Post by ericn on Oct 26, 2016 11:51:00 GMT -6
A pretty 47 Fet i for $3k at the Overland Park KS GC sure is pretty but I just can't justify the $$ for a Fet . I keep telling g my self $3k could buy a used pair of Gefells and a c38!
Post by mulmany on Oct 26, 2016 13:41:14 GMT -6
You can also diy for under a grand!
Post by ericn on Oct 26, 2016 14:50:01 GMT -6
You can also diy for under a grand! Yeah I was thinking that as well , but I must say the body work & hardware was better than any $100o clone I have seen !
Post by Ward on Oct 26, 2016 15:25:42 GMT -6
It is well worth it. Buy it. I have two. Numbers 52 and 57.
Post by ericn on Oct 26, 2016 16:15:46 GMT -6
It is well worth it. Buy it. I have two. Numbers 52 and 57. So you want another ? Serial #72--, it is a pretty good price if you have 3k to spend but not for me.
Post by illacov on Oct 26, 2016 16:25:41 GMT -6
Ericn, You might consider a Warbler IID. If you're not digging the capsule (which sounds pretty good to my ears) an upgrade to a Thiersch M7 would set you back around $400 or a Heiserman HK47 for $250??. You'd still be clocking in under $700 and the mic offers some major versatility with the pattern, voicing and pad options.
Another candidate that I dig in this category is the JJ Rottweiler 47. Cinemag out tx, K47 capsule, high quality caps. On groupbuy they go for $650, at least they used to. I could put my Rottweiler inside a kick drum and man it was insane in there.
The Warbler is plenty interesting. Their stock capsules sound pretty sweet.
Thanks -L
Post by bradd on Oct 26, 2016 16:42:18 GMT -6
If I was extremely wealthy, I suppose I could justify the expense of a real 47 fet. I just can't see spending 3K for a mic that is largely thought of as a great outside kick and bass amp mic.
Post by ericn on Oct 26, 2016 16:54:57 GMT -6
Ericn, You might consider a Warbler IID. If you're not digging the capsule (which sounds pretty good to my ears) an upgrade to a Thiersch M7 would set you back around $400 or a Heiserman HK47 for $250??. You'd still be clocking in under $700 and the mic offers some major versatility with the pattern, voicing and pad options. Another candidate that I dig in this category is the JJ Rottweiler 47. Cinemag out tx, K47 capsule, high quality caps. On groupbuy they go for $650, at least they used to. I could put my Rottweiler inside a kick drum and man it was insane in there. The Warbler is plenty interesting. Their stock capsules sound pretty sweet. Thanks -L I have the ground covered, with my Lawson Fet, if anything I would have Shannon build me a head ! The price is on the low side and it is pretty but If I were in that price range I'd buy a FLEA ef12 like bradds or have Shannon tweet a DIY or CV4. Besides after spending $3k I bet I'd still end up sending it to Sinsay!
Post by aremos on Oct 26, 2016 16:56:53 GMT -6
For just another $300, you can buy a brand new one. And it's worth it!
Post by ericn on Oct 26, 2016 16:57:03 GMT -6
If I was extremely wealthy, I suppose I could justify the expense of a real 47 fet. I just can't see spending 3K for a mic that is largely thought of as a great outside kick and bass amp mic. I have used a Fet on vocals, It's not a M7 but K47, and definetly not your FLEA!
Post by aremos on Oct 26, 2016 16:58:30 GMT -6
I liked it better than the FleA
Post by ChaseUTB on Oct 27, 2016 13:18:28 GMT -6
You can also diy for under a grand! Yeah I was thinking that as well , but I must say the body work & hardware was better than any $100o clone I have seen ! F*** the body work let's talk about a real Neumann capsule that's most important lol
Post by ChaseUTB on Oct 27, 2016 13:22:21 GMT -6
My main vocal mic is an fet m7 frankenmic, modded and based on 47 fet but with Thiersch Blue line m7 and electronics tuned for that $175 for St77 donor mic, $550 for trafo, electronics and capsule install
Post by ericn on Oct 27, 2016 13:31:36 GMT -6
Yeah I was thinking that as well , but I must say the body work & hardware was better than any $100o clone I have seen ! F*** the body work let's talk about a real Neumann capsule that's most important lol Yeah but a gets a K47 not a m7!
Post by ChaseUTB on Oct 27, 2016 13:45:06 GMT -6
F*** the body work let's talk about a real Neumann capsule that's most important lol Yeah but a gets a K47 not a m7! I'm well aware that the U 47 FET comes with a K 47 FET capsule ... my frankenmic employs an m7 blue line and similar electronics to a fet47.... *** Edit So yes, historically accurate, not by any means The sound tho.... glorious!
Post by ericn on Oct 27, 2016 14:14:05 GMT -6
Yeah but a gets a K47 not a m7! I'm well aware that the U 47 FET comes with a K 47 FET capsule ... my frankenmic employs an m7 blue line and similar electronics to a fet47.... *** Edit So yes, historically accurate, not by any means The sound tho.... glorious! I think that's why I always preferred the Gefell UM70/71 Fet over a 47 Fet most of the time!
