Post by drsax on Jan 25, 2016 13:43:49 GMT -6
Hey guys, I'm looking at a Lynx Hilo Thunderbolt to add to my current setup and had a question for those of you that have these. Is it possible to utilize the seperate DA's in standalone mode from seperate digital inputs? For example, to have the SPDIF input routed to the XLR main outs while having the AES input routed to the TRS monitor outs? Trying to see if this unit is gonna fit into the workflow of my studio and haven't been able to find this answer. Thanks for any help or advice!
Post by Johnkenn on Jan 25, 2016 18:50:15 GMT -6
I had one for a little while...and I think so...but you might wanna try downloading the manual onlineĀ
Post by drsax on Jan 25, 2016 21:15:32 GMT -6
I had one for a little while...and I think so...but you might wanna try downloading the manual onlineĀ Thanks man. The manual isn't quite clear but I reached a Hilo user that says it can do this in standalone mode. Think of using it alongside my Svartbox for the inserts on my master buss.
Post by drsax on Jan 26, 2016 13:07:02 GMT -6
Update: I found out it is not possible to route more than one digital input (AES, SPDIF coax, SPDIF optical) to the outputs, but... There is one exception - You can use one of the AES or SPDIF coaxial inputs PLUS the ADAT optical inputs. The ADAT input is separate. Since I happen to have an RME ADI-8dd format converter, I can convert the AES to ADAT and should be able to achieve the needed result that way. I'll find out in a couple weeks when I get my Hilo. According to Lynx it will work. I've got my fingers crossed
