Post by alexmc1988 on Apr 10, 2016 10:22:42 GMT -6
Does anyone know how to do the output mod adding a pot to the output for matched stereo use? I might be able to get a pair used for a good price but sending them to zenproaudio would greatly reduce the good deal.
Thanks!
Post by winetree on Apr 10, 2016 21:17:44 GMT -6
I'd like to put output knobs on my pair also. No puns needed.
Post by jeromemason on Apr 10, 2016 22:51:24 GMT -6
A 100k log pot wired like this should do the trick. Just wire pin 1 to ground and the +/- to 2 and 3.
Post by EmRR on Apr 11, 2016 6:09:50 GMT -6
They don't have an internal trim for that? Are they that loose in gain tolerance? This is supposed to be a unity gain device.
Post by alexmc1988 on Apr 11, 2016 6:16:18 GMT -6
Thanks jeromemason!
It seems like most are within 1 DB but I have heard of there being as much as a 6db difference. I'd really like to use them on mix buss so they need to be pretty darn close.
Post by jcoutu1 on Apr 11, 2016 8:13:50 GMT -6
Thanks jeromemason! It seems like most are within 1 DB but I have heard of there being as much as a 6db difference. I'd really like to use them on mix buss so they need to be pretty darn close. Were you the one that put an offer in on Reverb? If not, there is a used pair there.
Post by EmRR on Apr 11, 2016 8:48:37 GMT -6
A 6dB difference is most likely a connection problem. Theres no tube circuit on eath that would have a 6dB variance.
Post by ragan on Apr 11, 2016 9:37:40 GMT -6
This has been discussed at length on the GS thread, with Bryce chiming in too. You can just get a matched pair of tubes and your gains will match (or so it's been said). Also people chiming in that their original Pultecs also varied a lot in output and the mixbus duties were always a bit of a trick because of it.
Just getting a factory matched set of tubes seems like by far the easiest way to go.
I didn't even do that, I just went through some tubes until I found two that were close and I print mixes through them all the time. They sound amazing on the 2 bus.
