Post by Johnkenn on Mar 8, 2016 15:14:37 GMT -6
I'm starting to get them on a regular basis. VERY ANNOYING. Didn't have this issue on 12.3. Just having to freeze tracks. Can't imagine getting it on a 24 track session - even maxed...i7/16gb RAM
Just wondering if it was a thing.
Omnisphere and 12.4 are the only two new things I've installed...don't know how it could be omnisphere if it's not even in the session.
Post by Johnkenn on Mar 8, 2016 15:40:30 GMT -6
Well...God bless Trashing Prefs...seems to have improved it dramatically. Why am I still having to Trash Prefs in PT12??
Post by mulmany on Mar 9, 2016 11:11:07 GMT -6
Do you have dynamic plugin processing turned on? Having that on solved alot of odd pt cpu load issues for my machine.
Post by Johnkenn on Mar 9, 2016 14:22:34 GMT -6
Yes - getting it with DPP on...and now I've loaded 5GB of memory in disk cache. Still doing occasionally. Wondering if my 4TB USB drive is starting to get flaky
Post by tasteliketape on Mar 9, 2016 14:39:32 GMT -6
I had same set up Mac mini i7 an a old external hard drive case FireWire/usb it was old I bought a new usb3 case put same hard drive in it all my problems stopped. I guess what I'm saying is my external drive case was causing all kinds of errors
Post by Johnkenn on Mar 9, 2016 14:44:02 GMT -6
It's a USB 3 drive with moving parts in it...so I thought I could defrag...but it won't let me. I might go buy a second and spread out the duties.
Post by ericn on Mar 9, 2016 22:26:25 GMT -6
It's a USB 3 drive with moving parts in it...so I thought I could defrag...but it won't let me. I might go buy a second and spread out the duties. If your going to buy a new external, buy a SSD as a work drive and keep the spinner as an archive! I am amazed how many systems are less taxed with an SSD doing all the heavy read/write/ read/ write lifting.
Post by Johnkenn on Mar 11, 2016 15:32:22 GMT -6
I have to say - I'm DONE with PT's. This is just ridiculous. I don't have any problems in other DAWs. Only PTs.
Post by Johnkenn on Mar 11, 2016 16:00:08 GMT -6
I should say "major" problems.
