Post by Randge on Jul 6, 2015 13:02:28 GMT -6
Post by BradM on Jul 6, 2015 13:07:32 GMT -6
Post by Randge on Jul 6, 2015 14:26:53 GMT -6
Thanks! They all have their merits and choosing is gonna be tough. I mostly need a pair for processing with vintage compressors from the 30's and 40's, but being able to incorporate pedals is certainly another plus.
Post by dandeurloo on Jul 6, 2015 15:15:44 GMT -6
Serpent Audio Send n Blend link
Post by gouge on Jul 6, 2015 17:35:52 GMT -6
it strikes me how expensive these modules are. $500-$700+ for a blender is really really over the top. I don't care what's inside it.
Post by BradM on Jul 6, 2015 18:29:56 GMT -6
Well you can partially blame that on dealer markup. This is the type of product that in basic form would make a good kit.
Brad
Post by EmRR on Jul 6, 2015 21:36:52 GMT -6
What 1930's comp do you have? There aren't many.
No input on 500 series blenders. Console and patch bay mult comes to mind.
Post by dandeurloo on Jul 6, 2015 21:39:50 GMT -6
The Send N Blend is half that and works great.
Post by gouge on Jul 6, 2015 22:11:54 GMT -6
I had another look. Ok, $400 and up. That's still way over the top.
I have been wanting to make a line level box passive blender for myself but next up is an m/s box.
A kit would be excellent. I often double mic stuff and would like to send 1 channel to the converters or console.
Post by EmRR on Jul 6, 2015 22:18:29 GMT -6
You can do resistive blenders, transformer blenders, active blenders, all pretty easy DIY. Those great little Radio Shack experimenters boards are only a few $. Slap them in a Classic Audio Products 500 frame and faceplate with edge connector to make your own if it needs to be that way.
Post by winetree on Jul 7, 2015 0:06:18 GMT -6
check out Radial Engineering. They have some mic combiners in 500 format. Don't know prices.
Post by KJ on Jul 7, 2015 4:01:27 GMT -6
Post by jcoutu1 on Jul 7, 2015 7:20:32 GMT -6
Thanks! They all have their merits and choosing is gonna be tough. I mostly need a pair for processing with vintage compressors from the 30's and 40's, but being able to incorporate pedals is certainly another plus. Hey Randy, you have a guy that does restoration work on your old compressors and such right? I bet the could probably build a 4 channel version of one of these into a 2U rack box with some vintage looking knobs to match your gear for the price of a single one of these 500 series units.
Post by Randge on Jul 7, 2015 7:24:35 GMT -6
I don't know a tech that will work that cheap and do solid work. I am so busy in the studio that I have no time for any DIY at this time and was wanting a quick solution.
Post by drbill on Jul 7, 2015 10:45:14 GMT -6
I had another look. Ok, $400 and up. That's still way over the top. It is what it is. Either pay it or buy a cheap console. If you don't mind what a Mackie sounds like, you can get 8 "blenders" for less than half the price of 1 500 series blender.
Post by ericn on Jul 7, 2015 11:12:17 GMT -6
I had another look. Ok, $400 and up. That's still way over the top. It is what it is. Either pay it or buy a cheap console. If you don't mind what a Mackie sounds like, you can get 8 "blenders" for less than half the price of 1 500 series blender. Yeah for simple blending I would look at some of the many used install or broadcast simple mixers .
Post by wiz on Jul 7, 2015 16:45:42 GMT -6
Delta modded?
or a SSL X desk if you want new?
Post by gouge on Jul 7, 2015 16:59:38 GMT -6
I"m already using a fully modified cal ghost.
It's just easier to use a box sometimes and avoid all of the console circuitry. Currently using either the groups or aux.
Post by Randge on Jul 8, 2015 9:03:57 GMT -6
Nah, not into having any more console in my way other than the Smart Av. I wanted a handy blender, not a big Mackie boat anchor that I wouldn't even remotely like the tone of. I have my signal chains pretty organized and know what I want out of them sonically. I just want a mix and blend setup that is easy to plug in and go. Looks like the TK one is more to suit what I need.
Post by odyssey76 on Jul 18, 2015 13:17:05 GMT -6
Does anyone know if there's a plugin that does this?
It'd be awesome to put a blender/mix knob plugin after a hardware insert and have it blend that piece of hardware to taste. Is there anything that does this?
Post by wiz on Jul 18, 2015 17:41:08 GMT -6
Does anyone know if there's a plugin that does this? It'd be awesome to put a blender/mix knob plugin after a hardware insert and have it blend that piece of hardware to taste. Is there anything that does this? Okay, I will be the smart ass 8) its called a fader 8) bring the hardware back in to a channel, and blend the channel into the mix 8) cheers Wiz
Post by Randge on Jul 18, 2015 17:56:30 GMT -6
I already have a pretty elaborate set up, Wiz. I was trying to avoid that and print with more efficiency. I want to track with it as well, which will shave my post work time down and be more streamlined. I like to commit and roll baby!
Post by wiz on Jul 18, 2015 18:18:23 GMT -6
I already have a pretty elaborate set up, Wiz. I was trying to avoid that and print with more efficiency. I want to track with it as well, which will shave my post work time down and be more streamlined. I like to commit and roll baby! Hey RandgeI see where ya are going... I was talking more directly to Justins question about a mix knob with hardware gear... cheers Wiz
Post by Randge on Jul 18, 2015 19:19:46 GMT -6
Gotcha.
Post by ericn on Jul 19, 2015 17:18:03 GMT -6
I already have a pretty elaborate set up, Wiz. I was trying to avoid that and print with more efficiency. I want to track with it as well, which will shave my post work time down and be more streamlined. I like to commit and roll baby! Randy I get your point, but man I still see soo much value of having a small line mixer lying around! From simple mixes to just having the ability to have some gain or attenuation before going digital!
