Post by Johnkenn on Sept 10, 2015 14:29:19 GMT -6
www.steinberg.net/nc/en/support/knowledgebase_new/show_details/kb_show/cubase-8-version-history-and-issues-and-solutions.html
Cubase 8.0.30 update
Key Summary
BON-10244 Improved ASIO Guard support for Dual-CPU systems.
BON-11279 Sometimes no audio output was generated when projects from previous version were loaded.
BON-6954 Potential crash fixed on sampelrate change while a project is loaded.
BON-12124 Improved compatibility with USB Audio Interfaces.
BON-11303 Sometimes the application didn't quit completely.
BON-9133 Using a file selector made the application lose focus.
BON-11380 On first start, Project Templates were not shown in the MediaBay
BON-11280 On some PC systems the skin file was not correctly updated and caused program crashes.
BON-12692 MediaBay crashed when search string containd "()".
BON-10554 Fixed: Unwanted activating of VST Expression Sound Slots.
BON-7379 MIDI track input settings was sometimes not restored correctly.
BON-10272 mouse wheel on text in value box (like volume) with or without using Shift modifier
BON-11074 EQ no longer stops working after copying EQ settings by drag&drop in the Mixconsole
BON-11728 In some conditions, mono tracks didn't show the meter activity.
BON-10341 Anymix Pro individual signal positions were not saved/restored with a project.
BON-10599 Retrologue: Saved programs did not show up in MediaBay.
BON-11341 [REVerence] Used impulse response file was not found after opening a project from Mac OS on Windows.
BON-11687 Possible crash fixed with MIDI Plug-Ins in the Inspector.
BON-12377 Possible crash fixed with renaming tracks.
BON-9515 Time ruler was not updated correctly when switching between projects with different timecode framerate.
BON-10204 MIDI Playback did not correctly resume after automatic punch out.
BON-9380 Render In Place abort function now works reliably.
BON-5220 Score Editor: Step Input Cursor is now blue.
BON-9505 Score Editor: Corrected Note Symbols Tooltips.
BON-12445 VCA Fader setup can now be operated from Avid EuCon based consoles.
BON-8147 Improved VCA mechanism for Slave faders set to -∞ dB.
Key Summary
