Post by saxmonster on Feb 18, 2016 21:04:29 GMT -6
Just wondering how you guys are doing it. Since Dp doesn't have automatic compensation for outboard gear like PT how are you guys using your outboard equipment? I have to set my buffers low and "Direct hardware patch thru" and listen to say a drum buss coming out and running through my sb4001 finding a setting I want then rerecording it back into DP and then adjusting it back however many samples I figured out and have written down. Actually I set Dp to move it back automatically kinda of set it and forget it. But I was wondering if there is a way to use the outboard gear as your are mixing and then rerecord all the outboard gear at the end. So say as I am mixing I am running a drum buss through the 4001 and bass thru my la2a and a guitar through my la3a and then at the end rerecord everything and then bounce everything down. How do you do this live so to say as I am mixing? I am using "Direct hardware patch thru" but still notice a delay.
