Post by scumbum on Nov 22, 2016 0:13:43 GMT -6
So I've read it a few times and still don't understand it .
Whats the point of finding 2 different reference points , speaker excursion , and when the cab becomes involved with the sound .
Why not just use the speaker excursion point ? He says it varies and some cabs get involved with the sound before and after the speaker excursion point . But shouldn't the speaker excursion point be the goal ?
I haven't tried this all yet but I'm going to soon .
Post by ericn on Nov 22, 2016 8:25:07 GMT -6
Excursion is the physical limit of the speaker, what he is saying is you need to know the physical limits and where it sounds best !
Post by svart on Nov 22, 2016 8:53:53 GMT -6
So I've read it a few times and still don't understand it . Whats the point of finding 2 different reference points , speaker excursion , and when the cab becomes involved with the sound . Why not just use the speaker excursion point ? He says it varies and some cabs get involved with the sound before and after the speaker excursion point . But shouldn't the speaker excursion point be the goal ? I haven't tried this all yet but I'm going to soon . He means that at a point, the speaker movement starts being resisted by the cabinet. If it's a sealed cab, the air acts as a spring and tries to hold the cone, against which the speaker motor and amplifier are trying to pull and push. It will limit lower and higher frequencies somewhat, and as the cone flexes, will add harmonic distortion, as will the amp straining to move the speaker at higher wattages. However, at very low volumes, the cone isn't moving very much, so the cabinet air volume offers very little resistance. He means finding the point at which you have some cabinet effects, but not too much. Ultimately, the sound will be thicker in the mids, and less highs and lows will be present, but not so much that things get splatty. Something similar happens with ported cabs, the air spring effect is created by the air volume and the port size. This can be adjusted to tailor the response of the system, but I doubt many amp cab manufacturers care too much about this. It's much more important for speaker/monitor manufacturers. Open back speakers have none of these issues, but also don't have the box's frequency extension, nor it's low pass effect, so the resulting sound will be cleaner, but much thinner.
Post by scumbum on Nov 23, 2016 10:24:56 GMT -6
Thanks for the translations , he never explains any of that .
So if the cab gets involved before speaker excursion that would be a bad thing , bad cab .
I don't know , that whole read seems kinda like a bunch of rambling wasted time .
Why not just say " turn the volume up and down until you find where the guitar rig sounds good , then move the mic around the speaker until it sounds good , done , HOHOHO "......
Post by schmalzy on Nov 23, 2016 12:47:11 GMT -6
Why not just say " turn the volume up and down until you find where the guitar rig sounds good , then move the mic around the speaker until it sounds good , done , HOHOHO "...... I think it's probably because its VERY easy to be fooled by volume. Also, a person could chase their tail around a guitar sound for a week if they didn't know what volume they wanted to be at. I appreciate him saying "this is [his idea of] the ideal amount of work a cab should be doing. Don't waste time searching for something beyond this." I'm never convinced I'm not failing spectacularly so I'll never turn down a little guidepost like that!
Post by svart on Nov 23, 2016 16:35:16 GMT -6
Thanks for the translations , he never explains any of that . So if the cab gets involved before speaker excursion that would be a bad thing , bad cab . I don't know , that whole read seems kinda like a bunch of rambling wasted time . Why not just say " turn the volume up and down until you find where the guitar rig sounds good , then move the mic around the speaker until it sounds good , done , HOHOHO "...... It's one of those amusing things you follow when reading a lot hoping to get better at recording, but in the end it IS a bunch of crap. Even positing that there is a single "right" way to do things makes you instantly wrong, although time had certainly weeded out the approaches that don't deliver.. but even then, sometimes those are exactly what you need. I've read professional recordists who have stated everything from turn everything completely to 10, to set the amp volume barely above audible..
Post by scumbum on Nov 23, 2016 23:52:10 GMT -6
Thanks for the translations , he never explains any of that . So if the cab gets involved before speaker excursion that would be a bad thing , bad cab . I don't know , that whole read seems kinda like a bunch of rambling wasted time . Why not just say " turn the volume up and down until you find where the guitar rig sounds good , then move the mic around the speaker until it sounds good , done , HOHOHO "...... It's one of those amusing things you follow when reading a lot hoping to get better at recording, but in the end it IS a bunch of crap. Even positing that there is a single "right" way to do things makes you instantly wrong, although time had certainly weeded out the approaches that don't deliver.. but even then, sometimes those are exactly what you need. I've read professional recordists who have stated everything from turn everything completely to 10, to set the amp volume barely above audible.. I read Weezer on the Blue Album recorded guitars at low volume . Not sure if its true . Who did you read records at low volume ? You know that guy Rob Chapman ? He does a ton of guitar reviews on youtube . This is him here with a cheap Marshall MG practice amp . I have this same amp . Its solid state , 8 inch speaker . It sounds good . I had doubts and thought I must be crazy for liking this amp but he likes it too . You never know with guitar gear .
Post by johneppstein on Nov 24, 2016 12:41:39 GMT -6
So I've read it a few times and still don't understand it . Whats the point of finding 2 different reference points , speaker excursion , and when the cab becomes involved with the sound . Why not just use the speaker excursion point ? He says it varies and some cabs get involved with the sound before and after the speaker excursion point . But shouldn't the speaker excursion point be the goal ? I haven't tried this all yet but I'm going to soon . He means that at a point, the speaker movement starts being resisted by the cabinet. If it's a sealed cab, the air acts as a spring and tries to hold the cone, against which the speaker motor and amplifier are trying to pull and push. It will limit lower and higher frequencies somewhat, and as the cone flexes, will add harmonic distortion, as will the amp straining to move the speaker at higher wattages. However, at very low volumes, the cone isn't moving very much, so the cabinet air volume offers very little resistance. He means finding the point at which you have some cabinet effects, but not too much. Ultimately, the sound will be thicker in the mids, and less highs and lows will be present, but not so much that things get splatty. Something similar happens with ported cabs, the air spring effect is created by the air volume and the port size. This can be adjusted to tailor the response of the system, but I doubt many amp cab manufacturers care too much about this. It's much more important for speaker/monitor manufacturers. Open back speakers have none of these issues, but also don't have the box's frequency extension, nor it's low pass effect, so the resulting sound will be cleaner, but much thinner. I think you're missing the point about cabinet involvement. However, first a bit of an aside about the author. Slipperman (Tim Gilles) was until recently the proprietor and guiding light of Big Blue Meenie Studios, a large studio in New Jersey that was known largely for their work with heavy metal and hard rock acts. Consequently, much of what Slippy says here relates to recording LOUD guitars (you might have got a bit of a hint by the title of the article?) en.wikipedia.org/wiki/Big_Blue_Meenie_Recording_StudioWhen a guitar amp is playing loud it responds somewhat differently than an amp that is playing, er, not so loud. I'm not talking about distortion per se, although that does enter into it. However with modern equipment you can get plenty of distortion without being particularly loud. However it just doesn't really get the same sort of excitement - something's missing. What's missing to a large degree is - you probably guessed it - cabinet involvement. Cabinet involvement is what happens when a sealed cabinet (or sometimes a ported cabinet) is driven to the point where the cabinet's panels become excited and start vibrating enough to make a real conrtribution to the sound in the room. (Hence the term "cabinet involvement".) A cabinet generally has to be driven pretty hard to reach this point. Using a low power head or a power soak won't do it - you generally need AT LEAST 40 or 50 watts and preferably 100 to get those panels vibrating - If they vibrate at all. Not all cabinets are created equal, and this is one of those weird cases where what can be desirable for a guitar amps diverges sharply from what is regarded as "good practice" in the rest of the audio world. Specifically, a cabinet like a classic Marshall 4x12 which is fairly lightrly built out of plywood with virtually no bracing is vastly superior to, e.g. a Mesa Boogie 4x12 which is heavily built and well braced. The latter has virtually no panel resonance - it is "dead", which gives you more or less only the sound produced by the amp and speakers, with no additional coloration.. The Marshall, however, has lots of panel resonance which contributes to the harmonic richness of the combined tone. (Of course not every lightly built, resonant cab is desirable - some sound good, some not so much.) Cabinets made of MDF are generally not desirable, as MDF is pretty non-resonant, as well as being heavy as hell to cart around. No, you probably DO NOT want your drivers hitting maximum excursion before the cab gets involved. That's the way you tear up your speakers. What Slippy's saying is that you want the entire thing vibrating synergistically as a whole to achive a good hard rock/metal tone, at least according to his philosophy of recording. This is something that's often missed in these days of little amps, amp sims, virtual recording, bedroom studios, neighbors, etc. It's one of the big reasons that a lot of "heavy" music isn't so heavy these days.
Post by johneppstein on Nov 24, 2016 13:10:44 GMT -6
I read Weezer on the Blue Album recorded guitars at low volume . Not sure if its true . Probably is. Who cares? I seriously doubt that Weezer has much to do with the type of sound Slippy was talking about. FWIW, I really don't care for Weezer, although I often record guitars at lower volume - but then I don't really do that kind of (loud) music anymore. I generally don't read records, I listen to them. Most artists record at a level they are comfortable with for the music they play. And if they don't, they should. Generally speaking, the more videos they put on Yootoob, the less I pay attention to them, especially the gear reviewers. How many times do you see a bad gear review on YT? Never? Those guys are there to make anything they're "reviewing" appear in the best light possible - it's what they get paid for. If not paid in cash, then in access to gear, relationships with the company, being "internet stars", whatever. If you like the amp, great! Use it. Personally I don't really care for any of the Marshall SS amps, but if it works for you, use it.
Post by svart on Nov 24, 2016 13:27:07 GMT -6
He means that at a point, the speaker movement starts being resisted by the cabinet. If it's a sealed cab, the air acts as a spring and tries to hold the cone, against which the speaker motor and amplifier are trying to pull and push. It will limit lower and higher frequencies somewhat, and as the cone flexes, will add harmonic distortion, as will the amp straining to move the speaker at higher wattages. However, at very low volumes, the cone isn't moving very much, so the cabinet air volume offers very little resistance. He means finding the point at which you have some cabinet effects, but not too much. Ultimately, the sound will be thicker in the mids, and less highs and lows will be present, but not so much that things get splatty. Something similar happens with ported cabs, the air spring effect is created by the air volume and the port size. This can be adjusted to tailor the response of the system, but I doubt many amp cab manufacturers care too much about this. It's much more important for speaker/monitor manufacturers. Open back speakers have none of these issues, but also don't have the box's frequency extension, nor it's low pass effect, so the resulting sound will be cleaner, but much thinner. I think you're missing the point about cabinet involvement. However, first a bit of an aside about the author. Slipperman (Tim Gilles) was until recently the proprietor and guiding light of Big Blue Meenie Studios, a large studio in New Jersey that was known largely for their work with heavy metal and hard rock acts. Consequently, much of what Slippy says here relates to recording LOUD guitars (you might have got a bit of a hint by the title of the article?) en.wikipedia.org/wiki/Big_Blue_Meenie_Recording_StudioWhen a guitar amp is playing loud it responds somewhat differently than an amp that is playing, er, not so loud. I'm not talking about distortion per se, although that does enter into it. However with modern equipment you can get plenty of distortion without being particularly loud. However it just doesn't really get the same sort of excitement - something's missing. What's missing to a large degree is - you probably guessed it - cabinet involvement. Cabinet involvement is what happens when a sealed cabinet (or sometimes a ported cabinet) is driven to the point where the cabinet's panels become excited and start vibrating enough to make a real conrtribution to the sound in the room. (Hence the term "cabinet involvement".) A cabinet generally has to be driven pretty hard to reach this point. Using a low power head or a power soak won't do it - you generally need AT LEAST 40 or 50 watts and preferably 100 to get those panels vibrating - If they vibrate at all. Not all cabinets are created equal, and this is one of those weird cases where what can be desirable for a guitar amps diverges sharply from what is regarded as "good practice" in the rest of the audio world. Specifically, a cabinet like a classic Marshall 4x12 which is fairly lightrly built out of plywood with virtually no bracing is vastly superior to, e.g. a Mesa Boogie 4x12 which is heavily built and well braced. The latter has virtually no panel resonance - it is "dead", which gives you more or less only the sound produced by the amp and speakers, with no additional coloration.. The Marshall, however, has lots of panel resonance which contributes to the harmonic richness of the combined tone. (Of course not every lightly built, resonant cab is desirable - some sound good, some not so much.) Cabinets made of MDF are generally not desirable, as MDF is pretty non-resonant, as well as being heavy as hell to cart around. No, you probably DO NOT want your drivers hitting maximum excursion before the cab gets involved. That's the way you tear up your speakers. What Slippy's saying is that you want the entire thing vibrating synergistically as a whole to achive a good hard rock/metal tone, at least according to his philosophy of recording. This is something that's often missed in these days of little amps, amp sims, virtual recording, bedroom studios, neighbors, etc. It's one of the big reasons that a lot of "heavy" music isn't so heavy these days. Eh, I'm not sure I did, but our opinions are our own I suppose. Most speaker cabs are semi-reinforced for minimal sympathetic vibration. When designing speaker boxes, the box is not supposed to vibrate at all. It's merely a shell to hold the proper amount of air to support the Fs of the speaker for low frequency extension. If they were built to "enhance" the speaker vibration, then nobody would reinforce them and they would be built with much more flimsy materials that vibrate much easier.
Post by johneppstein on Nov 24, 2016 14:28:12 GMT -6
I think you're missing the point about cabinet involvement. However, first a bit of an aside about the author. Slipperman (Tim Gilles) was until recently the proprietor and guiding light of Big Blue Meenie Studios, a large studio in New Jersey that was known largely for their work with heavy metal and hard rock acts. Consequently, much of what Slippy says here relates to recording LOUD guitars (you might have got a bit of a hint by the title of the article?) en.wikipedia.org/wiki/Big_Blue_Meenie_Recording_StudioWhen a guitar amp is playing loud it responds somewhat differently than an amp that is playing, er, not so loud. I'm not talking about distortion per se, although that does enter into it. However with modern equipment you can get plenty of distortion without being particularly loud. However it just doesn't really get the same sort of excitement - something's missing. What's missing to a large degree is - you probably guessed it - cabinet involvement. Cabinet involvement is what happens when a sealed cabinet (or sometimes a ported cabinet) is driven to the point where the cabinet's panels become excited and start vibrating enough to make a real conrtribution to the sound in the room. (Hence the term "cabinet involvement".) A cabinet generally has to be driven pretty hard to reach this point. Using a low power head or a power soak won't do it - you generally need AT LEAST 40 or 50 watts and preferably 100 to get those panels vibrating - If they vibrate at all. Not all cabinets are created equal, and this is one of those weird cases where what can be desirable for a guitar amps diverges sharply from what is regarded as "good practice" in the rest of the audio world. Specifically, a cabinet like a classic Marshall 4x12 which is fairly lightrly built out of plywood with virtually no bracing is vastly superior to, e.g. a Mesa Boogie 4x12 which is heavily built and well braced. The latter has virtually no panel resonance - it is "dead", which gives you more or less only the sound produced by the amp and speakers, with no additional coloration.. The Marshall, however, has lots of panel resonance which contributes to the harmonic richness of the combined tone. (Of course not every lightly built, resonant cab is desirable - some sound good, some not so much.) Cabinets made of MDF are generally not desirable, as MDF is pretty non-resonant, as well as being heavy as hell to cart around. No, you probably DO NOT want your drivers hitting maximum excursion before the cab gets involved. That's the way you tear up your speakers. What Slippy's saying is that you want the entire thing vibrating synergistically as a whole to achive a good hard rock/metal tone, at least according to his philosophy of recording. This is something that's often missed in these days of little amps, amp sims, virtual recording, bedroom studios, neighbors, etc. It's one of the big reasons that a lot of "heavy" music isn't so heavy these days. Eh, I'm not sure I did, but our opinions are our own I suppose. Most speaker cabs are semi-reinforced for minimal sympathetic vibration. When designing speaker boxes, the box is not supposed to vibrate at all. It's merely a shell to hold the proper amount of air to support the Fs of the speaker for low frequency extension. Well, you might haver noticed that I said that this is one of those cases where guitar amp design goes 180 degrees away from conventional practice? Yes, when designing a conventional speaker box it's not supposed to vibrate at all. A guitar cab is not a conventional speaker box, it's better to think of it as the body of the guitar. You probably wouldn't want an acoustic guitar with a non-resonant body, would you? Now, I don't think that any guitar speaker manufacturer has really given much thought to this particular aspect of design (and that those who have considered design principle have tended to embrace conventional concepts, like the Mesa 4x12 which is considered by many to be unresponsive and "stiff" sounding compared to the "much more poorly designed Marshall); I think that the cabs that work well in this way are more likely "happy accidents". Have you ever opened a classic Marshall 4x12? The only thing in it even resembling a brace is a short 2x2 coupling post between the center of the front baffle and the center of the back panel, most likely to kill the fundamental resonant frequency of the back. Other than that there is no bracing whatsoever. There isn't even any fiberglass damping material. And the cabinet is square. Totally wrong from the standpoint of conventional speaker design. Yet it's one of the most successful, popular guitar cabinet designs in history. Well, as I said, I don't think that too many builders have put too much thought into it. There have been companies that put out amps/cabs made of much flimsier materials and generally they havent't sounded that great. My conjecture is that it needs to be a balance between stiffness and flexibility - you need the resonance to be controlled. Again, think of it in terms of the body of an acoustic instrument. When I was younger I built a fair number of speaker cabs, always adhering to conventional construction and design principles - the PA cabs pretty much always came out pretty good. The guitar cabs, OTOH, often seemed a bit... unresponsive - and I could never quite figure out why until I encountered Slippy's comments about "cabinet involvement" at which point a little light bulb went on... Having been involved somewhat equally between the Hi-Fi/Sound reinforcement/Recording side and the Guitar electronics and speaker side of audio I have come to find the dichotomy between to two utterely fascinating. One the guitar side it's important not to be constrained by dogma and instead to ask "why is this happening" when something diverges from the rules. EDIT - It just ocurred to me that both Jim Marshall and Slipperman have backgrounds as drummers. I wonder if the drum design concept of "shell involvement" could have some bearing on this...?
Post by jazznoise on Nov 25, 2016 8:00:42 GMT -6
Slipperman's contributions are not without validity, and also not without serious flaws. It's a very stylized approach - this is how you might work in an overdub based facility making metal records. It's not really of any benefit to someone working a live band session, or recording a country act. However the stuff on cabinets and cabinet excursion and stuff is interesting science to be aware of - though I never bother with it outside of being aware of it. Just get the sound the guitarist likes and uses, and go from there. Reinventing the wheel to sate your own fetish of having a 'process' is not enabling good art.
Also his talk of diaphragm distortion to me seemed like bollocks. A 57's diapraghm can take an insane amount of punishment, if he can find a speaker clean enough to replay a 100Hz and 1Khz tone at 120dB he should play it at an SM57 and plot the output, and then knock it back to 80dB and do the same. The transformer might be driven at higher levels but the diaphragm should be fine.
Post by donr on Nov 25, 2016 9:45:25 GMT -6
Kemper profiles would capture the cabinet involvement, as the Kemper would profile whatever the mic was hearing. Then you'd have it without deafening the neighborhood, and you could use that cab with other amp head profiles.
Post by johneppstein on Nov 26, 2016 14:10:37 GMT -6
Slipperman's contributions are not without validity, and also not without serious flaws. It's a very stylized approach - this is how you might work in an overdub based facility making metal records. It's not really of any benefit to someone working a live band session, or recording a country act. However the stuff on cabinets and cabinet excursion and stuff is interesting science to be aware of - though I never bother with it outside of being aware of it. Just get the sound the guitarist likes and uses, and go from there. Reinventing the wheel to sate your own fetish of having a 'process' is not enabling good art. Also his talk of diaphragm distortion to me seemed like bollocks. A 57's diapraghm can take an insane amount of punishment, if he can find a speaker clean enough to replay a 100Hz and 1Khz tone at 120dB he should play it at an SM57 and plot the output, and then knock it back to 80dB and do the same. The transformer might be driven at higher levels but the diaphragm should be fine. Yeah, as I pointed out he's known primarily for metal, hard rock, and punk recordings and yes, it definitely is a very stylized approach. I haven't had much call to use it since I've been doing country and a bit of blues the last few years, but if I was still involved in the earbleed stuff it would fit right in. I think it's important for all recordists to be aware of since it goes against the grain of a lot of the conventional "innerwebz wizzdom" and makes you aware of aspects that you don't get from a lot of the "orthodox" sources. Yes, there are certain things that you can only get from a real amp cranked up (or perhaps a well crafted Kemper profile of said amp, but that still starts with the amp, doesn't it?) And sometimes a little bit of "gonzo" has its place. I dunno about diaphragm distortion. What I do know is that Shure's capsules are not nearly as clean as they'd have you believe and it wouldn't surprise me one bit if the diaphragm of a typical 57 did distort a bit at high levels.
Post by Guitar on Nov 27, 2016 11:14:22 GMT -6
I have a number of cabinets that respond very differently, disregarding speaker selection. The Silvertone 2x12 is incredibly flimsy and you hear it as sort of a slight compression of the sound coming out of the drivers, probably due to the cabinet flexing under volume or something.
I have a Mojotone 1x12 open back that I believe is made of pine wood. That is a sweet sounding cabinet and I really want to believe the relatively thin pine walls have something to do with it, even though it's open.
My Avatar 4x12 and 2x12 are by comparison sort of plain and predictable, but sound very good, being more of a traditional Marshall style build. The cabinet does not seem to interact too much at least at low and medium volumes. These are really sturdy boxes made of thick plywood.
None of this is tested, it's just impressions I've had from playing through these for many years. It's nice to have the options.
Post by svart on Nov 27, 2016 19:30:44 GMT -6
I have a number of cabinets that respond very differently, disregarding speaker selection. The Silvertone 2x12 is incredibly flimsy and you hear it as sort of a slight compression of the sound coming out of the drivers, probably due to the cabinet flexing under volume or something. I have a Mojotone 1x12 open back that I believe is made of pine wood. That is a sweet sounding cabinet and I really want to believe the relatively thin pine walls have something to do with it, even though it's open. My Avatar 4x12 and 2x12 are by comparison sort of plain and predictable, but sound very good, being more of a traditional Marshall style build. The cabinet does not seem to interact too much at least at low and medium volumes. These are really sturdy boxes made of thick plywood. None of this is tested, it's just impressions I've had from playing through these for many years. It's nice to have the options. Interesting. I was recently chasing guitar tones and was having a tough time getting the sound, even with identical gear to the original player. So during my testing, I mic'd up an open back 1x12 with a V30 in it and BAM, there's my sound. The thing is, I have another closed back cab with a V30 in it, so I mic'd that one up with the same mic, same position.. Not even close to the same tone. So then I pulled the V30 from the open back cab, and put it in the closed back to see if the cabinet made a difference in the tone. I used the same mic placement, and it almost matched the same tone as the open back cabinet. Same goes for the V30 that was in the closed back cab, I placed it in the open back, and got the same tone that I got when it was in the closed back cab. So my testing showed that the cabs offered almost no change in tone to the speaker, at any level. However, these were both English made V30's of the same era/same impedance, and sounded like completely different models of speakers. Based on this, I believe that the speakers themselves had MUCH more difference between each other than any cab could introduce.
Post by svart on Nov 27, 2016 19:33:26 GMT -6
Eh, I'm not sure I did, but our opinions are our own I suppose. Most speaker cabs are semi-reinforced for minimal sympathetic vibration. When designing speaker boxes, the box is not supposed to vibrate at all. It's merely a shell to hold the proper amount of air to support the Fs of the speaker for low frequency extension. Well, you might haver noticed that I said that this is one of those cases where guitar amp design goes 180 degrees away from conventional practice? Yes, when designing a conventional speaker box it's not supposed to vibrate at all. A guitar cab is not a conventional speaker box, it's better to think of it as the body of the guitar. You probably wouldn't want an acoustic guitar with a non-resonant body, would you? Now, I don't think that any guitar speaker manufacturer has really given much thought to this particular aspect of design (and that those who have considered design principle have tended to embrace conventional concepts, like the Mesa 4x12 which is considered by many to be unresponsive and "stiff" sounding compared to the "much more poorly designed Marshall); I think that the cabs that work well in this way are more likely "happy accidents". Have you ever opened a classic Marshall 4x12? The only thing in it even resembling a brace is a short 2x2 coupling post between the center of the front baffle and the center of the back panel, most likely to kill the fundamental resonant frequency of the back. Other than that there is no bracing whatsoever. There isn't even any fiberglass damping material. And the cabinet is square. Totally wrong from the standpoint of conventional speaker design. Yet it's one of the most successful, popular guitar cabinet designs in history. Well, as I said, I don't think that too many builders have put too much thought into it. There have been companies that put out amps/cabs made of much flimsier materials and generally they havent't sounded that great. My conjecture is that it needs to be a balance between stiffness and flexibility - you need the resonance to be controlled. Again, think of it in terms of the body of an acoustic instrument. When I was younger I built a fair number of speaker cabs, always adhering to conventional construction and design principles - the PA cabs pretty much always came out pretty good. The guitar cabs, OTOH, often seemed a bit... unresponsive - and I could never quite figure out why until I encountered Slippy's comments about "cabinet involvement" at which point a little light bulb went on... Having been involved somewhat equally between the Hi-Fi/Sound reinforcement/Recording side and the Guitar electronics and speaker side of audio I have come to find the dichotomy between to two utterely fascinating. One the guitar side it's important not to be constrained by dogma and instead to ask "why is this happening" when something diverges from the rules. EDIT - It just ocurred to me that both Jim Marshall and Slipperman have backgrounds as drummers. I wonder if the drum design concept of "shell involvement" could have some bearing on this...? It's good thoughts, but due to the proximity of the mic to the cone in most close-mic applications, there is no way that cabinet vibrations could be loud enough to compare to the cone's power. Maybe it might make a difference if it was only room mics some distance away and off axis.
Post by jazznoise on Nov 28, 2016 6:40:58 GMT -6
That's less the point and more the point that the cabinet resonances act as a feedback network to the speaker, drastically affecting how the speaker itself sounds.
Post by svart on Nov 28, 2016 7:30:36 GMT -6
That's less the point and more the point that the cabinet resonances act as a feedback network to the speaker, drastically affecting how the speaker itself sounds. I still disagree with this theory. The inverse square law dictates that there is no way that an enclosure panel sympathetically moving <1mm can effectively change the tone of a speaker being driven to move 5mm-10mm. Besides, I posted my findings in the post before last where I swapped speakers in boxes and found that there was almost no difference in tone in the different boxes, at different powers. The only difference was change in low end response from the volume/closed/open nature of the box, and that was minimal.
Post by kilroyrock on Nov 28, 2016 10:25:30 GMT -6
It's one of those amusing things you follow when reading a lot hoping to get better at recording, but in the end it IS a bunch of crap. Even positing that there is a single "right" way to do things makes you instantly wrong, although time had certainly weeded out the approaches that don't deliver.. but even then, sometimes those are exactly what you need. I've read professional recordists who have stated everything from turn everything completely to 10, to set the amp volume barely above audible.. I read Weezer on the Blue Album recorded guitars at low volume . Not sure if its true . Weezer did record the blue album guitars really low. They also had/have these ridiculously tall marshall cabs. Liking weezer aside ( I do, others don't), the production on that album was GREAT. Such meat on them guitars. The vinyl version I have just crushes it.
Rivers said Pinkerton was like in utero to the blue album and nevermind. Freaked out and trying to make the perfect album and caring too much about the production side of it all. Live everything, crushed LDC's and excitement at Sound City, vs Blue album's New York City Electric Lady Studio action.
From weezer.com:
Also responsible for that sound is the Mesa Boogie, which was still in top condition at this time. The Mesa was run through the tall Marshall, often at unusually low volume, to get some of the sounds on the album. As far as I know, there are NO effects pedals on the guitar sounds on the Blue Album. Rivers would not start really fooling around with recording with effects and pedals till later
Post by scumbum on Nov 28, 2016 12:56:56 GMT -6
That's less the point and more the point that the cabinet resonances act as a feedback network to the speaker, drastically affecting how the speaker itself sounds. I still disagree with this theory. The inverse square law dictates that there is no way that an enclosure panel sympathetically moving <1mm can effectively change the tone of a speaker being driven to move 5mm-10mm. Besides, I posted my findings in the post before last where I swapped speakers in boxes and found that there was almost no difference in tone in the different boxes, at different powers. The only difference was change in low end response from the volume/closed/open nature of the box, and that was minimal. Have you tried the same speaker in a 1x12 , 2x12 and 4x12 to see how much difference there is close miced ? I've always wanted to try this myself .
Post by svart on Nov 28, 2016 13:14:33 GMT -6
I still disagree with this theory. The inverse square law dictates that there is no way that an enclosure panel sympathetically moving <1mm can effectively change the tone of a speaker being driven to move 5mm-10mm. Besides, I posted my findings in the post before last where I swapped speakers in boxes and found that there was almost no difference in tone in the different boxes, at different powers. The only difference was change in low end response from the volume/closed/open nature of the box, and that was minimal. Have you tried the same speaker in a 1x12 , 2x12 and 4x12 to see how much difference there is close miced ? I've always wanted to try this myself . yeah, one speaker was in a 1x12 open cab, the other in a 2x12 closed cab with another speaker. I swapped them around thinking that the cab and/or other speaker might be making a difference, but 99% of the tone moved with the speaker itself. Having a speaker wired in parallel made a difference in tone, so I ran the 2x12 as a single speaker, and even then the tone was not very different at all to the same speaker being in the open back cab. The bass was slightly dampened, but not as much as I expected. The crazy thing was that these were both English made V30's from the same era, but they couldn't be further apart in tone than a greenback is to a V30. I used to think that boxes mattered more in tone and that speaker selection did not.. Now my beliefs are completely opposite.. That the box doesn't matter as much and the speaker itself is much more important. I now see why folks are always talking about "selecting the speaker in the cab that sounds the best".. I used to think that being the same make/model, that speakers couldn't possibly be that different in tone. Talk about being wrong.
Post by johneppstein on Nov 29, 2016 0:41:55 GMT -6
That's less the point and more the point that the cabinet resonances act as a feedback network to the speaker, drastically affecting how the speaker itself sounds. Exactly. It affects the way the speaker itself sounds and additionally will make a difference in room sound if you're using a seconde mic at a distance.
Post by johneppstein on Nov 29, 2016 0:59:34 GMT -6
That's less the point and more the point that the cabinet resonances act as a feedback network to the speaker, drastically affecting how the speaker itself sounds. I still disagree with this theory. The inverse square law dictates that there is no way that an enclosure panel sympathetically moving <1mm can effectively change the tone of a speaker being driven to move 5mm-10mm. Besides, I posted my findings in the post before last where I swapped speakers in boxes and found that there was almost no difference in tone in the different boxes, at different powers. The only difference was change in low end response from the volume/closed/open nature of the box, and that was minimal. I don't think that the inverse square law is applicable when there's a direct mechanical coupling involved. Also it's not necessarily the amount of physical movement of the panel affection the speaker as much as the moving mass of that panel relative to the much lighter mass of the speaker cone(s). Also, saying you found "almost" no difference in tone doesn't really mean much of anything as your results really only apply to the specific cabinet constructions you used and cabinet involvement does not occur at the same volume level on all cabinets in which it is a significant factor, which makes it rather difficult to set up a direct comparison. It's also one of those things where even cabinets of the same make and model might not behave in exactly the same way - we're dealing with wood here, which is not a homogenous material. Again, think in terms of the acoustical properties on an (acoustic) guitar body - two guitars of the same model can sound quite different; one might be a dog and another might be magic. Haven't you ever encountered a situation where one speaker cabinet has something "special" about it that a similar cabinet lacks? Everything matters. The propoprtions in which things matter relastive to each other depend on the build and the situation.
Post by kilroyrock on Nov 29, 2016 6:21:00 GMT -6
The biggest difference i've heard when micing a cab is open back vs closed back. Lots more bottom. Maybe playing low gives you less vibration on the back, and gives sort of a middle ground of an open back and closed back?
I really like green day's dookie, which i believe is a close 421 and a 57, and a U87 room mic, which is the main sound of the cd. Big bass guitar work on the tracks though. Great bass makes any guitar track better
