Post by Jason on Mar 3, 2016 10:30:35 GMT -6
what's wrong with fall out boy? ;-D
Post by ragan on Mar 3, 2016 11:07:46 GMT -6
Hey Ragan follow up trigger question, I notice the Deluxe pack has the newer unprocessed samples. Were you running trigger platinum or Deluxe ? "The Deluxe set adds 16 Snares, 14 kicks, and 19 toms to your Trigger Drum Library. And these new drums are unprocessed, but recorded with such amazing detail that they will sit in the mix effortlessly. If you want to customize the drum samples, they respond beautifully to eq, compression, and other effects. thx ! I have both (I believe, I'll double check). I just don't believe the ad copy. They still sound overcooked. The Blackbird pack is the only Slate stuff that sounds good and real to me. It's much better than the others (to me).
Post by Ward on Mar 3, 2016 16:24:02 GMT -6
what's wrong with fall out boy? ;-D Didn't they have a falling out?
Post by swurveman on Mar 4, 2016 14:19:51 GMT -6
Thank you noah. I'm spending a month in Venice in a place right off of Rose. It's good to be back in LA.
Post by Deleted on Mar 4, 2016 18:17:37 GMT -6
I usually make my own but these two are nice: roomsound.org and iwantthatsound.comI have no idea any of you use Trigger, it's always out of time when I use it so I replace by hand using single shot stuff.
Post by Deleted on Mar 4, 2016 18:19:37 GMT -6
what's wrong with fall out boy? ;-D pre 2007 nothing post 2007 damn near everything.
Post by sopwith on Mar 4, 2016 23:41:55 GMT -6
I don't need anything other than the ~35 multisampled kits included with Ableton Live suite - I think they're all by Chocolate Audio (who also do Kontact and BFD kits). With GrooveMonkee midi clips playing through those and careful control of velocities, it sounds very, very awesome.
Tell you my secret. Every drum in these packs has between 16-30 velocity layers. I put Max4Live midi velocity control devices on some of the individual drums, and on the kit as a whole. Then I midi map those velocity devices to my control surface. That way I can control how hard the individual drums (and the whole kit) are being hit right from the mixer in real time. Sounds about 10000 times more lifelike than just changing the volume of the samples, and it's way easier than drawing velocity curves into the piano roll.
Post by sopwith on Mar 5, 2016 0:01:37 GMT -6
Post by sopwith on Mar 5, 2016 0:07:26 GMT -6
Post by noah shain on Mar 5, 2016 2:09:27 GMT -6
Thank you noah. I'm spending a month in Venice in a place right off of Rose. It's good to be back in LA. If you find yourself in DTLA drop in!! I'll get that other folder up Monday
Post by tonycamphd on Mar 5, 2016 9:43:20 GMT -6
Thank you noah. I'm spending a month in Venice in a place right off of Rose. It's good to be back in LA. If you find yourself in DTLA drop in!! I'll get that other folder up Monday Noah, where about are you in DTLA? i used to work at Hollywood locations(set stuff) that took over the LA Herald building, also LA center studio's on the north side of the 101(damn i cant remember the street! been 15 years!... i'm old), anyway, it'd be cool to drop by and see you one of these times when i'm up there, i'm going to be going to Steve Vai's studio again here pretty quick, my pal's tracking a record there(not vai's anymore, he sold it) here's the jail set we built, can't believe i just found a pic of it! blast from the past, those bars are actually white PVC, and 1x furring, the artist who come in and paint are amazing! Attachment Deleted
Post by swurveman on Mar 6, 2016 16:56:46 GMT -6
Thank you noah. I'm spending a month in Venice in a place right off of Rose. It's good to be back in LA. If you find yourself in DTLA drop in!! I'll get that other folder up Monday Will do. Thanks! Home away from home in Venice.
Post by Golgoth on Mar 8, 2016 10:50:47 GMT -6
Thanks a million times for the pack Noah! Best snare pack ever IMO. I think I'll always find something useful in any situation in this one. Need more hats now
Post by Johnkenn on Mar 9, 2016 14:58:30 GMT -6
Post by noah shain on Mar 9, 2016 23:38:06 GMT -6
Here's some more stuff y'all: www.hightail.com/download/ZWJVSU5KMHdiR0pwdmNUQwI tried to upload 9 gigs today. Hahaha. Hightail only lets me do 2 gigs at a time. I can keep it coming if it's useful stuff to you guys. It was all given to me...this stuff flows around LA like water. I don't want to offend anybody or hurt anyone's business by giving away what should be paid for. If I'm crossing an ethical line here just let me know and I can pull em down.
Post by tasteliketape on Mar 9, 2016 23:50:08 GMT -6
Noah you the man THANKS O
Post by lordnielson on Mar 10, 2016 6:55:48 GMT -6
I usually make my own but these two are nice: roomsound.org and iwantthatsound.comI have no idea any of you use Trigger, it's always out of time when I use it so I replace by hand using single shot stuff. Iwantthatsound.com gets a ditto from me.
