Post by Johnkenn on Jun 1, 2015 19:41:29 GMT -6
I was following @svarts advice on breaking in the Amphions - set up a sine wave at 20hz and the woofers are flapping and surprisingly I definitely hear frequency in this range (and even below - I thought humans could only hear 20hz-20khz?) I'm going out of the RM1794 into the sub, then to the power amp and then of course to the speakers. The sub has a foot switch bypass that I'm using right now, but I was engaging the sub at different frequency points and noticed that the sub doesn't even make a sound at 20hz while the much smaller Amphions produce a pretty loud tone. Also, I noticed at about 116hz, the Amphions are louder by themselves and then with the sub engaged it is several dbs lower in volume. WTH? I haven't tried the phase switch - actually, that just occurred to me. Any other thoughts of what it might be? Randge, tonycamphd, @danduerloo?
Post by kcatthedog on Jun 1, 2015 19:50:55 GMT -6
If you hear nothing from the sub but something from the amphion at 20 hz, I'll be interested to know that explanation ? it suggests that the amphions are not actually creating a 20 hz cycle, jus an audible artifact ?
Post by Johnkenn on Jun 1, 2015 20:04:39 GMT -6
Yeah. It's strange.
Post by mulmany on Jun 1, 2015 20:35:14 GMT -6
Pulled this from an old post I wrote on the other site. Hope it makes sense for you.
When you use a sub with any system make sure your phase response at the crossover is correct. That means - 80hz is at 40 degrees phase at the LR speakers but because of the sub displacement (distance) 80hz from the sub is at 70 degrees phase. This kind of combination will cause a comb filter on up though the frequency range. The numbers I picked are random, your system will be different.
Most subs come with a phase switch or knob that you can adjust. You want to send a sinewave though your system at the crossover frequency. (Your crossover frequency is the frequency that is -6dB at the natural low roll off of the speaker) For fun take a walk around the room and listen to the changes. Now invert the phase on the sub 180 degrees and move it around until the level drops at the listening position, this will take two people to make short work of it. Once you have found the position that creates the greatest reduction in level, switch the phase back to zero. If your sub has a phase knob - invert the LR speaker phase, and adjust the knob until you have a level drop at the listening position - correct the polarity on your LR speakers and take a listen. You should have a fuller, richer bass responce, since your Sub is now truly reinforcing the LR speakers. You also want to adjust the level of the sub to create as smooth and flat transition as you can into its range.
Advanced dual channel FFT programs will allow you to do this much quicker and more accurately like SIA's Smarrt.
This is not to say that you don't need more bass trapping. Put as much as you can! It will also help to aline the sub with the LR speakers as you will reduce the ringing in the room, and let you hear when you have cancelation.
Hope this helps
PS make sure that the sub and speakers are level matched before testing the phase.
Post by winetree on Jun 1, 2015 22:24:10 GMT -6
I just make sure the drivers in the sub and speakers are in the same horizontal plane. Seems to work for me.
Post by tonycamphd on Jun 1, 2015 22:38:59 GMT -6
JK, put the 20hz sine wave through the sub, crank it up to where you think it would be loud(be careful), and then walk around the room, you will hear the 20hz(or any freq for that matter, from around 75hz down)tone in some places, and it will disappear in others, and it will be even louder in other spots, especially corners(even trapped corners), these are called nodes and antinodes, and the only way to rid yourself of them is with some serious room treatments in the form of bass traps, i know you already have some in there, and they do help, but 6" corner traps are not going to cut it most times, i have 3 absolutely huge bass traps in here, and my walls have 3" of roxul underneath the slat diffusors, my room is pretty good, but it STILL has hot and cold spots. Beside lots of acoustics tuning, the best way to eliminate these problems is by monitoring at low volume, you can try the phase switch and see what happens? if it works in your listening position? then use it. You should get someone over there to help you run some sweeps with room eq wizard, it can only help you understand where you room is lacking, and then you can either fix it, or compensate for it. kcatthedog It's totally normal that the amphions are hitting 20hz and below(it will be rolled off, but it will be very much there), i just was hearing/feeling/watching my HR824's kicking at 7hz. The reality is humans can hear/feel a bit above 20k as long as there are many multiples of freq's involved, and they surely hear(mostly feel) down to 7hz, big people even lower! check this out, get it down there and be careful as you turn it up, you will have to turn it up BE CAREFUL! and don't forget to turn it back down or the next time you use your rig, you're gonna shit your pants lol plasticity.szynalski.com/tone-generator.htmI also should add that if 20hz is showing up weird, it makes sense that harmonics can do weird stuff as well, you should also check the frequency plot of the amphion 1 18's and set your crossover point of your sub accordingly, sometimes if they are crossed too high a fight breaks out, no influence on the 20hz thing though, I don't know about you guys, but I usually hard filter off just about everything below 25hz anyway.
Post by dankin on Jun 1, 2015 22:52:32 GMT -6
What sub are you using? I had a pair of KRKs for a while, but I never could get used to them. I finally listened to the advice of a friend who's a great engineer, and went back to just the ProAcs. I did try a pair of Focal Twin 6 with the Focal Sub 6be for about a month. I never did like the Twins, (way to harsh to my ears) but the Focal sub was much tighter than the KRKs.
Post by Johnkenn on Jun 1, 2015 23:42:36 GMT -6
I just posted this in the Amphion thread:
"So get a load of this. I've been meaning to dial my sub in again - with an spl meter and the whole works...so I did tonight...It's a cheaper KRK 10S. But like I said in another thread, there was some weirdness going on, so I bypassed the sub altogether. Normally, you go out of the DA into the sub, into the power amp, then into the monitors...but I just went straight from the DA to the power amp...and lo and behold - there was the amazing imaging I remembered from the 15's. When I demo'd the 15's, I demo'd them mostly without the sub and then quickly with it...I figured if I could live with them without the sub, then the sub would make them even mo better. Plus, I added the sub to them a couple of hours into straight listening. Who knows, maybe it's just that the sub is adding more of the center stage, therefore making the sides not sound as wide. But regardless of the reason - the 18's sound better by themselves.
I also put about 4 hours of 20Hz on them too...and they do sound like they've loosened up. Maybe it's purely psychological - but I'm happy...so, so be it."
I'm think I'm dumping the sub. Well, I'm gonna try some mixes without and maybe keep it around for reference.
