Post by Johnkenn on Jan 6, 2016 14:54:36 GMT -6
Oh - I had the B2
Post by carymiller on Jan 6, 2016 14:58:04 GMT -6
I'm going to say go Avid 16x16 buy a 2 ch Burl and or Mytek for flavor. If later you go summing And want Larger Burl and or Mytek do it then, you will have decided which you want to build a system and you can sell the AVid. Heya Jan, This might wind up being the configuration: A Mytek 8x192, the AVID 16x16....and both the Bomber ADC and DAC. The Mytek will be a bit more clean/neutral than the AVID, though the AVID will be fantastic for tracking. So the Mytek would be more for transfers, additional inserts, and headphone mixes. I would probably monitor off the Bomber DAC to help reduce ear fatigue, and the ADC to do most over dubs/vocals/bass/and guitars. Drums would wind up being cut with the AVID The Mytek would also give me an extra port for DSD conversion...so there's potential added flexibility there. The other thing I'm considering at this time is a Burl Mothership with 8 or 16 I/O to start...which I would upgrade later, and either the 16x16 or Omni. This opens things up to expansion I wouldn't have otherwise. I think...as of this morning I've ruled the IZ out.
Post by ericn on Jan 6, 2016 16:18:22 GMT -6
I'm going to say go Avid 16x16 buy a 2 ch Burl and or Mytek for flavor. If later you go summing And want Larger Burl and or Mytek do it then, you will have decided which you want to build a system and you can sell the AVid. Heya Jan, This might wind up being the configuration: A Mytek 8x192, the AVID 16x16....and both the Bomber ADC and DAC. The Mytek will be a bit more clean/neutral than the AVID, though the AVID will be fantastic for tracking. So the Mytek would be more for transfers, additional inserts, and headphone mixes. I would probably monitor off the Bomber DAC to help reduce ear fatigue, and the ADC to do most over dubs/vocals/bass/and guitars. Drums would wind up being cut with the AVID The Mytek would also give me an extra port for DSD conversion...so there's potential added flexibility there. The other thing I'm considering at this time is a Burl Mothership with 8 or 16 I/O to start...which I would upgrade later, and either the 16x16 or Omni. This opens things up to expansion I wouldn't have otherwise. I think...as of this morning I've ruled the IZ out. The advantage of the 16x16 if Avid ever wants to screw other Manufacturers by Fucking with the Digilink protocol is it will still work! Check with Avid to see if you can convert a standard 16x16 to all digital I repeat Avid not dealers!
Post by carymiller on Jan 6, 2016 17:16:50 GMT -6
Did the B2 generate alot of heat? Just wondering if spacing is truly important. I would think with those transformers...at least with the mothership, this would be an issue to consider.
Post by Johnkenn on Jan 6, 2016 19:09:23 GMT -6
Not any more than normal.
Post by Johnkenn on Jan 6, 2016 19:10:07 GMT -6
I'm going to say go Avid 16x16 buy a 2 ch Burl and or Mytek for flavor. If later you go summing And want Larger Burl and or Mytek do it then, you will have decided which you want to build a system and you can sell the AVid. Heya Jan, This might wind up being the configuration: A Mytek 8x192, the AVID 16x16....and both the Bomber ADC and DAC. The Mytek will be a bit more clean/neutral than the AVID, though the AVID will be fantastic for tracking. So the Mytek would be more for transfers, additional inserts, and headphone mixes. I would probably monitor off the Bomber DAC to help reduce ear fatigue, and the ADC to do most over dubs/vocals/bass/and guitars. Drums would wind up being cut with the AVID The Mytek would also give me an extra port for DSD conversion...so there's potential added flexibility there. The other thing I'm considering at this time is a Burl Mothership with 8 or 16 I/O to start...which I would upgrade later, and either the 16x16 or Omni. This opens things up to expansion I wouldn't have otherwise. I think...as of this morning I've ruled the IZ out. I think that's a really good solution. Best of all worlds.
Post by kcatthedog on Jan 7, 2016 11:40:37 GMT -6
You don't mention Prism but I just got an email indicating they are giving away a PT HDX card with some new interfaces.
Post by Pueblo Audio on Jan 7, 2016 16:43:05 GMT -6
With that budget I would recommend....
3x JCF-Audio AD8 (24ch) for multitracking 1x Lavry AD122-96 mk3 for 2buss capturing/mastering
And if I might dare, Compliment the AD8's with some Pueblos and you will find the recording process so much more effortless and joyfull.
Post by joey808 on Jan 7, 2016 22:53:38 GMT -6
I agree with John, the top end on the b2 sounded too bright, I ended selling mine as well.
Post by gregwurth on Jan 29, 2016 13:58:10 GMT -6
Hey guys, I'm building a new home studio, which is where I'll work while I save towards a house over the next few years. I am leaning towards upgrading to Pro Tools HD Native, for ease of use with professional work (*I have a new job lined up, and I'll be working pretty steady for the next three years for a corporate client.) It took me a long time to get the stars to align for this, and times were lean most of the previous year. To my surprise, I have money in hand to build things out concerning gear, and a decent amount of room treatment that can be transferred to a house when the time comes. I can't build a studio proper until then, so any tracking will be overdubs in the control room, however...my budget is higher than expected (not limitless or anything, but way more flexible than I thought it would be.) I just want to talk DAW and converter combinations. But for this setup I'm not interested in Apogee products since I'm on a PC platform, and I'm going to rule out things like the Lynx Aurora, MOTU, RME, and Antelope converters. I've tried many, if not most of these products out over the years, and I'm going to go with the pros and cons of things I've tried which managed to impress me. I'd like to have enough conversion for at least a 16 track studio which can handle mixing and mastering, headphone mixes, and some analog inserts, etc. So my questions are going to more in nuanced realms of technical details, rather than simply "what sounds better".01. AVID 16x16/Omni: I've only heard the 16x16 out of these two, but it was great sounding. Clean, but with a bottom end that felt defined and tight. I have not gotten to test it out as a mastering AD/DA however, and I'm not sure how it's internal clcok stands up. 02. BURL Mothership: The Mothership really blew me away when I heard it, though I've been told that clocking it to something external (IE: Antelope 10M) can improve things. It's modular however and for limited quantities of conversion not unobtainable to start, despite it's price. 03. IZ ADA: This is a great middle ground between the others on the list. Clean, but not sterile, and I've been partners in a small studio which had a Radar unit. I know what this stuff sounds like under heavy usage, however...it's an investment since it's harder to get these upgraded in a modular fashion than the Burl, and better to figure out how to max out as a 24 I/O unit to start. Though I never hear anyone talk about using external clocks with these. 04. Mytek 8x192: I love this unit. Some people feel it's too clean, but it's fantastic for mastering. I feel it has the best clock out of all of these choices, though I've never been able to do clock comparisons with the AVID stuff. Or a direct shootout with their converters in the same space (though I did use the same test material on both of them for a reference point.) 05. System Stability: Is it just better in the long run to stick with AVID products for the most part in terms of stability? CONCERNING DAWS: I'm most likely to stick with Pro Tools HD, since I've been using Pro Tools Native for my home rig since version 9, and it does help with major label client work/name recognition. However my first setup was a Cubase system (which I still own the license to), and Cubase/Nuendo aren't out of the realm of possibility. However, I'd like to grow clientele outside of my main job, and I'm not interested in expanding to Surround/Film Post work at this time (I'd much prefer music clients to give me something "fun" to do when I'm not working for a company doing audio lab work.) BUDGET/QUESTIONS:I can afford ten to fifteen grand in this direction, however...I'm trying not to overspend....so here's my questions.... 01. Has anyone used a Mytek to clock the BURL? Was this a significant step up? 02. Has anyone used a Mytek to clock either of the new AVID units? Was that a step up? 03. Has anyone tried clocking the Burl with an AVID unit? Or visa versa? Which did you prefer? O4. Has anyone managed to possibly hear all of these clocking combinations? 05. Is the new AVID clock used in the 16x16/Omni competitive to the Mytek's? NOTES:I'd like to potentially have some Burl converters paired with something clean like the Mytek or an avid unit (I've been lusting after the burl for years.) However...I'm fairly certain I can't afford anything like the 10M at this time, and I'm not certain it would be a huge step up from the Mytek internal clock to act as the master. Clocking the Burl with the Mytek is probably the most cost effective solution, however if the AVID clock can get comparable results to the Mytek...I'd rather buy a PT HD Native rig and be done with it as far as the clean converters go. I can always get a Bomber AD later...but with PT HD with 24 I/O (16x16 AND an Omni), or a 16x16 system with a Mytek to get the track count up...things start getting into IZ ADA territory. So...any thoughtful opinions on the matter would help...I'm having a new custom desk made and otherwise I seem to know what I want for once, this is kind of my last hurdle when it comes to design. Hope you guys had a great holiday. - Cary I personally use Burl products in my studios and I can say they are great and the clocking is fantastic. I wonder why you don't consider the Lynx Aurora 16 in your choices? I also use those in my studios and they are rock solid.
Post by ragan on Jan 29, 2016 14:14:11 GMT -6
I agree with John, the top end on the b2 sounded too bright, I ended selling mine as well. Really? I must have missed John's comment but that surprises me. The top end on my B2 is so smooth. It's a very round sounding converter that I've never thought of or heard referred to as "bright". Not to criticize your experience of it it just surprised me.
Post by drbill on Jan 29, 2016 14:22:51 GMT -6
#1 - the Avid 16X16's sound fantastic.
#2 - the Avid 16X16's sound fantastic.
#3 - Avid has a nasty habit of making other companies products "obsolete" with their upgrades. You've got less of a chance of that happening with the 16X16's.
#4 - you can get your 16 channels of AD/DA for $1800 shipped to your door.
#5 - you can spend the rest of your $13k + on things that will matter more to the end product.
The obvious answer - Avid 16X16....
YMMV....
Post by joey808 on Jan 29, 2016 14:46:06 GMT -6
I agree with drbill, 16x16 sounds awesome.
Post by delcampo on Jan 29, 2016 15:12:07 GMT -6
Of note & regarding RB and his Mothership ...I believe he's now clocking it via a Black Lion micro clock III. I'm curious about this clock and it's buzz lately.
fwiw, I use MH Lio and Burl B2 (clocking either/or)
Post by themaidsroom on Feb 4, 2016 19:08:30 GMT -6
I was thinking 16 I/O of Burl with the Mytek, or maybe the Omni if the clock proves to be comparable. Cary, the old digidesign 'sync' is one of the best clocks out there and can be found as cheap as $300. It works like a charm!! I am always amazed by my Digidesign "sync" in its ability to lock my Studer A827 with pro tools. Even after almost fifteen years and doing it frequently, it still gives me a thrill. I am most likely going to upgrade to the Burl Mothership this year. I have not yet heard it, but have heard only good things about it. I do almost all of my work on tape but would like to be able to give people the best files possible. Be well - Jack
Post by Johnkenn on Feb 4, 2016 19:13:24 GMT -6
I agree with John, the top end on the b2 sounded too bright, I ended selling mine as well. Really? I must have missed John's comment but that surprises me. The top end on my B2 is so smooth. It's a very round sounding converter that I've never thought of or heard referred to as "bright". Not to criticize your experience of it it just surprised me. I wouldn't call them bright, but I do think they impart a bit of sheen...
Post by Johnkenn on Feb 4, 2016 19:14:37 GMT -6
Cary, the old digidesign 'sync' is one of the best clocks out there and can be found as cheap as $300. It works like a charm!! I am always amazed by my Digidesign "sync" in its ability to lock my Studer A827 with pro tools. Even after almost fifteen years and doing it frequently, it still gives me a thrill. I am most likely going to upgrade to the Burl Mothership this year. I have not yet heard it, but have heard only good things about it. I do almost all of my work on tape but would like to be able to give people the best files possible. Be well - Jack Welcome, themaidsroom!
Post by spock on Feb 4, 2016 19:59:55 GMT -6
I love my RADAR studio, and before that my RADAR 24 we'd use to dump tracks from a 3M M79, and it always sounded great.
Post by Ward on Feb 4, 2016 20:24:46 GMT -6
I love my RADAR studio, and before that my RADAR 24 we'd use to dump tracks from a 3M M79, and it always sounded great. Does it have any integrated synchronization capabilities?
Post by cowboycoalminer on Feb 4, 2016 20:34:55 GMT -6
I don't know if I would be concerned about the clock in the Burl stuff. A superior clock, yep.
Post by cowboycoalminer on Feb 4, 2016 20:37:09 GMT -6
To me, the Avid HD i/o stuff sounds amazing and has given me great stability over the past 2 years... but I'm wondering about this Burl stuff and why guys like Vance are 'preaching' about it like it's the second coming of the Lord. prolly cuz they didn't pay for it lol Try one before you say that. Burl is the undisputed king IMO. And they don't give me anything to say that.
Post by cowboycoalminer on Feb 4, 2016 20:41:54 GMT -6
Did the B2 generate alot of heat? Just wondering if spacing is truly important. I would think with those transformers...at least with the mothership, this would be an issue to consider. Cool as a cucumber. My Symphony on the other hand, not so much.
Post by cowboycoalminer on Feb 4, 2016 20:45:54 GMT -6
I agree with John, the top end on the b2 sounded too bright, I ended selling mine as well. Really? I must have missed John's comment but that surprises me. The top end on my B2 is so smooth. It's a very round sounding converter that I've never thought of or heard referred to as "bright". Not to criticize your experience of it it just surprised me. Haha. Yeah, Ragan, anytime I think I can sell my Burl and just be ok with Apogee or UA, I track something with it and kick myself in the ass for even thinking such craziness. BUT, I can't afford anymore than 2 channels. At 1k a channel, it's pricey.
Post by ragan on Feb 4, 2016 20:52:38 GMT -6
Really? I must have missed John's comment but that surprises me. The top end on my B2 is so smooth. It's a very round sounding converter that I've never thought of or heard referred to as "bright". Not to criticize your experience of it it just surprised me. Haha. Yeah, Ragan, anytime I think I can sell my Burl and just be ok with Apogee or UA, I track something with it and kick myself in the ass for even thinking such craziness. BUT, I can't afford anymore than 2 channels. At 1k a channel, it's pricey. Sure is. But I track the majority of my overdubs through it and I print my D Box sum through the Warm Pultecs into the Burl and I'm not getting rid of it anytime soon. I've (in the hopes of selling it and freeing up some cash) done extensive blind tests lately and I still just love me some Burl. Staying in my rack.
Post by Deleted on Feb 5, 2016 3:28:12 GMT -6
Hey man, I would not sink that kind of money into converters. Some people say yay, I say nay. I use Antelope ones because I am OCD and if I don't use good stuff I will blame my failures on not having the best equipment. That's how people are. I would definitely recommend the Orion32, it's by an irrefutably good company with a good reputation for making good stuff. Their support is great, my Zen is rock solid and for 32 channels at 3k you'll have lots of I/O for whatever you may want to expand to. Sorry to the guys who hear a difference, I really don't. I doubt I'd pick out the converters I use against an Mbox. I just like having 12 good preamps in a single rack space with conversion over USB.
