starts out so bass heavy that it feels like a gimmick to me. Once I take that away, I can't hear it really doing anything. I like the VTM over the UA Ampex most the time. But I back the bass and the noise down in the hidden settings and run the input 'way lower than any real tape machine. Then I do what you do, clicking with your eyes closed after level matching to get a fair comparison. I'll post a production I just did where I used it like that.
Post by Johnkenn on Dec 30, 2016 12:30:10 GMT -6
The GS thing to do would be to say, "you're wrong, Don!"
Post by donr on Dec 30, 2016 12:44:21 GMT -6
I don't know jack on GS.
Post by Deleted on Dec 30, 2016 13:08:18 GMT -6
Well we have to thank @johnkenn for setting this place up then ..
Post by illacov on Jan 3, 2017 17:23:35 GMT -6
Normally what I do is turn down the volume on my system a bunch and drive the mix or the master into the input until I hear it start to get hairy. It's alot easier to hear this at lower volume than full volume. The trick is to get your instruments and vocals, drums where you want them without it getting too hairy. Of unless you dig that sort of thing.
But you can get some serious depth and punch this. Preamp choice makes a huge difference too.
Oh wait for plugins?
Oops.
Thanks -L.
Post by Deleted on Jan 3, 2017 18:36:35 GMT -6
Preamp choice makes a huge difference too. Since you work for Handsome Audio you might be able to explain why? Is there a scientific test now in place that proves without a shadow of a doubt they do? Because I was under the impression that unless the pre-amp is rubbish it doesn't make a "huge" amount of difference. The pre-amps in the back of my MOTU have a dynamic range of 118dB with a THD+N of -110dB, if you look at something like an Art Pro studio pre-amp then it's dynamic range is <100dB but still with a THD of <0.1%. Yes, in terms of getting signals to the AD stage the MOTU wins. But in the slightly upper end we're talking slight variations of distortion to give it a subtle "pleasing" colour right? I only bought Daking Pre-amps for the amount of gain (to drive an SM7) / slight bit of driveable mojo. Everything I've read so far shows that at a certain point (which isn't THAT expensive), it doesn't matter that much. Some reading www.soundonsound.com/reviews/pick-preampI understand and don't really question that mic's have quite a large impact and it's scientifically proven your room can, but pre-amps have always tickled me. There's Many, Many, Many more papers on it, thoughts / theories etc. Hey, this thread has run it's course, so might as well discuss something semi-interesting right? Or maybe start a new thread?
Post by mrholmes on Jan 3, 2017 20:15:57 GMT -6
The Slate VTM starts out so bass heavy that it feels like a gimmick to me. Once I take that away, I can't hear it really doing anything. The good thing about the Slate VTM you can do something about it in the settings dialog.
Post by illacov on Jan 3, 2017 20:31:11 GMT -6
Preamp choice makes a huge difference too. Since you work for Handsome Audio you might be able to explain why? Is there a scientific test now in place that proves without a shadow of a doubt they do? Because I was under the impression that unless the pre-amp is rubbish it doesn't make a "huge" amount of difference. The pre-amps in the back of my MOTU have a dynamic range of 118dB with a THD+N of -110dB, if you look at something like an Art Pro studio pre-amp then it's dynamic range is <100dB but still with a THD of <0.1%. Yes, in terms of getting signals to the AD stage the MOTU wins. But in the slightly upper end we're talking slight variations of distortion to give it a subtle "pleasing" colour right? I only bought Daking Pre-amps for the amount of gain (to drive an SM7) / slight bit of driveable mojo. Everything I've read so far shows that at a certain point (which isn't THAT expensive), it doesn't matter that much. Some reading www.soundonsound.com/reviews/pick-preampI understand and don't really question that mic's have quite a large impact and it's scientifically proven your room can, but pre-amps have always tickled me. Â There's Many, Many, Many more papers on it, thoughts / theories etc. Hey, this thread has run it's course, so might as well discuss something semi-interesting right? Or maybe start a new thread? I meant in regard to driving my tape emulator. But let's take this back to your topic. If you can attenuate the output of your preamp either with an output knob or an attenuate them you can in theory run your ITB mix into those Dakings and intentionally saturate them via a hardware insert. Then you could feed that signal into which tape simulator plugin or buds compressor plugin etc to gain that extra bit. I find that letting analog do the heavy lifting is a far better way to go every time. Preamps do make a huge difference outside the nominal operating range. I know a guy who dimes his transformer Mic preamps on purpose and plays into the distortion artistically. Preamps used this way are going to all sound different. Even non vintage units. When using them in a nominal way the differences do become more subtle. But like I'm referencing, the differences are huge. Thanks -L.
Post by Deleted on Jan 3, 2017 20:35:10 GMT -6
I meant in regard to driving my tape emulator. But let's take this back to your topic. If you can attenuate the output of your preamp either with an output knob or an attenuate them you can in theory run your ITB mix into those Dakings and intentionally saturate them via a hardware insert. Then you could feed that signal into which tape simulator plugin or buds compressor plugin etc to gain that extra bit. I find that letting analog do the heavy lifting is a far better way to go every time. Preamps do make a huge difference outside the nominal operating range. I know a guy who dimes his transformer Mic preamps on purpose and plays into the distortion artistically. Preamps used this way are going to all sound different. Even non vintage units. When using them in a nominal way the differences do become more subtle. But like I'm referencing, the differences are huge. Thanks -L. Oh yeah, sorry thought you was just talking about nominal / cleans.. Yup, some good transformer based distortion / saturation sounds more pleasent than clean.. There's a drive knob (no inuendo intented) on the dakings, so you can actually drive distortion at relatively low levels.. It's mighty cool. Plus a bit of outboard compression goes a long way.. Every tried riding a fader whilst singing ? Not as easy as it looks .. I did think about getting an OTB compressor for mastering, like an API 2500D and a TC brickwall.. I think Ward was right in the other thread, I am just lieing to myself ..
