Post by jjinvegas on Dec 27, 2016 6:23:39 GMT -6
I was out and drove by this auction, and I just gotta stop. Mostly housewares, but in a dusty pile was a bunch of drums. Nobody seemed to even notice them, when they came up it started at 200 bucks, then 100., nobody reacted. I raised my hand and said 35, and that was it. A practically new set of Mapex, with a few hardware pieces, and a combination Tama set with this Star Classic kick drum with Aquarian head and sealed front. Gee, street price on a Star Classic kick, somewhere North of 1000 bucks. After de-griminig and dusting, I had to try it out. Rest of tthe set was pretty cool also, pinstripes and mounts via the rim, huge upgrade to my little set. Thing sounds killer in the room, but getting that to come out of the speakers was not so easy. I suppose I will eventually mount some kind of mic inside, but on this thing I used a dynamic and a Rode NT2 on the front, and then fired a cross-stick sample off the dynamic and printed it. Then used that to key a gate on the condenser and also the room mic, which I multed. The sound of that kick influenced the rest of what I did, as well as some other things I have picked up in the last ten days for peanuts, couple of guitars, and a pair of Yamaha NS-4636 (2 bucks at Goodwill!!!) and a Presonus Dual Path mic pre-amp for 50. That Presonus is pretty nifty for guitars and bass, small, basically a tube direct box, the mic pres are not stellar but I don't mind as it cost 20 per cent of street retail. The main point being that switching things up and getting out of your comfort zone can get you re-engaged and reacting to different sounds impacts your art, hopefully in a good way......here is what I came out with....... clyp.it/gzmtjmzn
Post by Ward on Dec 27, 2016 6:58:31 GMT -6
Well, how would I handle that? (setting aside your good fortune and the Ferengi laws of acquisition)
I get a spare front head and cut a hole in it.
Post by jjinvegas on Dec 27, 2016 7:02:22 GMT -6
I wonder if you would do that after you heard it. It is so classic sounding, not exactly speed metal material, but so warm and thunky.....
Post by timcampbell on Dec 27, 2016 7:16:25 GMT -6
I would put an SM57 near the beater 180 degrees out of phase to capture click and a decent bass drum mic out in front and blend them to suit the song.
Post by rowmat on Dec 27, 2016 7:27:59 GMT -6
Kick drum without a hole? - It worked for John Bonham!
Post by jjinvegas on Dec 27, 2016 8:08:12 GMT -6
I would put an SM57 near the beater 180 degrees out of phase to capture click and a decent bass drum mic out in front and blend them to suit the song. I didn't have a mic stand that would work in that spot when I cut the track, but I have used that method when I encountered this before. But now that we are not linear-locked I think every DAW should just eliminate the polarity switch entirely. If phase cancellation is present, rarely, if ever is polarity reversal the best remedy. Just put the wave forms next to each other and nudge the channel with the microphone most distant from the source until the waveforms hit peak voltage at the same time. Once you figure this out, another lightbulb goes off, what if something sounds more pleasing and complex with some degree of cancellation? Think about the most amazing bass cabinet of all time, the SVT 8-ten inch comb filter factory. Now you know why i don't sleep much at night....smile...
Post by jimwilliams on Dec 27, 2016 10:09:58 GMT -6
Most jazz drummers don't have a hole, that's part of that sound, it ain't rock & roll. I use an RE-20 next to the kick pedal pointing at the rear head, that's the head the drummer hears and tunes to. The RE-20 is excellent for that as it has no proximity effect.
I didn't see a hole or a missing front kick drum head until the 1970's.
Post by kevinnyc on Dec 27, 2016 10:11:31 GMT -6
I would put an SM57 near the beater 180 degrees out of phase to capture click and a decent bass drum mic out in front and blend them to suit the song. I didn't have a mic stand that would work in that spot when I cut the track, but I have used that method when I encountered this before. But now that we are not linear-locked I think every DAW should just eliminate the polarity switch entirely. If phase cancellation is present, rarely, if ever is polarity reversal the best remedy. Just put the wave forms next to each other and nudge the channel with the microphone most distant from the source until the waveforms hit peak voltage at the same time. Once you figure this out, another lightbulb goes off, what if something sounds more pleasing and complex with some degree of cancellation? Think about the most amazing bass cabinet of all time, the SVT 8-ten inch comb filter factory. Now you know why i don't sleep much at night....smile... You've got the affliction bad, I see...
Post by jazznoise on Dec 27, 2016 10:31:43 GMT -6
Up until our last record we never had access to a kit with a port in the front head. I mic'd the front side and the beater side and sum'd them, worked fine.
If you're cutting a hole, just keep it as small as is manageable and off centre
Post by johneppstein on Dec 27, 2016 22:40:43 GMT -6
I was out and drove by this auction, and I just gotta stop. Mostly housewares, but in a dusty pile was a bunch of drums. Nobody seemed to even notice them, when they came up it started at 200 bucks, then 100., nobody reacted. I raised my hand and said 35, and that was it. A practically new set of Mapex, with a few hardware pieces, and a combination Tama set with this Star Classic kick drum with Aquarian head and sealed front. Gee, street price on a Star Classic kick, somewhere North of 1000 bucks. After de-griminig and dusting, I had to try it out. Rest of tthe set was pretty cool also, pinstripes and mounts via the rim, huge upgrade to my little set. Thing sounds killer in the room, but getting that to come out of the speakers was not so easy. I suppose I will eventually mount some kind of mic inside, but on this thing I used a dynamic and a Rode NT2 on the front, and then fired a cross-stick sample off the dynamic and printed it. Then used that to key a gate on the condenser and also the room mic, which I multed. The sound of that kick influenced the rest of what I did, as well as some other things I have picked up in the last ten days for peanuts, couple of guitars, and a pair of Yamaha NS-4636 (2 bucks at Goodwill!!!) and a Presonus Dual Path mic pre-amp for 50. That Presonus is pretty nifty for guitars and bass, small, basically a tube direct box, the mic pres are not stellar but I don't mind as it cost 20 per cent of street retail. The main point being that switching things up and getting out of your comfort zone can get you re-engaged and reacting to different sounds impacts your art, hopefully in a good way......here is what I came out with....... clyp.it/gzmtjmznHow annoying...ER, Ahem, CONGRATULATIONS! As to your question - if you want to preserve the current character of the drum as it is now, I'd start by paying attention to what mic I was using on it. You said "dynamic mic" but that covers a lot of territory. There are many, many dynamic mics I would NOT want to use for that application. Probably I'd want to use either an RE-20 or an AKG D12/D20. Probably wouldn't want to use an M88 as it's hypercardiod and I'd want a somewhat wider pattern. I'd have it hanging off the corner of the drum 6" or a foot back, so it could hear a bit of sound off the rear of the drum. I also might try various LDCs but I'd start with one of those two dynamics and see how it sounded. l also would not do the common "close mics witrh overheads" setup on the rest of the kit.
Post by jeremygillespie on Dec 27, 2016 23:41:55 GMT -6
I personally feel that the kick drum sound can lend a LOT to the overal feel of a song. It all comes down to serving the song. For the drums I personally own, I have different heads. Ported, non ported, big holes, small holes, dampening system, etc. Each of these, in combination with the beater type and how the bass drum is played and tuned are huge variables.
When Im using a non ported head, many times I'll add a felt strip on the reso head to tame the boom a bit, but it's not always needed.
If I can't get the sound I want out of a single mic on the front of the drum, I'll either change the beater, the head, or the drum. I don't see any sense in trying to fight the drum or the head in order to get the sound im after.
Post by jjinvegas on Dec 28, 2016 0:38:14 GMT -6
I personally feel that the kick drum sound can lend a LOT to the overal feel of a song. It all comes down to serving the song. For the drums I personally own, I have different heads. Ported, non ported, big holes, small holes, dampening system, etc. Each of these, in combination with the beater type and how the bass drum is played and tuned are huge variables. When Im using a non ported head, many times I'll add a felt strip on the reso head to tame the boom a bit, but it's not always needed. If I can't get the sound I want out of a single mic on the front of the drum, I'll either change the beater, the head, or the drum. I don't see any sense in trying to fight the drum or the head in order to get the sound im after. The whole thing about this drum was how it influenced the approach I used as an arranger. I had an acoustic guitar part, and then I played with that as a guide to the changes, but nothing was spelled out. So the whole ba dum ba dum ba dum sort of thing in the song is because of the decay of the kick, once that was in place the rest of the roles were obvious. Then the laconic nature of the beat suggested the lyrics, so in a way the kick drum is the crucial creative element. It is the best of times, and the worst of times, for writers and creators. We can create and react to recorded material in a way that used to be the exclusive province of the creme de la creme, but that ease is countered by reduced value put on the creations. I guess this site is more about the technical side, so Mr. Eppstein, that is an RE-15 dynamic, the poor musician's RE-20, and I chose the Rode over my usual AT-AE3000 because it has more "bloom" in the envelope. But the room microphone, with a gate controlling its envelope was most predominant, even with a sealed front the kick is quite loud and when it barked it sounded alone even from six feet from the kit. I react to sounds as i write, which is why I am so pleased to find myself surrounded by tools with their own signature, the guitar I picked up to play lead on is a neglected Hagstrom Viking, I hung it back on the wall so I would remember to use it now and then, it alters my playing style, as did the Oberheim/Viscount weighted controller I had put in the closet due to its large, heavy cumbersome nature. But there is nothing like a traditional wooden weighted keyboard to take you back to the feel of an actual piano, it forces a certain technique. Don't tell my long suffering girlfriend/reality check that I am on the lookout for a Leslie 142, there is only so much she can take......
Post by johneppstein on Dec 28, 2016 3:31:37 GMT -6
I personally feel that the kick drum sound can lend a LOT to the overal feel of a song. It all comes down to serving the song. For the drums I personally own, I have different heads. Ported, non ported, big holes, small holes, dampening system, etc. Each of these, in combination with the beater type and how the bass drum is played and tuned are huge variables. When Im using a non ported head, many times I'll add a felt strip on the reso head to tame the boom a bit, but it's not always needed. If I can't get the sound I want out of a single mic on the front of the drum, I'll either change the beater, the head, or the drum. I don't see any sense in trying to fight the drum or the head in order to get the sound im after. The whole thing about this drum was how it influenced the approach I used as an arranger. I had an acoustic guitar part, and then I played with that as a guide to the changes, but nothing was spelled out. So the whole ba dum ba dum ba dum sort of thing in the song is because of the decay of the kick, once that was in place the rest of the roles were obvious. Then the laconic nature of the beat suggested the lyrics, so in a way the kick drum is the crucial creative element. It is the best of times, and the worst of times, for writers and creators. We can create and react to recorded material in a way that used to be the exclusive province of the creme de la creme, but that ease is countered by reduced value put on the creations. I guess this site is more about the technical side, so Mr. Eppstein, that is an RE-15 dynamic, the poor musician's RE-20, and I chose the Rode over my usual AT-AE3000 because it has more "bloom" in the envelope. But the room microphone, with a gate controlling its envelope was most predominant, even with a sealed front the kick is quite loud and when it barked it sounded alone even from six feet from the kit. I react to sounds as i write, which is why I am so pleased to find myself surrounded by tools with their own signature, the guitar I picked up to play lead on is a neglected Hagstrom Viking, I hung it back on the wall so I would remember to use it now and then, it alters my playing style, as did the Oberheim/Viscount weighted controller I had put in the closet due to its large, heavy cumbersome nature. But there is nothing like a traditional wooden weighted keyboard to take you back to the feel of an actual piano, it forces a certain technique. Don't tell my long suffering girlfriend/reality check that I am on the lookout for a Leslie 142, there is only so much she can take...... Agreed on most points. The RE-15 is a "sleeper mic" often ignored but very useful in various situations. I've got a couple of them (actually a couple of RE-10/15s and a couple of RE11/16s) and like them a lot for various things. I question the use in this particular application because they're just a tad bass shy for this - I'd probably want something with a bit more bass extension... and also it's a supercardioid and I'd probably want a somewhat wider pattern - but if it's far enough back, maybe not. It's an interesting choice.... OTOH there are a lot of mics that get commonly used on kick by some people that I'd like a hell of a lot less - MD421 to start with and certainly the SM57 (I don't understand people who use those on kick....)
Post by allbuttonmode on Dec 28, 2016 5:29:58 GMT -6
Congratulations on a real bargain! It's all up to preference and music style, obviously, but I always go for a full front head. I usually burn a small hole at the bottom, large enough to get an xlr connector through, and usually go for a Shure 91 inside, taped to one of these: Evans EQ pad . Then I use whatever is available on the outside, at the center of the head (D112, D12, Fet47, etc.). Move it around a bit to where it's in phase with the inside mic. Then you get both the smack and the sound of the full head.
Post by jjinvegas on Dec 28, 2016 14:26:28 GMT -6
I like the RE15 because the sound of the beater (usually used inside) has that EV thunk instead of that click which I grew weary of. Actually, the fact that it is bass shy is a good thing in this application, as you can turn up the thunk loud enough to actually cut through for definition without further crowding the bottom. Although I like MD421s, as I am no longer running a commercial facility it is hard to justify their cost for their typical role, there are lots of mics that sell for a fraction that can do a fine job picking up the occasional tom fill. I really like an unlikely choice on toms, the Samson Q7, intended as a 58 alternative at Sam Ash, they don't look as cool as a 421 but they have this little presence peak that brings out the stick, supercardioid but not obnoxious off axis (although I typically gate them, where that pattern really helps with false triggers). I see them all the time for about 25 bucks. Less than the price of that semi-fragile mount on Sennheisers. How after 40 years they haven't improved that is a mystery, but maybe they like selling them.....smile....
Post by Guitar on Dec 29, 2016 12:27:18 GMT -6
I think the EV 660 is a really good kick beater mic.
I play an unported kick drum. I got compliments from a pro drummer on my kick sound. One strip of felt on the batter head, no muffling on the reso head, small pillow inside.
I don't even mic the batter side, but I could. Another pro drummer friend of mine says, "It's a kick drum, not a click drum."
I use a subkick, and an M88TG on the reso side near the center of the head. It gets plenty enough attack for my taste, but what I am really looking for is that big, bonhamy low end.
Works for me, anyhow.
