Post by Johnkenn on Jun 15, 2016 9:50:41 GMT -6
I don't know how I've missed these...I think he's in Nashville too...anyway, thanks nomatic for bringing it to my attention (at least I think...now I want the pre and comp) Rembrandt Mic Pre Housed in a 2U rack unit, the Rembrandt is centered around the EF806 pentode tube, which provides some of the most sonically pleasing amplification available. The signal first enters the preamp by passing through an ultra high fidelity Jensen transformer, and from there moves to the EF806, followed by a 12au7. The signal exits the Rembrandt by passing through another ultra high fidelity Jensen output transformer. The entire preamp is discrete, single ended, and Class A in design, causing it to handle transients and the full range of frequencies in a way that few preamps are able to accomplish. . Regarding the control features, the Rembrandt offers a very unique and extraordinarily versatile set of tools at the user’s disposal: . - The LOW CUT control allows the user to select six different positions, from zero bass cut to a max cut for all frequencies below 1k hz. This feature is essential in tweaking the preamp for a variety of sources and conditions. . - The GAIN control does not technically set the gain of the amplification stage, but instead, sets the amount of negative feedback used for the channel. The more negative feedback selected, the quieter the volume is, but also the more linear and neutral the sound becomes. Selecting the position that allows for the most volume actually bypasses the negative feedback loop and offers the most pure, harmonically rich amplification the preamp has to offer. A good way to think about this control is like a “Variable Pad”, though it does more than just pad the signal. . - The BOOST switch, allows the user to increase gain, alter the response of the EF806, and let the preamp run wild! . - The TRIM control is actually closer to a standard Gain control, but does act as a master volume in this particular circuit. This control allows you to set the amount of negative feedback to taste, then control the output volume in order to not overdrive the output signal. . With these controls, the Rembrandt can go from an extremely linear and controlled preamp to an out of control gain monster. It can be neutral or colored, clean or dirty, and shines in any application. It is a force to be reckoned with! . **Included Features** - Phase Reverse - 48v Phantom Power - XLR In and Out - DI Input - Six Position Low Cut Switch - Gain Boost Switch - Gain Knob - Trim Knob - Two EF806's and One 12au7 - Jensen Transformers - All Hand-Wired construction - Rugged, etched metal faceplate
Post by Johnkenn on Jun 15, 2016 9:55:29 GMT -6
Van Gogh Compressor
When considering the optical based, tube studio compressor, there have been some fantastic examples produced over the years. Typically these compressors have typically fallen into the “tried and true” category, desiring to stick to one or two main applications. However, what if an optical tube compressor could break through the historical model, incorporating a whole host of “crazy” ideas that incorporated some of the past, but merged it into something that embodied true versatility and pure tone? . Well, you would have the Hendyamps Van Gogh, and it is not for the feint of heart! . Tube Optical Compressor Housed in a 2U rack unit, the Van Gogh employes 12au7‘s for the makeup gain portion of the unit. The signal first enters the Van Gogh by passing through an ultra high fidelity Jensen transformer, and from there moves to the two 12au7 gain stages. The signal exits the Van Gogh by passing through another ultra high fidelity Jensen output transformer. The entire compressor is completely hand-built, all tube, discrete, single ended, and Class A in design, causing it to handle transients and the full range of frequencies in a way that few compressors are able to accomplish. The compression is handled by three different circuits that all feed in together, allowing for the user to engage and manipulate any combination of the compressors at the same time. . Regarding the control features, the Van Gogh offers a unique and extraordinarily versatile set of tools at the user’s disposal: . - The GAIN control allows the user to increase the gain after the compression has been added to the signal. . - The RATIO control allows the compression to affect the signal more as the knob is turned clockwise. . - The COMP switches allow the user to switch the gain reduction for that particular compressor in and out of the circuit for immediate analysis regarding the compression vs bypassed signal. . - The GLOBAL THRESHOLD knob controls the overall gain reduction circuit for all compressors at the same time. Using this control in conjunction with the Threshold controls for each compressor allows for an incredible amount of versatility and options. . - The DISTORTION SHAPE switch changes the shape and character of the third compressor. In the down position the compressor acts as a hard limiter that produces a large amount of distortion and fuzz. In the up position, the distortion becomes much more sharp and aggressive. The down position is very nice on bass guitars while the up position is perfect for snares. . COMPRESSOR 1 The first compressor is an optical circuit that is quick in attack and release response. While not as fast as a typical VCA or FET design, this is about as fast as an optical circuit can go, and when pushed hard, can begin to behave in somewhat unpredictable and interesting ways. . COMPRESSOR 2 The second compressor is closest to the traditional optical sound that is embodied by the word “smooth”. This circuit just plain works on almost any source, retaining a full, rich tone, even when pushed very hard. . COMPRESSOR 3 The third compressor is something completely different and unexpected. Whereas most compressors attempt to make a signal clean and smooth, this compressor attempts to destroy a signal as much as possible! As this compressor is pushed, it responds by adding a significant amount of unique distortion/fuzz as well as near brickwall limiting. When smashing a signal to the max, it actually provides a somewhat disorienting result that simply needs to be heard in order to fully understand. What this compressor does in moderate settings to sources like a snare drum is downright stunning! . MIXED SETTINGS If it were not enough to have three unique and amazing compressors in one unit, there is still another option that allows for even more creativity - All compressors are able to be used at the same time! This not only provides for an infinite amount of different combinations of compression, but as you turn up and down the different controls, each compressor’s response curves change as they all draw off of the same triggering circuit. What that means is turning up the threshold of one compressor affects all the others...even when they are not engaged! The possibilities are absolutely endless, making this unit one of the most interesting compressors on the market today.
Post by kcatthedog on Jun 15, 2016 9:56:26 GMT -6
lovely sound !
Post by tasteliketape on Jun 15, 2016 10:01:11 GMT -6
I think Blackbird has a pre thought I read that on the Hendyamps site maybe you could rent it first
Post by Johnkenn on Jun 15, 2016 10:05:17 GMT -6
I think this is the guy from Hendersonville that I've heard about...Bukovac was talking about him a couple of years ago...but I had no idea he was making pro audio gear.
Post by tasteliketape on Jun 15, 2016 10:19:43 GMT -6
There in Houston Tx unless they moved
Post by Johnkenn on Jun 15, 2016 10:25:42 GMT -6
Ah...ok...then scratch that.
Post by Johnkenn on Jun 15, 2016 10:26:07 GMT -6
Maybe I'm thinking of Little Walter...
Post by Jason on Jun 15, 2016 21:36:17 GMT -6
His name's Chris; he's in the Houston area. He's a stand-up guy, and his gear is sublime!
Post by joey808 on Jun 15, 2016 22:52:40 GMT -6
I own the Michael Angelo Eq, it's incredible!
Post by rowmat on Jun 15, 2016 23:45:52 GMT -6
I own the Michael Angelo Eq, it's incredible! Looks good except for the voltage selector switch which looks far too accessible IMO.
Post by Randge on Jun 16, 2016 1:24:03 GMT -6
Maybe I'm thinking of Little Walter... Little Walter Tube Amps are close to the ocean in North Carolina.
Post by Johnkenn on Jun 16, 2016 11:10:39 GMT -6
Maybe I'm thinking of Little Walter... Little Walter Tube Amps are close to the ocean in North Carolina. Really? I thought LW was here? Holy shit...I'm completely out of the loop
Post by Ward on Jun 16, 2016 16:05:16 GMT -6
Shhh... when you talk about things like this, they go up in price.
Post by kcatthedog on Jun 16, 2016 16:18:08 GMT -6
and us el cheapo canadians don't want to afford the regular price after listening to that first video I would have bought one of those pres on the spot if I had the money in the bank
Post by joey808 on Jun 19, 2016 10:12:22 GMT -6
Post by Hendyamps on Sept 6, 2016 14:10:47 GMT -6
Hey everyone, I just stumbled across these forums and saw this page...thought I would stop by and say hi. My name is Chris and I live/design/build/record/mix/master/obsess/exist in a permanent psychosis right outside of houston texas. In answer to some of the questions above, and general unasked questions you might want the answer to: - Yes, last I heard Blackbird had a Rembrandt for rent (it has been there for several years). I assume they keep up with swapping the tubes when they start degrading in sound (heat kills) but I do not know that for certain...maybe load your own if you check it out...=) - I started out building guitar amps but soon moved into the studio gear as I was chasing the tone in my head and that is where it took me. I know, I probably need medical attention. - I have always been a more "custom" builder for I enjoy catering to customers, even if it is simply a different color faceplate or knob choice. I like people and helping them reach their goals/dreams is something I enjoy. - Because of me being a more custom guy, chassis, designs, etc., are a little more fluid than normal companies. So for instance, that Rembrandt and Van Gogh in those videos, they look a bit different now (aesthetics), but the circuits are still the same unless there is a sonic improvement tweak I believe belongs there. The Michelangelo EQ has grown substantially over the last year and a half (pic on my website is way out of date!) as a result of all the helpful feedback from customers and friends (no worries on that switch on the back...it is actually a proper recessed mains switch). I'm sure I forgot to say something else, but oh well....long winded enough as it is. Sorry for the intrusion - I'll butt out of the conversation now. If you have any questions though I will be happy to answer them. Chris
Post by Johnkenn on Sept 7, 2016 6:30:26 GMT -6
Thanks for stopping by, Hendyamps! Definitely want to check these out.
Post by 79sg on Sept 7, 2016 6:35:38 GMT -6
My Hendyamps Michelangelo (EQ) should ship out to me this week. Chris is a great guy and an absolute pleasure to work with.
Post by nomatic on Sept 7, 2016 6:51:01 GMT -6
The Michelangelo is always in my Mastering chain and The 4 channel Rembrandt is my favorite pre of all time in the Tube world..... Chris's stuff is the shit!
Post by 79sg on Sept 7, 2016 6:59:15 GMT -6
Rembrandt is next on my list.
Post by Johnkenn on Dec 28, 2016 21:26:36 GMT -6
The Michelangelo is always in my Mastering chain and The 4 channel Rembrandt is my favorite pre of all time in the Tube world..... Chris's stuff is the shit! There's a four channel Rembrandt?
Post by indiehouse on Dec 28, 2016 23:03:48 GMT -6
I've recently added a Michelangelo to my rack and let me tell you, it is THE shit. No joke.
Post by 79sg on Dec 29, 2016 9:13:51 GMT -6
Received the Michelangelo back in September and it is THE shit as indiehouse stated above.
Trying to decide on the Rembrandt or one of Chris's channel strips. Originally I thought I'd use the Michelangelo with the Rembrandt but quite frankly it is locked into our mastering chain so a channel strip is probably the way to go.
Post by Johnkenn on Dec 29, 2016 10:35:12 GMT -6
Damnit
