Post by mdmitch2 on Nov 27, 2015 0:15:00 GMT -6
This seems like a very useful design, but it's pretty new, so not a ton of info out there. Price seems good at $1,000. Dual band sweepable side chain with an EQ boost of sorts, plus a saturate knob....... and four compression modes, as well as a wet/dry mix knob. Supposedly good on drum or mix buss among other things.
www.drawmer.com/products/70s_series/1978_tone_shaping_compressor.php
and somewhat of a 'review' at KMR:
www.kmraudio.com/news/drawmer-1978-compressor-2/
Anyone have experience with this or other Drawmer compressors? For the quality and features, they all seem somewhat underpriced for gear that's made in the UK.
Product Description:
The Drawmer 1978 builds on the success of the award winning 1973 multiband FET compressor and adorns an unparalleled array of controls to give complete mastering over your mix, and all in a deceptively simple 1U frame.
In addition to the usual Ratio, Threshold, Attack and Release controls, the 1978 features four character switches offering a wide range of compression flavours, as well as a variable saturation control to add harmonic distortion to the signal. Side chain functionality is also included with side chain insert points on both channels and a very comprehensive and flexible Side Chain EQ section which offers LF and HF controls with a choice of specific shapes and frequencies for precise frequency-conscious compression such as de-essing. A wet/mix control also allows you to blend the processed signal with the dry for parallel compression.
In addition, a fast reacting Dual colour backlit VU Meter is employed to provide a visual indication of the amount of saturation added. Time delay relays are incorporated into the outputs to provide clean power-up and down with no pops or bangs, and a low hum toroidal linear power supply. The Drawmer 1978 is a truly flexible compressor made in the UK with high-quality components.
The 1978 is a Buss Compressor like no other - compression with character, controlled distortion, tonal shaping, wet/dry mixing - others have tried but have never managed to build a compressor that is this versatile and yet intuative. It's never been easier to get that elusive characteristic sound that sets you apart from the rest. Glue your mix, bring out the bass, control the highs, add warmth, distortion, smoothen, widen, sound less digital more analogue - and at a price that's right for even the smallest studio.
