Post by jcoutu1 on Oct 5, 2015 10:06:08 GMT -6
Anyone used this box? Looks solid and has a lot of features. www.future-retro.com/products.html#!/db-Mastering-Unit/p/50659643/category=0 Seems more complex than I would expect too. I was hoping for svart to do something like this for his next project, but I'm not sure how much cheaper it can be done.
Post by popmann on Oct 5, 2015 13:02:02 GMT -6
That looks like a cool box. They probably need to change the name from "mastering" unit....it's a 16channel summing, overdub analog zero latency cue mix for tracking, monitor switching, mid/side and parallel processing.....what amounts to a switchable patchbay for said overdub studio...which you could also use for some mastering like activity.
Post by jcoutu1 on Oct 5, 2015 13:21:03 GMT -6
That looks like a cool box. They probably need to change the name from "mastering" unit....it's a 16channel summing, overdub analog zero latency cue mix for tracking, monitor switching, mid/side and parallel processing.....what amounts to a switchable patchbay for said overdub studio...which you could also use for some mastering like activity. Seems really cool. For tracking, it has the 2 mic inputs in the front. You can switch between 2 flavors of preamp at the switch of a button, try a couple comps/eq's with a switch, and lay your tracks. 16 channels of summing when mixing, then some cool routing for when you're "mastering" your tacks or sweetening your 2-buss. As you said, it seems like a great little box for the overdub guy/small studio/electronic setup.
Post by rickcarson on Oct 5, 2015 13:26:01 GMT -6
dang that box looks awesome thanks for bringing it to my attention.
Post by svart on Oct 6, 2015 8:07:49 GMT -6
Yeah, that would be hard to beat price-wise. Assuming that the parts are as they say they are and all..
Post by popmann on Oct 6, 2015 11:37:25 GMT -6
Yeah--and they need to include preamps. I was wondering why there were mic inputs but then they claimed the summing needed you to add preamps....it's so you can plug a mic into the front and scroll through your preamps? Really? once you have a chassis and power supply, why is adding two gain stages to make it a completely functional box too expensive? Not from what I've been told. Go ahead and bump it to $1499 and make sure the preamps are solid, clean, quiet high voltage ones. I wouldn't think it would be hard to allow the summing to switch passive and into the "switchable chain"....but, to have it and ASSUME someone is bringing a pair of two buss worthy preamps just to make the summing actually FUNCTION? I mean....you're now limiting yourself to people who own stereo stand alone preamps. This is a better swiss army knife, IMO--if this IS the piece you pick up that does everything but get you in and out of the computer. A mini desk for a mini overdub room.
