Post by stratboy on Nov 29, 2015 19:46:46 GMT -6
Hi, Guys, Over the holiday, I inherited an Akai S-2800 sampler. I helped a friend rewire his studio and he had it in the closet, sitting unused for the last decade or so. I don't know why I took it; I haven't made music with MIDI since the late eighties, but it came with a Zip 100 drive and what looks like some pretty cool samples, especially drums. My friend used to work in NYC and picked up some gems (he says) from black market collections going around at the time.
I'm curious enough to invest a little bit of time in this beast, but I am in the process of downsizing my rig. There is no space in my racks. I can't keep it. So can any of you guys tell me how I might get these samples off the 3.5" floppies and the zips to make them useful? I can plug the Zip drive into the akai via a SCSI adapter, or I have a USB Zip drive I could connect to a PC. I can get access to a USB floppy drive for a PC, or perhaps use the floppy on the 2800 and transfer via MIDI?
Honestly, i am at a bit of a loss. Is this worth the time? I appreciate your thoughts and guidance; some of you I know have a long history with this kind of gear.
Thanks, Spence
Post by popmann on Nov 29, 2015 19:56:02 GMT -6
Well, I would assume an Akai supported sampler would recognize the disks--and then convert them to it's native format. I know that's how it works with my Akai formatted CDRoms. I was all about ROMplers at the point that you had to load stuff from floppy and zip....but, I would assume it works the same way--in that the OS (windows or OSX) can't read the format, but the sampler will allow you to see the Akai partitions on it.
Post by unit7 on Nov 29, 2015 20:50:20 GMT -6
Logic's built in sampler EXS 24 has an Import AKAI function. I guess other DAWs has this as well(?) I converted all my AKAI samples from magneto optical disks (SCSI II) many years ago, and if I remember correctly I did that by creating disk images from the MO disks to CD, while still having SCSI II machinery
