EZ1084
Jan 12, 2016 18:54:27 GMT -6
via mobile
Post by indiehouse on Jan 12, 2016 18:54:27 GMT -6
Anyone have experience with this build? PCB's are pricey, over $100 a piece. He throws in some transistors with that. Over $240 for a pair of just the PCB's. Wondering if these are worth it?
EZ1084
Jan 12, 2016 19:40:10 GMT -6
Post by tonycamphd on Jan 12, 2016 19:40:10 GMT -6
Anyone have experience with this build? PCB's are pricey, over $100 a piece. He throws in some transistors with that. Over $240 for a pair of just the PCB's. Wondering if these are worth it? If you're talking about the bluzzi ez? they are worth it no doubt, ask dandeurloo
EZ1084
Jan 12, 2016 20:05:46 GMT -6
Post by cademan7 on Jan 12, 2016 20:05:46 GMT -6
I have a pair. They are great! and Jim (Bluzzi) is a great help no doubt. I love mine
EZ1084
Jan 12, 2016 21:45:29 GMT -6
via mobile
Post by rocinante on Jan 12, 2016 21:45:29 GMT -6
This is probably my favorite eq. And I have many. It is everything you like about neve. Warm, silky, and can do beautiful things to guitars and vox and everything. Someday I want to build 8. I use it a lot. Oh and Bluzzi is as good as they get. Dan Deurloo also has really nice front panel for it that he color matched to his own neve consoles royal gray. Super pro build.
EZ1084
Jan 13, 2016 6:00:01 GMT -6
via mobile
Post by indiehouse on Jan 13, 2016 6:00:01 GMT -6
Aright then. I'm in for a pair!
EZ1084
Jan 13, 2016 7:17:45 GMT -6
Post by kcatthedog on Jan 13, 2016 7:17:45 GMT -6
EZ1084
Jan 13, 2016 7:19:10 GMT -6
Post by kcatthedog on Jan 13, 2016 7:19:10 GMT -6
Post by rocinante on Jan 13, 2016 9:29:14 GMT -6
Everything you need is at gdiy. The bom is actually uploadable to digikey so he's made everything a breeze. The most expensive part is the aml order.
EZ1084
Jan 13, 2016 19:31:20 GMT -6
Post by porkyman on Jan 13, 2016 19:31:20 GMT -6
the ez1073 is the easiest build ive ever done. i dont know if the 1084 is the same as far as coloring book and everything, but if it is its probably even easier.
Post by dandeurloo on Jan 13, 2016 21:55:58 GMT -6
The EZ1084 eq sounds great. It is also a really easy build. I use this eq 99% more often then the ez1073 eq. I pretty much only use the 1073 eq when using the pre.
EZ1084
Jan 20, 2016 0:59:21 GMT -6
Post by rob61 on Jan 20, 2016 0:59:21 GMT -6
Just ordered a pair. Should be cool when the 1290LE add on preamp is available too. I like the eq's in my ez1073, so these should be a nice addition.
Post by rob61 on Feb 7, 2016 11:49:15 GMT -6
Just finished my pair. They sound great. Bluzzi was first class with support during the build, and Dan and his Collective Cases makes for a great looking build as well. Highly recommended. Attachments:
EZ1084
Feb 7, 2016 12:03:08 GMT -6
Post by tonycamphd on Feb 7, 2016 12:03:08 GMT -6
Just finished my pair. They sound great. Bluzzi was first class with support during the build, and Dan and his Collective Cases makes for a great looking build as well. Highly recommended. wow, you embarrass me with your speed! nice external PSU, those look great man, congrats! can we see pics inside? especially the PSU!
EZ1084
Feb 7, 2016 12:11:04 GMT -6
Post by rob61 on Feb 7, 2016 12:11:04 GMT -6
Well, they're already in my rack and in use! Internal shots now would be a lot of work! The power supply case came from Dan at Collective Cases, as well as the 1084 cases. I used the Five Fish Audio 2448Plus power supply. Very quiet and an easy build with good docs. Got the power cable from Jeff at CAPI. Pretty straight forward. Bluzzi (Jim) was always quick and very helpful in answering questions during the build.
EZ1084
Feb 7, 2016 12:46:03 GMT -6
via mobile
Post by noah shain on Feb 7, 2016 12:46:03 GMT -6
Well, they're already in my rack and in use! Internal shots now would be a lot of work! The power supply case came from Dan at Collective Cases, as well as the 1084 cases. I used the Five Fish Audio 2448Plus power supply. Very quiet and an easy build with good docs. Got the power cable from Jeff at CAPI. Pretty straight forward. Bluzzi (Jim) was always quick and very helpful in answering questions during the build. Damned fine work. Very sexy. Curious what total cost is?
Post by rob61 on Feb 7, 2016 15:22:32 GMT -6
$1800 for the pair.
