Post by Johnkenn on Sept 24, 2015 11:59:40 GMT -6
Post by dandeurloo on Sept 24, 2015 12:01:36 GMT -6
So true. I think PT 9 was one of the worst versions.
Post by formatcyes on Sept 24, 2015 15:04:11 GMT -6
Mine never did anything as good as order a pizza what plugin is that and is it available in AU?
Post by unit7 on Sept 24, 2015 15:39:33 GMT -6
Ha ha Love it!
Post by krcwell on Sept 24, 2015 18:28:07 GMT -6
I feel like I've been on PT9 for so long that my expectations have been lowered to compensate. You just learn to live with the endless load time and the random times where it decides to take it's ball and go home because something happened it didn't like.
It's easier/lazier than trying to decipher the PT12 pricing scheme.
Post by dandeurloo on Sept 24, 2015 18:36:09 GMT -6
PT 11 is the best so far.
Post by Johnkenn on Sept 24, 2015 21:29:51 GMT -6
See if you can grab 10, krcwell. Worked much better for me than 9 and still uses rtas.
Post by rickcarson on Sept 24, 2015 21:39:38 GMT -6
I am on 10. I love how if you reload the page its different insults everytime. There is just so much bad shit to say.
Post by Ward on Sept 25, 2015 6:58:42 GMT -6
I'm fine with 10. Everything works. Not as slow as some suggest. of course, I'm also running a 'Westmere' Mac Pro tower with SSD drives and maxed out on RAM... and the 12 dual-core processors don't hurt either.
Post by swurveman on Sept 25, 2015 7:28:37 GMT -6
I'm using 11 Native and, despite so many negative things said about PT, I've found it to be extremely stable and easy to work with. The 64 bit transition to work with my 64 bit plugins is excellent. The ability to use external FX as inserts is excellent. In particular, the mix window is second to none in terms of its functionality. They really did a nice job with this software.
Post by Johnkenn on Sept 25, 2015 9:24:03 GMT -6
I'm fine with 10. Everything works. Not as slow as some suggest. of course, I'm also running a 'Westmere' Mac Pro tower with SSD drives and maxed out on RAM... and the 12 dual-core processors don't hurt either. That really makes a huge difference.
Post by Johnkenn on Sept 25, 2015 9:27:38 GMT -6
I'm using 11 Native and, despite so many negative things said about PT, I've found it to be extremely stable and easy to work with. The 64 bit transition to work with my 64 bit plugins is excellent. The ability to use external FX as inserts is excellent. In particular, the mix window is second to none in terms of its functionality. They really did a nice job with this software. Yeah, definitely. Nothing was wrong with 11. Other than some plugs I couldn't use anymore. It's the extortion upgrade to 12 that has everyone pissed. I'm thinking about breaking down and getting it, though, because I have a project I'm mixing in PT's and I'm getting some GUI flashing on 11 in Yosemite...and in 10, sometimes, the menu's graphics don't propagate until you scroll over them. PITA. Seems like it's almost an intentional bug to make you move up.
Post by ericn on Sept 25, 2015 10:40:06 GMT -6
Loving 12 native here no problems!
