Post by sozocaps on Nov 30, 2016 11:32:07 GMT -6
Can someone link to a drawing how this signal flow with an eq and compressor is done.
I want to eq the sidechain on my STAM for my mix bus.
danke schoen !
rjr
New Member
Post by rjr on Nov 30, 2016 12:37:39 GMT -6
I don't have a drawing, but it's easy.
1. Mult the source signal. 2. Send one side of the mult to the comp's stereo inputs, and the other side to the inputs of a stereo EQ. 3. Plug the outputs of the stereo EQ into the comp's sidechain input.
Stereo sidechain inputs are typically unbalanced and use one connector - either XLR or TRS - where "+" is L and "-" is R. So you'll probably need a Y cable from the EQ output to the sidechain input. Check your owner's manual for specifics.
