Post by Deleted on Sept 10, 2013 12:38:17 GMT -6
ahh.. here we go again, of course the tests are never good enough. That's not true. Some tests are perfectly valid. However, most informal tests I see are indeed not good enough for reasons that are not difficult to understand. That's not true either. In fact, it's exactly what you complain about above, that tests are never good enough. Blind testing is the gold standard for all branches of science. It makes no sense to me that for some reason blind testing is invalid for audio. Absolutely! Like loudspeakers, microphones vary all over the map. The differences are real. And they're both audible and measurable. But comparisons still need to be done properly. Microphones are especially difficult to compare because it's difficult to put two different microphones in exactly the same place. Even when you do that, nobody can sing or play an instrument exactly the same way twice. One solution is to mark with string where each microphone's capsule goes, and use a loudspeaker playing music as a repeatable source. --Ethan
Post by tonycamphd on Sept 10, 2013 12:44:40 GMT -6
Ok, enough of this, i'm going to single handedly put this perpetual internet feud to rest once and for all! (yeah right lol!) Since the beginning of this thread, it's veered steadily toward assessing the value of performing modifications to existing equipment, caps are part of the whole(so i believe i'm on topic??lol!),
So here's the comparison i'm trying to put together, i have "almost" 2 completely different chains that are exactly the same....? The things i'm working on acquiring are in RED, let me explain..
CHAINS AS FOLLOWS: A: stock Apex 460 condenser mic- stock Soundcraft delta 200 input strip(utilizing pre/eq)-stock aphex 651 compressor insert-stock digi 002 A/D conversion-protools/macbook-44.1 wave file
B: JW's Apex 460 condenser mic- JW mod Scraft delta 200 input strip(utilizing pre/eq)- JW mod aphex 651 compress insert-BLA signature mod digi 002-protools/macpro-44.1 wave file
SINGLE ACOUSTIC GUITAR PERFORMANCE EXAMPLES, THEN SOME ACCOMPANY TRACKS EXAMPLES TO DENSE UP THE MIX A LITTLE, MIC CAPSULES WILL BE AS CLOSE TO EACH OTHER AS POSSIBLE, ALL KNOB/FADER SETTINGS IDENTICAL ON ALL SETS OF EXAMPLES, edit;AND THEN VOLUME MATCHED ON ANOTHER SET OF EXAMPLES, REASON BEING IS, THESE WILL SURELY HAVE DIFFERENT HEADROOM LEVELS DUE TO THE MODS(although i probably shouldn't level match, as the dynamic range will be improved with the mods, which does indeed makes them a better pieces, and will be a fair comparison). THE ONLY DIFFERENCES IN THE EXAMPLES WILL BE THE MIC CAPSULES BEING PLACED AS CLOSE AS POSSIBLE TO EACH OTHER/BUT OBVIOUSLY DIFFERENT, ALL OTHER CHAIN SETTINGS WILL BE IDENTICAL,
I'm confident Jim Williams will let me borrow his Apex 460 mic, so that's almost an assumption at this point, and my friend Dan is coming down from LA next weekend for the Chargers(Chokers!)/Eagles game, so he's gonna dig up his stock Digi 002.
I lol'd when i typed the A/B above, I know exactly what the result of this is gonna be, i've said this many times before, and i believe it whole heartedly. The end result of what we do, is the sum of all the "little things"...this will be an example of how a few "little things" in a chain can make a big difference, should be interesting and fun fella's!! My shit is all over the place right now, but I will make this happen if i can get these pieces, I'll keep ya posted.
Post by Martin John Butler on Sept 10, 2013 13:00:45 GMT -6
When I said "the tests are never good enough", I was saying that you invalidate experienced people's impressions, because of their listening methods. Blind tests are only valid for testing what they're testing, where their testing it, when they test it. Who knows, maybe the testing method has aspects that are questionable. In the test you posted a link to, they use Monster 2.2 cables. Those things will make everything sound the same shitty way, no matter what you put them into, they're that bad. I had them, I know.
In the end, I believe my ears, and you say you can't trust them, and even if my interpretation of your statements are incorrect, and you're basically saying our ears can be fooled, I say fair enough, my way's more fun.
Sorry, I've gone way off topic. What are caps? Damned if I know, that's why I'm here, enjoying the posts, and maybe learning something new while I'm at it.
Post by popmann on Sept 10, 2013 13:35:37 GMT -6
Maybe the discrepancy is Kennedy isn't plugging it into "any preamp with low noise specs" and then into a Soundblaster running at 44.1. wait, are you saying that manufacturers use cheap preamps/interfaces when they design their mics and outboard? No, I'm simply restating some of Ethan's great hits of expert opinions for context. I thought pretty cleverly in one sentence.
Post by Johnkenn on Sept 10, 2013 13:39:44 GMT -6
I think we should all realize that we aren't going to change anyone else's mind - if that mind has been made up.
Post by tonycamphd on Sept 10, 2013 14:04:16 GMT -6
I think we should all realize that we aren't going to change anyone else's mind - if that mind has been made up. Your right JK, i'm going to do that a/b comparison for the open minded folks(i think there are plenty here), others will see what they want to see, and negate the whole experiment, probably due to the carbon matter that forces the capsules to be 2" from one another lol!.
Post by Martin John Butler on Sept 10, 2013 14:09:39 GMT -6
True John, I'll try to remember that. Believe me, I know a few acknowledged experts who can just as expertly voice the opposite opinion as Ethan's. So there really is little point debating that in a post about caps. I'm not some anti-science Luddite, on the contrary, I just see a different picture than some people. Their picture is just fine from where they're looking.
I think Ethan has a lot to offer us too, and many of his points are worthy of consideration, if only for balance.
Back on topic now...
Cowboy has done some mods to his Ghost. Did that include caps, I forget?
Post by jazznoise on Sept 10, 2013 14:31:22 GMT -6
I think we should all realize that we aren't going to change anyone else's mind - if that mind has been made up. Well, that's the crux of the argument. Opinions are just simply things you like to believe. But facts are facts - and it's objectively true that an ABX is the standard scientific test method. The subjectivist nightmare of "Well I can hear the difference between oxygen free power cables and regular power cables" is the worst part of audio. It makes no sense to throw so much money at imaginary problems if you can prove they don't exist. It reduces our overheads, meaning we can be cheaper for the client and offer the same quality product. What's not to like? The only similar scenario I can think of is certain crazy Post-Modern feminists declaring physics to be patriarchal by nature because people dismiss them for wildly inaccurate claims. "If you were me you wouldn't be saying that!". But no one else is them so it's there problem to prove what they say in a fair, repeatable manner. I'm not saying microphone capsules don't matter, incidentally. I'm just saying I find the hostility to science in some parts of audio bizarre. Mozart was tuning pianos to compensate for room acoustics and temperament issues for the Concertos, Etudes and Symphonies he wrote - I think we can open up an ABX program and give it a go every now and again.
Post by Johnkenn on Sept 10, 2013 14:32:43 GMT -6
I try and learn the best from the best and then form my own opinions - allowing that I could be wrong. Successful people - even some legendary - don't have the corner on right-thinking. I can't tell you how many grammy winning/hit making songwriters I've sat in the room with and thought, "Man...I just don't get it..." (there have been just as many that I thought, "Man, I GET it)
But there was always something there that I could learn. "I learned long ago, never to wrestle with a pig. You get dirty, and besides, the pig likes it." - George Bernard Shaw
I promise I'm not aiming this at anyone...I was just thinking about the endless arguing on message boards and how if it were face to face, it would never happen.
Post by Deleted on Sept 10, 2013 14:42:03 GMT -6
i have "almost" 2 completely different chains that are exactly the same. If you compare two completely different chains and find there's a real difference, how can you know which device(s) are responsible? The article by Tom Nousaine I linked to compared two "chains," but there were only two devices and neither was a microphone. So I'm not sure what your test will reveal. --Ethan
Post by Deleted on Sept 10, 2013 14:49:58 GMT -6
you invalidate experienced people's impressions, because of their listening methods ... In the end, I believe my ears, and you say you can't trust them Yes, though I don't necessarily distrust ears if the test is valid! An experienced mix engineer who takes part in a test that's poorly conceived will not be able to provide a useful opinion. That's a failing of the test, not the person. But doesn't this make my point? If Monster wires really do make everything sound "shitty," how do you explain that nobody could tell one system from another? Further, what property could a wire possess, other than maybe bad soldering, that would make it affect the sound at all? --Ethan
Post by Deleted on Sept 10, 2013 14:58:20 GMT -6
I was just thinking about the endless arguing on message boards and how if it were face to face, it would never happen. For sure. I have a standing invitation for those who disagree with me to get together in person either here or at their place, because I'm sure one of us would be able to easily convince the other. But it's rare for people to agree to meet even when we're local. Years ago Slipperman invited me to test his claim that he could hear when a hard 20 KHz low-pass filter was inserted into his mix bus. He insisted ultrasonic frequencies affect frequencies we can hear, and I offered to bring a filter and switch it while he didn't look. But then he backed out. Same for an "audiophile" that lives near me, who believes in all manner of stuff like magic isolation platforms for his power amps and CD player. As with Slipperman, I begged this guy a dozen times to let me visit and test him blind, but he never agreed. So I'm not optimistic, though this remains a standing offer. --Ethan
Post by Deleted on Sept 10, 2013 15:03:33 GMT -6
others will ... negate the whole experiment, probably due to the carbon matter that forces the capsules to be 2" from one another lol!. But a spacing of 2 inches is enough to completely change what the microphone captures! At least in a home-sized room. The difference in captured response is simple to prove with a basic measurement. So yeah, I can tell you now that such a test is invalid. That's why I mentioned using strings, as was done for this test: Comparison of Ten Measuring Microphones--Ethan
Post by tonycamphd on Sept 10, 2013 15:33:40 GMT -6
i have "almost" 2 completely different chains that are exactly the same. If you compare two completely different chains and find there's a real difference, how can you know which device(s) are responsible? The article by Tom Nousaine I linked to compared two "chains," but there were only two devices and neither was a microphone. So I'm not sure what your test will reveal. --Ethan Ethan, unless i'm really misunderstanding??, your argument is generally that mods are unnecessary, and make little, if any difference. I'm confident these blind examples will prove beyond subtly, they can make a huge difference! who cares what "piece" it is that makes the improvement, if the basis of an argument is "mods aren't worth it, and they don't make a difference" Any improvement at all is a win for modding! The 2 chains will be identical equipment, stock vs modded, plain and simple. Any convolution beyond this is suspect IMV I reiterate, the knobs and faders on every single piece of gear will be identical, head room and noise floor changes are part of the advantage of modding, my prediction is, the results will be far from identical. I'm even going to plug the modded equipment into my balanced power suppy(power supply mod lol!), stockers get the wall treatment with the fridge and microwave upstream lol!
Post by tonycamphd on Sept 10, 2013 15:39:17 GMT -6
others will ... negate the whole experiment, probably due to the carbon matter that forces the capsules to be 2" from one another lol!. But a spacing of 2 inches is enough to completely change what the microphone captures! At least in a home-sized room. The difference in captured response is simple to prove with a basic measurement. So yeah, I can tell you now that such a test is invalid. That's why I mentioned using strings, as was done for this test: Comparison of Ten Measuring Microphones--Ethan I'll set the mics to cardoid, and set up in the middle of my room, the low spl of an acoustic should keep the room out of the mics enough for reasonably good sets of ears to make a general assessment, despite a vertical 2" center to center mic capsule discrepancy. Beside this, i'm going to DI a bass on one of the examples, so any doubters can use that track to draw their conclusions. edit, maybe i'll even throw a synth part in there?
Post by svart on Sept 10, 2013 16:53:47 GMT -6
The 2 inches that Ethan is mentioning means that two different mics, comprised of the same parts, would sound different unless they inhabited exactly the same space at the same time. Anyone who's spent any time studying the nuances of moving mics around on a guitar cabinet would know that even 1/4 inch is enough to make a huge difference in the sound. 2 inches would be impossible to match, therefore nullifying the scientific portion of the test, leaving only the subjective portion, and only bringing the argument full circle. It's a hard thing to wrap the head around unless you've worked doing high level testing in some scientific discipline, and even then it can really be a bitch.
Post by Johnkenn on Sept 10, 2013 17:58:55 GMT -6
Post by tonycamphd on Sept 10, 2013 18:05:28 GMT -6
Svart, you are a genius, but respectfully, I think every one here is either a SERIOUS enthusiast on some level, or a music pro, we all should have some basic degree of active listening skills. I think, the idea that 2 mics/capsules being 2 inches apart center to center, will destroy objectivity in making a blind assessment of their quality, seems a bit silly. Yes they will sound a little different, but the assertion that it makes a comparison useless, is a reach. By this standard, i'm going to have to stop wasting my time A/B ing different mics on vocalists, because the takes will be different from one another, and they may move their head position a little, and i won't be able to discern the differences between them accurately I'm not buying that one. The examples i'll put forth, will also have split, single performance DI tracks to alleviate these types of microphone placement concerns. I want to make clear, that i have nothing but respect for Ethan and Svart, they are both quite impressive fell's, and quite accomplished IMV This is fun and interesting stuff for me personally, I'm going to be as impartial and scientific as my tiny intellect will allow me to be with the samples i put forth lol! And hopefully everyone who's interested can learn something from it? I'll report back when i'm set up for this blind. T
Post by svart on Sept 10, 2013 19:09:59 GMT -6
Lol johnkenn. Awesome.
Tony, it's all good man! I'm just hard headed. I like to teach, but i get like a pitbull and latch onto something. It's making it very hard not to reply!
If i went to my boss and said i thought two RF amplifiers looked the same and didn't bring a stack of papers about 1/4" thick proving that they were indeed the same in all the right ways, he'd probably shake his head and wonder about his hiring choice.. so, i come from the side where perfect testing is required, not just nice to have. Case in point, we spent a million dollars on testing stations for a production line in order to ensure calibrations on our product.. if i went only by opinion and was even slightly wrong, there is real money to be lost!
The point being, this stuff is programmed in me. Details, Details, Details!
I have a feeling Ethan is the same way.
Post by Martin John Butler on Sept 10, 2013 19:56:33 GMT -6
Well, If you gave me two identical mics, and told me I could keep only one, I'd test them by doing something like play an acoustic guitar, and then play the same thing with the other mic, same settings, same mic placement. Then I might sing something with each mic, as equal as I could make it, and then I'd listen.
Now, compared to a test lab somewhere, there might be dozens of variable factors that might make my auditioning of the mics "invalid", but I bet I'd prefer one over the other, and that would be the one I'd choose. Of course, even manufacturing can make the same product slightly different, model to model, so there's no guarantee any two mics are enough the same to make a comparison "valid". I'd be secure my choice was the right one, and I'd be done with it. Am I "wrong", maybe, but I also bet if I posted those same tracks everyone here would choose the same,"better " mic.
So, much of this is just spinning our wheels. I'd bet cash money I'd hear the same thing cowboy did when it comes to his cap mod.
Post by LesC on Sept 10, 2013 20:44:48 GMT -6
Gee, my house cost about $800,000. For that price, the architect and contractor surely made sure that everything was absolutely top quality, so I shouldn't need any room treatment. Thank you Ethan, you just saved me a pile of money!
Post by svart on Sept 10, 2013 21:03:31 GMT -6
Gee, my house cost about $800,000. For that price, the architect and contractor surely made sure that everything was absolutely top quality, so I shouldn't need any room treatment. Thank you Ethan, you just saved me a pile of money! Actually, I've seen a number of expensive houses around that number that came with sound control.
Post by LesC on Sept 10, 2013 21:13:31 GMT -6
I'd have to do a blind test, with the identical house and identical performance, with and without the sound control. Anything less and the test is invalid, so we can't possibly know if the sound control made a difference.
By the way, I am joking! I think Ethan is brilliant, and I'm glad he's here, somethings I just find humorous.
Post by svart on Sept 10, 2013 21:35:40 GMT -6
Sure, it's humorous. It's strange and seems time consuming and irrelevant, but Ethan is still 100% right in his theory. He's just looking at it from a scientist point of view rather than a user's point of view. His job is the details that nobody sees or really cares about. Sometimes those details are a lot more complicated than anyone would ever guess and communicating those ideas is hard, even without opinions and emotions flying.
I suspect there is a disconnect between the designer and the casual tinkerer and the way they think, that leads to back and forth threads like this.
Post by Martin John Butler on Sept 10, 2013 22:05:32 GMT -6
I'm not a "casual" musician, and I disagree with Ethan's general premise that only under careful scientific testing can we know the truth regarding sound perception. There's lots of abstraction going on here, ( lesC's new house room treatment statement is a good example), and as I've said before, I might find a theory interesting, but I'm convinced we do not understand human perception to make these 100% sure kind of statements. My stereo system sounds better with my new power cord than the previous one, I don't need any more info to make that call that my 40 years of full time professional experience hasn't already given me.
