Post by wiz on Dec 6, 2016 15:08:55 GMT -6
ooooh MOTU 8A
would be very cool to use with my 16A and put the monitor outs, headphone outs etc on cheers Wiz
Post by EmRR on Dec 6, 2016 15:13:15 GMT -6
Interesting.
Or for $200 more get a Monitor 8, 8 of the line outs are also headphone outs so you can use them either way, AND get 2 headphone bus, a master and aux output too.
Post by bricejchandler on Dec 6, 2016 15:16:09 GMT -6
Hey,
I'm actually looking for something exactly like this!
Wonder how much it is.
Post by wiz on Dec 6, 2016 15:24:17 GMT -6
I saw a price of 795USD
Post by kcatthedog on Dec 6, 2016 15:33:13 GMT -6
what do we know about the converters ?
Post by kcatthedog on Dec 6, 2016 15:34:11 GMT -6
Superb analog audio quality and high-end converters Renowned ESS Sabre32™ DAC technology delivers 123 dB dynamic range and the same proven, award-winning audio quality as MOTU's flagship 16A.
Post by jcoutu1 on Dec 6, 2016 15:40:55 GMT -6
Interesting. Or for $200 more get a Monitor 8, 8 of the line outs are also headphone outs so you can use them either way, AND get 2 headphone bus, a master and aux output too. Looks like the new box has a better ADC.
Post by wiz on Dec 6, 2016 15:59:24 GMT -6
I will have to have a good think about it.. but one of these might mean I can get rid of a whole patch bay, and associated cabling... and the Behringer 8200 that runs my meters...
Post by mulmany on Dec 6, 2016 16:35:11 GMT -6
I will have to have a good think about it.. but one of these might mean I can get rid of a whole patch bay, and associated cabling... and the Behringer 8200 that runs my meters... cheers Wiz Just go big and get a 2nd 16a! 😁
Post by EmRR on Dec 6, 2016 16:58:04 GMT -6
Or there's that. : )
If you don't need more than 16 AD converters on a regular basis, the Monitor 8 is a contender, with the XLR main out and headphone busses. The AD in it also sounds fine.
Post by wiz on Dec 6, 2016 17:16:02 GMT -6
Does anyone know, if you add a second MOTU AVB interface to say your existing 16A if you can define which interface does the monitor outs...?
Post by indiehouse on Dec 6, 2016 17:21:44 GMT -6
So, how are you supposed to chain this to a 16a? Only 1 thunderbolt port on both, ADAT is only 4 channels at higher sample rates. Sounds like you'll need to invest in AVB.
Post by wiz on Dec 6, 2016 17:29:25 GMT -6
So, how are you supposed to chain this to a 16a? Only 1 thunderbolt port on both, ADAT is only 4 channels at higher sample rates. Sounds like you'll need to invest in AVB. can't you just link em via a ethernet cable? cheers Wiz
Post by indiehouse on Dec 6, 2016 17:33:21 GMT -6
So, how are you supposed to chain this to a 16a? Only 1 thunderbolt port on both, ADAT is only 4 channels at higher sample rates. Sounds like you'll need to invest in AVB. can't you just link em via a ethernet cable? cheers Wiz Don't they both only have the single Ethernet port? I think you might need the AVB hub thing.
Post by EmRR on Dec 6, 2016 17:47:46 GMT -6
AVB from one to the other, USB or TB from one to computer.
You define which is the master output through the AVB routing, and you only use one of the units built in AVB mixers.
You can save all sorts of routing templates for any operation you normally use, in either unit.
You only need an AVB hub for more than 2 units, and there are ways around this using ADAT, or one USB and one TB, etc.
Post by indiehouse on Dec 6, 2016 18:03:28 GMT -6
AVB from one to the other, USB or TB from one to computer. You define which is the master output through the AVB routing, and you only use one of the units built in AVB mixers. You can save all sorts of routing templates for any operation you normally use, in either unit. You only need an AVB hub for more than 2 units, and there are ways around this using ADAT, or one USB and one TB, etc. Ah, I see. That makes sense.
Post by kilroyrock on Dec 7, 2016 7:10:01 GMT -6
The 16A/8A are really intriguing and keep me bouncing back and forth between that or a claret. Since the dude backed out on my last night, I have more time to think about it again.
So what's the ADC? Sabre for DAC, sure. What's the first thing to touch that analog signal?
