Post by peterc on Jun 3, 2016 2:32:04 GMT -6
Hi all Hope this is OK to post here. I am doing a limited run of PCbs for some of my projects. If you are interested, please have a look here: groupdiy.com/index.php?topic=62900.0 Gren Mic Pre S800 EQ Green PSU 5003 EQ Nite EQ The listing will only be available for a month. Regards, Peter
Post by jcoutu1 on Jun 3, 2016 4:54:06 GMT -6
Hi all Hope this is OK to post here. I am doing a limited run of PCbs for some of my projects. If you are interested, please have a look here: groupdiy.com/index.php?topic=62900.0 Gren Mic Pre S800 EQ Green PSU 5003 EQ Nite EQ The listing will only be available for a month. Regards, Peter What are these based on? Do you have BOM's for the builds? Any idea of all in cost for the Nite EQ?
Post by svart on Jun 3, 2016 7:34:11 GMT -6
Hi all Hope this is OK to post here. I am doing a limited run of PCbs for some of my projects. If you are interested, please have a look here: groupdiy.com/index.php?topic=62900.0 Gren Mic Pre S800 EQ Green PSU 5003 EQ Nite EQ The listing will only be available for a month. Regards, Peter What are these based on? Do you have BOM's for the builds? Any idea of all in cost for the Nite EQ? Green pre is an Amek preamp S800 is trident EQ 5003 EQ is an API 553 type EQ Nite EQ is Nitepro clone
Post by svart on Jun 3, 2016 7:46:17 GMT -6
The big question is, any metalwork available for the 500 series PCBs? For most folks, that would be the hardest part of the build, to adapt the PCB to fit correctly.
Post by rocinante on Jun 3, 2016 11:48:05 GMT -6
The first 3 are classics. The Nite is a bit tricky and requires aml pots and some serious bias and adjustments. That said Im into the 5003 if its in 500 format.
Post by kilroyrock on Jun 3, 2016 12:07:59 GMT -6
That was always my question for people who buy pcb and not kits.. do you guys have metal brakes and form and cut your own cases as well, or what? Buying a case is half a build cost from what I've found
Post by rocinante on Jun 3, 2016 12:11:15 GMT -6
Yeah cases aren't cheap. I have a few means. Collective cases has awesome cases; the best imo. Par metal. For me its where there is a will theres a way. It depends on how nice you want it. If your building an aml ez1073 for instance id get the best.
Post by jcoutu1 on Jun 3, 2016 12:12:34 GMT -6
Post by kilroyrock on Jun 3, 2016 12:37:20 GMT -6
I'm gonna start a separate thread about building cases and sourcing metal in the states. Let me know if you have a BOM or is the pcb labeled clearly? (bom would still be nice)
Post by jcoutu1 on Jun 3, 2016 12:41:24 GMT -6
dandeurloo mentioned before that he could do Nite cases for $150/each if there were 10 orders. I assume he could do other cases too. I'm looking at this Nite eq thread on GDIY and the damn thing is 55 pages. I just want the basic info on these things... BOM Schematic Power Supply Info Case / front panel layout / vendor Total cost.
Post by NoFilterChuck on Jun 3, 2016 12:48:06 GMT -6
I'm looking at this Nite eq thread on GDIY and the damn thing is 55 pages. lol that's part of the charm of GroupDIY projects. Having to sift through a bazillion thread pages to figure out how to build the dang thing!
Post by jcoutu1 on Jun 3, 2016 12:50:46 GMT -6
I'm looking at this Nite eq thread on GDIY and the damn thing is 55 pages. lol that's part of the charm of GroupDIY projects. Having to sift through a bazillion thread pages to figure out how to build the dang thing! What a pita. Why not just include all the important info in the top post or something. I'd love to order the S800 and Nite boards while they're available, but have no idea how much money I'd have to invest or even if I have the ability to get them done.
Post by rocinante on Jun 3, 2016 13:19:04 GMT -6
Okay the nite is hard. Minus the pots everything is easy to get at mouser. Adjusting the frequencies is a different matter. Unfortunately there was a slight design slip up but can be adjusted. S800 has a good amount of support and cases are easy. I actually have the front panel file for fpd for whoever needs it. The green pre has a bagillion threads and is highly documented. Everything can be run on an antec or lindberg toroidal thats got 15v secondaries. Psu's can be had from five fish (you can also get a 15v toroidal bundled for about $75 together.For the eq's you vould use mnats (via hairball) for way cheaper and with a toroidal from mouser maybe $35 including components to stuff it. Damn im practically doing the bom for you. Jeff probably has a bunch of any hard to get parts for the 5003.
Post by jcoutu1 on Jun 3, 2016 13:27:00 GMT -6
Okay the nite is hard. Minus the pots everything is easy to get at mouser. Adjusting the frequencies is a different matter. Unfortunately there was a slight design slip up but can be adjusted. S800 has a good amount of support and cases are easy. I actually have the front panel file for fpd for whoever needs it. The green pre has a bagillion threads and is highly documented. Everything can be run on an antec or lindberg toroidal thats got 15v secondaries. Psu's can be had from five fish (you can also get a 15v toroidal bundled for about $75 together.For the eq's you vould use mnats (via hairball) for way cheaper and with a toroidal from mouser maybe $35 including components to stuff it. Damn im practically doing the bom for you. Jeff probably has a bunch of any hard to get parts for the 5003. If the Nite is hard, I should avoid that one. The S800 has that parts kit with AML, so that should help. Beyond that, it seems to be power supply, and generic stuff like jacks that I'd still need I guess. This guy slapped his into a pretty rad case with nice chicken knobs and it looks great. diyproaudio.blogspot.com/2013/07/s800-eq-complete-info-to-come-little.htmlThe other option would be to try to fit 4 units into a 2 rack space. Wouldn't look as rad as this, but would have a bit more utility and wouldn't add a ton to the cost if you could get it all into a single case off one power supply.
Post by rocinante on Jun 3, 2016 20:37:02 GMT -6
That's great diy. I spend a bit on looks. I like fancy knobs. I like push buttons. I like white engraving. Most of all I like it to look professional. Lucky for me I like the igs shadow hills look. Easier to diy. Remember just because it's DIY doesn't mean it's cheap. More than often it actually cost more than the factory made, its just spread out over a longer period of time. Its important to like doing DIY if you're gonna diy. The problems are riddles. Not faults.
Post by rocinante on Jun 3, 2016 22:45:03 GMT -6
So who's down? I think im into a 5003 and maybe 8000.
Also for those interested i have trident and nite eq frontpanel designs.
Also I wanted to say that the nite EQ is super special and anyone that has used it (factory made or this diy version) and so has gotten it to work correctly raves about it. Maag missed the mark ive heard. I know several mastering studios that use the night EQ a lot and love it and swear they could not operate without one. I think dagoose uses one. Stepped pots would make it something else. Its got that air band.
Post by jcoutu1 on Jun 4, 2016 8:06:47 GMT -6
I think I'm going to order boards for 4 channels of S800 and 2 channels of Nite. Even if I can't do the Nite now, I'll at least have boards to give it a go at some point.
I'm curious if the green power can power the s800 or nite.
Post by jcoutu1 on Jun 4, 2016 19:34:40 GMT -6
rocinante, Peter says that The Green PSU will power the S800 or Nites. At least 4 channels of each. Do you think that's my best bet or should I try to figure something else out. I'm a total beginner (other than some basic soldering of kits, Colours and guitar pedals).
Post by rocinante on Jun 5, 2016 8:19:15 GMT -6
The green psu is great. Its a simple hardy design and ive used it in two of my builds. I would definitely reconsider the nite. Just spend two hours on the thread from page 30 to the end. I think you'll then see why.
Post by jcoutu1 on Jun 5, 2016 8:40:37 GMT -6
The green psu is great. Its a simple hardy design and ive used it in two of my builds. I would definitely reconsider the nite. Just spend two hours on the thread from page 30 to the end. I think you'll then see why. I want it to go with this bad boy though! imgur.com/SnknOi4Is it just poorly designed or something? I guess I've got some reading to do.
Post by rocinante on Jun 5, 2016 9:47:42 GMT -6
Yeah there were design mistakes. The repair is replaving resistors eith trimmers and tuning them to get the correct freq then either replace the trimmers with the correct odd resistors or leave them in. The potentiometers for it aint cheap either. A lot of people settled but mind you the plots were off and one wouldn't be boosting or cutting the frequency they thought they were. If the wanted to do it by ear thst would be fine but one could just ignore any front panel because it hardly lined up with what was really happening. Others took the time to do it right and narrowed it down. It took months. It is so vitally important for me to say that this was a really really hard design to go implement and I don't want anyone to think that the pcbs were bad. They were fine; it's just that it needed far more than the average diyer could do. I have the upmost respect for the designers and think those guys are geniuses. This particular pcb just kind of fell to the wayside and unless one is super patient and has a good understanding of eq plots id leave it alone.
Post by jcoutu1 on Jun 5, 2016 11:18:46 GMT -6
Alright, I'm convinced. I emailed Peter. I'm gonna do 4x S800 and 2x Green PSU. Not sure if I'll do 4 channels in a single case or 2 cases, but we can cross that bridge WAY down the line.
I'm excited. It seems like a good beginner project for a fair price.
Thinking out loud a bit, these eq's are transformerless right? What would it take to add some iron on the output or something? 1:1 can kind of be slapped anywhere right? Would a 1:1 add much in terms of tone?
Also, could I build this green psu in an external case and run power to 2 different units from the single supply? A la Daking.
Post by rocinante on Jun 5, 2016 11:28:04 GMT -6
You wont need to build the psu's in a separate case which is good. Remember a well laid out design is crucial and in the trident and green you have both. I think the motto: "fake it till you make it" applies here. Copy those before you. Keep the psu in the back near the toroidal and away from the filters and you'll be fine. If you end up doing a rack of tridents (like 6 and up) then id consider it. 1u with 1 psu is pretty standard and might want to be done first.
Post by kilroyrock on Jun 6, 2016 7:00:58 GMT -6
The problems are riddles. Not faults. I'm pretty sure that's gonna be my new motto in life. Kudos to you.
Post by jcoutu1 on Jun 6, 2016 9:03:05 GMT -6
