Post by M57 on Jul 11, 2016 18:35:00 GMT -6
I feel like I'm starting to get a handle on how a number of compressor types work.. E.g, VCA (DBX 160), Optical (SA-2A), FET (1176), etc - and the different types of functions they can serve in the studio. I now have one of each of the above in my studio so I'm actually getting to hear the difference too, but I feel like I'm in the dark when I hear/read pre-amp speak.. I think part of the problem is there are so many vintage standards out there, and aside from whether or not they have tubes, I have trouble differentiating what makes them sonically different. I've done a bit of searching, but mostly I find online stores that are pointing you to their inventory. Can someone point me to a layman's primer out there that is comprehensive. While I am interested in different brands and models that fall into different design categories, I'm just as interested in learning about the categories themselves. Something tells me it's not as simple as compressor types. For instance pretty much all amps are Class A.
So if it's not a 'type' thing, maybe different people can impart specific knowledge about a "Vintage" type, name some of its 'clones' and 'inspired by' models that are out there, and offer a general description of what it sounds like, and maybe even what it's typically used for and what mics pair well with it. I realize that may be a tall if not impossible order - e.g. it may not about the mic and pre so much as it is about the source. Anyway, just throwing it out there.
Post by M57 on Jul 12, 2016 5:20:46 GMT -6
OK, so too broad of a question. I found this page on the Musician's friend site, and the part that got my attention was on transformers and the fact that apparently they are 'controversial.' Can someone weigh in on what's so controversial about them? Disclaimer - I'm looking for a good clean/transparent single channel pre-amp to complement my Dizegoff D4's, which have plenty of character. And though I'm hoping to get specific advice on that score, I really want to have a better understanding of the general differences in solid state and possibly hybrid designs.
Post by chasmanian on Jul 12, 2016 8:42:35 GMT -6
Post by joseph on Jul 12, 2016 8:53:13 GMT -6
Transformers are good for isolation from interference, impedance matching, and dealing with voltage loads, and can add a pleasing distortion and transient handling. But some transformers like Jensens are transparent and low distortion. Transformerless designs are more transparent generally speaking, and cheaper at entry level, but hard to design for musical character and low interference.
If you want a transparent pre that is still musical I would check out John Hardy M1 with transformer. For transformerless design but low interference and on the warmer side, Forsell, Schoeps, Gordon, GML, or AEA.
That said, maybe that's not actually what you want.
To give a basic rundown, some preamps such as transformerless or opamp designs and so on are faster with the transient response, and some are slower, like tube and multi-transformer designs. Some, like a cheap IC design you find in all-in-one USB interfaces are more opaque and flat, or like a true discrete design more 3 dimensional. Same is true of microphones in general.
Also preamps can have more headroom before distortion or less, and can have musical or nasty clipping distortion.
Some examples:
API style pres are mid forward, CAPIs are a little mellower/thicker, with more harmonic character like the vintage API designs. So one might use them on snare or guitars.
Neves are thicker and slower and bigger sounding. Some one might use them on kick or overheads or vocals. Engaging the eq on a 1073 will also tighten up the sound a bit, and can be used to add sheen.
Electrodynes are sorta in between, not too fast, balanced but pretty fat sounding.
Vintage style tube pres like Telefunken, Chandler Redd 47, Tubetech and so on are more euphonic, have a pleasing harmonic distortion or soften sibilance and are really 3D or big sounding, but can still be more laid back or forward sounding depending on the character. Telefunken is more laid back, Chandler is more forward, and Tubetech is fat. Some modern tube designs are pretty clean sounding, though, like DW Fearn.
Another thing to consider is how preamps stack in the mix, which is a big part of the API or Neve sound, for instance, where you have a certain character in midrange and separation of elements as a result.
Post by EmRR on Jul 12, 2016 8:59:04 GMT -6
The difference available in tube pre's is far greater than generally acknowledged, as not many people have heard great shit tons of what's been used across decades of design theory. The commonly known late 50's and 60's tube stuff sounds closer to SS than it does to the tube stuff that came before.
Post by joseph on Jul 12, 2016 9:00:48 GMT -6
Right, a lot of vintage tube designs are pretty hifi sounding with proper gain staging and a lot of cheaper modern designs are pretty gray, noisy or congested sounding.
Post by EmRR on Jul 12, 2016 9:12:04 GMT -6
Yep, cheaper modern tube seems to aim for 'guitar amp theory', which 1940's stuff does better while still sounding open and hi-fi. Then you get into push-pull versus single ended and those harmonic differences, inductance value of transformers and the associated affects on sound, amount of negative feedback used (or not) and it's affect on harmonics, slope of distortion content (limiting versus compressing versus clipping), etc etc etc. Then there's early SS that's designed following tube theory, using transformers and fixed gain circuits......
Post by jcoutu1 on Jul 12, 2016 9:16:39 GMT -6
I found this post that I made from another thread. Updating here, with some more current info/thoughts.
Disclaimer: This is all based on my first hand experience. Clean to one person might be sterile to another. Words describing sound should always be taken with a grain of salt.
Nightpro PreQ3 (Maag PreQ4: transformer, solid state) - Great preamp. Nice weight/clarity and the Air Band is killer.
Thermionic Culture Rooster (transformer, tube) - Nice preamp. Solid color. EQ is good, not great, attitude is cool when you need some added tube harmonics. Lot of use here.
Peavey VMP-2 (transformer, tube) - Really cool, vintage sounding preamp. Thick on the bottom, round top, sounds pretty old school. Not an everyday workhorse, but cool when you're looking for that sound.
Millennia HV3C (transformerless, solid state) - Fast, clean pre. I know a lot of people don't like these, but I love the clarity for some sources. Really dig these on acoustic instruments and overheads with a pair of KM184's. Modern, clean, detailed sound.
UA 610 (transformer, tube) - Thick and wooly. I've have good results with kick and bass DI. I've tried it on vocals, acoustic/electric guitars, and snare and haven't liked the results.
Vintage Neve 1073 (GAP, BAE, Heritage Audio, AML: transformer, solid state) - Thick bottom, round top (darker than you would expect), with the ability to get dirty when pushed. Complete opposite of the Millennaia. I've used these positively on vocals, snare, and acoustic guitars.
API 512c (CAPI, Warm, BAE: transformer, solid state) - Fast, mid forward, great bite. Love them on guitar...drums all day. I haven't been happy with them on vocals or acoustic guitar.
Avalon VT-737sp (transformer, tube) - Nice, fairly clean tone. GREAT EQ. Love it on snare, good on vocals.
Grace 101 (transformerless, solid state) - Quick and detailed. Great sounding, inexpensive, transformerless preamp.
True Precision (transformerless, solid state) - Quick clean tone, but soulless.
SSL E and G (solid state) - Average preamps. Utility.
Joe Meek VC1 (transformer, solid state) - This thing has a tone to it. Sometimes it works, sometimes it doesn't. Doesn't blow me away on anything, but it's serviceable.
Midas Venice (transformerless, solid state) - Average preamps. Utility.
Post by tasteliketape on Jul 12, 2016 9:42:03 GMT -6
It's strange how often I hear I want that "Tube sound" when come to find out what the sound there wanting came from API , Neve ,etc no tubes I Think this a very common misconception Very good points Joseph and Emmr
Post by Ward on Jul 12, 2016 10:10:06 GMT -6
SSL E and G (solid state) - Average preamps. Utility. I think you spelled "suck ass" wrong. But I might be mistaken...
Post by jcoutu1 on Jul 12, 2016 10:15:31 GMT -6
SSL E and G (solid state) - Average preamps. Utility. I think you spelled "suck ass" wrong. But I might be mistaken... Nah. The Digi002 preamps were "suck ass". The SSL are usable.
Post by EmRR on Jul 12, 2016 11:13:05 GMT -6
It's strange how often I hear I want that "Tube sound" when come to find out what the sound there wanting came from API , Neve ,etc no tubes I Think this a very common misconception Very good points Joseph and Emmr And the 'tube sound' is often actually the transformer sound. You could DIY some 990 Hardy type preamps with all sorts of different and antique 1:2 and 1:1 transformers and get something else entirely.
Post by rowmat on Jul 12, 2016 12:51:02 GMT -6
The other thing to contemplate is a preamp set to a gain of 60db means the mic input signal has been increased in power ONE MILLION TIMES voltage 1000 times by the time it reaches the output of the pre.
So not only are the individual characteristics of different mics more obvious at high gains but also any type of preamp coloration that occurs especially in the first stages of the preamp (input transformer etc) becomes more far more apparent at higher gain settings.
Post by jakeharris on Jul 12, 2016 12:52:48 GMT -6
Clean, huge, no trannies: DAV BG1
Post by Pueblo Audio on Jul 12, 2016 14:00:30 GMT -6
The other thing to contemplate is a preamp set to a gain of 60db means the mic input signal has been increased in power ONE MILLION TIMES A polite correction... The VOLTAGE (not power) has been increased ONE THOUSAND TIMES (not one million) (And people from Phoenix are called "Phoenicians" ;-)
Post by rowmat on Jul 12, 2016 14:30:04 GMT -6
The other thing to contemplate is a preamp set to a gain of 60db means the mic input signal has been increased in power ONE MILLION TIMES A polite correction... The VOLTAGE (not power) has been increased ONE THOUSAND TIMES (not one million) (And people from Phoenix are called "Phoenicians" ;-) Correction noted... Voltage gain!
Post by thehightenor on Jul 12, 2016 14:58:08 GMT -6
Clean, huge, no trannies: DAV BG1 Yes that's a sleeper pre-amp - hugely underrated.
I think the 500 series DAV is about £250!
I had a BG1 on test here and put it up against my £3000 Millennia STT-1 channel strip pre's.
I had to admit to myself the DAV sounded every bit as big detailed and high quality as the valve pre path on my STT-1.
I was surprised I thought it would be the solid state path on the Millennia that would be most like the DAV but in fact the DAV had some warmth to it that really held perfectly against the Millennia valve path pre.
The DAV really is a great high quality pre-amp.
A BG1 is still on my wish list.
Post by Guitar on Jul 13, 2016 8:55:58 GMT -6
Daww, one of my favorite geeky topics!
I tend to favor the solid state transformer preamps for just about anything. SCA N72 (Neve) is fat and thick, CAPI VP312 (API, I modified to use Cinemag transformers) is a little more snappy sounding with a mid push to it, but still plenty of color. Both are usable on almost anything, and I absolutely love both of them. I just wish I had about 10 more of each.
The rest of my preamps are of the clean utility type, including Apollo Unison, Mackie Onyx, Presonus XMAX, Steinberg Yamaha D-Pre and Yamaha MLA-8, Focusrite Scarlett, and the Tascam UH-7000 HDIA Preamps. Wow, I have a lot of these! They get used but not as often as the CAPI and SCA. Usually more for instrument inputs.
Probably my favorite of all of those is the Tascam UH-7000. The sound is so smooth and natural to my ears, it almost rivals the Neve sound, just a bit lighter and cleaner. But the sound is so very "warm" for an IC op amp transformerless preamp, they did a great job with those. I would not hesitate to use these on any critical recording.
The Yamaha D-Pre in the Steinberg UR824 also has a smooth, natural sound and is a great all-around choice.
I use the Apollo preamps mostly for Hi-Z inputs now and then, when I'm doing DI work.
I am extremely curious about tube preamps, but the expense and scarcity of them has sort of kept me away. I did own the UA 610, and it's been described well above. Sort of warm and wooly, sort of dark on top.
I love preamps like the API that can have a DI input on them. That makes them extra fun for me.
One of these days I'm going to build a 4-channel Hardy M-1 clone. That will be fun. Also would like to add some VP28's from CAPI.
Post by rowmat on Jul 13, 2016 12:36:40 GMT -6
Daww, one of my favorite geeky topics! I tend to favor the solid state transformer preamps for just about anything. SCA N72 (Neve) is fat and thick, CAPI VP312 (API, I modified to use Cinemag transformers) is a little more snappy sounding with a mid push to it, but still plenty of color. Both are usable on almost anything, and I absolutely love both of them. I just wish I had about 10 more of each. The rest of my preamps are of the clean utility type, including Apollo Unison, Mackie Onyx, Presonus XMAX, Steinberg Yamaha D-Pre and Yamaha MLA-8, Focusrite Scarlett, and the Tascam UH-7000 HDIA Preamps. Wow, I have a lot of these! They get used but not as often as the CAPI and SCA. Usually more for instrument inputs. Probably my favorite of all of those is the Tascam UH-7000. The sound is so smooth and natural to my ears, it almost rivals the Neve sound, just a bit lighter and cleaner. But the sound is so very "warm" for an IC op amp transformerless preamp, they did a great job with those. I would not hesitate to use these on any critical recording. The Yamaha D-Pre in the Steinberg UR824 also has a smooth, natural sound and is a great all-around choice. I use the Apollo preamps mostly for Hi-Z inputs now and then, when I'm doing DI work. I am extremely curious about tube preamps, but the expense and scarcity of them has sort of kept me away. I did own the UA 610, and it's been described well above. Sort of warm and wooly, sort of dark on top. I love preamps like the API that can have a DI input on them. That makes them extra fun for me. One of these days I'm going to build a 4-channel Hardy M-1 clone. That will be fun. Also would like to add some VP28's from CAPI. If you already have a SCA rack and are thinking about a John Hardy why not build the SCA J99 which is modelled on the Twin Servo? We have two and they are excellent. seventhcircleaudio.com/products/J9We also have 4x N72's and 4x C84's. The are great with the C84's obviously being the cleanest and more suited to acoustic instruments. I agree about the UA 610 if it was a MKII. I find ours is woolly/muddy and the compressor is kind of grabby once the signal crosses the threshold. I've never found anything I like running through it.
Post by Guitar on Jul 13, 2016 12:55:35 GMT -6
I have considered the J99. However my plan is to use the Jensen input transformers, and I already have 4x PCBs and a PSU ready. I just need to get nitty gritty, order the case and parts, all the transformers, op amps, etc, and get started with it. It's going to be a somewhat expensive project, however I think it will still come out slightly cheaper than the SCA. Also I love me a good from-scratch build, rather than using a kit. I just have about 20% more fun that way. You should see svart 's stuff, it's amazing, mostly from scratch.
Post by M57 on Jul 15, 2016 17:55:47 GMT -6
Thanks everyone, this has been really helpful - Of course, parts of it went over my head, but that is to be expected.
Post by spock on Jul 16, 2016 11:01:03 GMT -6
It's interesting that the term bloom has not been used here. To me, where tubes reach beyond solid state, is something I identify as bloom or note bloom. Another key thing with tubes vs solid state is the randomness valves can yield, which I find to be more natural. None of this is to say tube circuits are better than solid state, just different in the message each send.
Post by swurveman on Jul 17, 2016 12:55:14 GMT -6
I watched a Rupert Neve interview about why he designed his original consoles with tubeless preamps and he said it was because of the noise of tubes. Can someone explain what has happened through the years that has solved the problem of noisy tubes?
Post by Ward on Jul 18, 2016 8:17:33 GMT -6
I watched a Rupert Neve interview about why he designed his original consoles with tubeless preamps and he said it was because of the noise of tubes. Can someone explain what has happened through the years that has solved the problem of noisy tubes? I never ever bought that. I think it had more to do with economy of space by using transistors and facility due to servicing considerations. And of course, reduction in cost to manufacture! But no matter the reasons, you cannot argue with his signature sound!
