Post by Johnkenn on Jan 20, 2016 11:03:11 GMT -6
(Requires Crane to lift into studio)
spl.info/en/products/processing/iron/overview.html
spl.info/fileadmin/user_upload/produkte-w/Iron/IRON_1_front_web.jpg
The IRON mastering compressor is not a copy of a classic unit, but rather an original concept in itself. Our goal was to conceive a compressor that provided a pleasant, melodic-sounding, transparent compression, inspired on the vintage compressors of the radio era. And we wanted it to be versatile enough to adapt perfectly to the needs of modern mastering studios.
Thus, the IRON combines not only the sonic virtues of legendary vintage tube compressors with the advantages of the High Dynamic 120 V operating voltage in a single unit. It also sets a new benchmark in terms of tube compressor technology, with the innovative implementation of a parallel dual-tube circuit.
Variable bias tube compressor
Parallel dual tube circuit
Tube selection and pairing with Weigl Roe Test
Specially conceived Mu-Metal iron transformers
Feed-forward resistive vactrol-opto-isolator
Six different Rectifier settings available
Sidechain that allows you to choose between Off, four sidechain-filter presets or an external sidechain signal.
All functions can be adjusted via switches or, in the case of the Threshold, with a detented potentiometer
In Link mode, the Threshold, Tube Bias, Attack, Release, and Rectifier parameters, as well as the Sidechain EQs, are controlled with the right side (channel 2) of the unit.
Additional passive 120V equalizer with two presets
High Dynamic 120V operating voltage
Auto Bypass mode
Made in Germany
Auto Bypass mode
Made in Germany
