Post by mobeach on Jun 13, 2015 8:46:58 GMT -6
I've been searching around for something simple with a tempo adjustment but all I seem to find is hip hop plugins. Anyone know of one?
Post by Deleted on Jun 13, 2015 22:50:50 GMT -6
Post by mobeach on Jun 14, 2015 6:01:36 GMT -6
I'll check it out thanks!
Post by mobeach on Jun 14, 2015 6:05:05 GMT -6
That's weird, the download for Tap gives you a DLL but no EXE
Post by Deleted on Jun 14, 2015 6:24:21 GMT -6
It's a VST plugin dll. Needs a vst host program. Copy to the vst folder of the DAW e.g....
Post by henge on Jun 14, 2015 7:24:34 GMT -6
Post by drew571 on Jun 14, 2015 13:56:18 GMT -6
i'm not sure if you want something for your DAW as a plugin or not, but as an MD when I'm running a band I'll use Tempo Advance on iOS. Great app.
Post by mobeach on Jun 14, 2015 14:00:21 GMT -6
I wasn't looking for a metronome, Reaper already has one of those.
Post by b1 on Jun 14, 2015 14:23:15 GMT -6
If you want to use a .dll as a standalone App, download the free "Savihost" from Hermann Seib. Rename Savihost to the name of the .dll, but leave the extension (.exe) in place on Savihost... no VST host required.
Post by Ward on Jun 14, 2015 21:24:18 GMT -6
What's wrong with the one that's built into Pro Tools? Or for that matter, any other lesser DAW? Aren't these standard?
Post by tonycamphd on Jun 14, 2015 22:20:50 GMT -6
it would be cool to have a simple click that had at least a little weight/groove to them, the daw clicks are terrible, the only time i've ever had clicks that felt remotely good was when I programmed a drum machine, i'd be really happy to find something simple that at least tried.
Post by levon on Jun 14, 2015 23:45:36 GMT -6
Not a plugin, not a metronome. I love this and use it all the time. Select your tempo, length and sound and download. Pull it into your DAW, align and go. Works great for me www.metronomer.com/
Post by b1 on Jun 14, 2015 23:49:02 GMT -6
it would be cool to have a simple click that had at least a little weight/groove to them, the daw clicks are terrible, the only time i've ever had clicks that felt remotely good was when I programmed a drum machine, i'd be really happy to find something simple that at least tried. It took me a while to remember where I put this, but this is a programmable .exe "metronome" with Drum Sounds: Cool MetronomeIf you'd like a little reverb, you can download Mini Host to load the Cool Metro .dll and a reverb plug-in .dll - all without a DAW.
Post by mobeach on Jun 15, 2015 4:48:40 GMT -6
it would be cool to have a simple click that had at least a little weight/groove to them, the daw clicks are terrible, the only time i've ever had clicks that felt remotely good was when I programmed a drum machine, i'd be really happy to find something simple that at least tried. That's what I'm talking about, I like the ones I can program into my DR-880 drum machine but was hoping there was something similar in a software version that's less time consuming than using a drum machine.
Post by Randge on Jun 15, 2015 12:15:05 GMT -6
Here ya go. And, what do ya know, it is all part of the Cubase world.
Post by Randge on Jun 15, 2015 12:15:36 GMT -6
Btw, you can have 4 different kits going on at the same time.
Post by terryrocks on Jun 17, 2015 14:08:55 GMT -6
I'm in the same boat. I really like the ios app Metronomics. Wish I had something similar for protools 11.
