Post by jcoutu1 on May 27, 2015 21:35:19 GMT -6
Looks cool to me. 7 bones right now for a pair? I'm going to check it out some more anyway.
Post by mdmitch2 on May 27, 2015 22:14:44 GMT -6
Here's the kickstarter link, which has frequency response listed as 40Hz-22kHz (+/-2.5dB) ... not too shabby for what appears to be a ~5 inch driver (achieved by dsp).
Post by Johnkenn on May 27, 2015 22:31:17 GMT -6
Yeah - cool idea. I assume they are active?
Post by winetree on May 28, 2015 0:08:15 GMT -6
Any further info on them. If they aren't funded you're not charged.
Post by jeromemason on May 28, 2015 0:46:04 GMT -6
I guess I'd be a little hesitant because of the long throw of a full range driver. I have a feeling those may not portray low transient detail all that well, but it's just a guess from the quick read. Neat looking speaker though.
Post by viesturs on May 28, 2015 5:10:16 GMT -6
Guys. Sorry for intrusion. I am Viesturs, CEO of Square Audio. Please ask any questions and I also would be grateful if your questions could be asked on Kickstarter and I will answer them there or as well here. Basically I launched Kickstarter to talk to people directly and not through corporation hyped marketing, I wanted to be honest as far my knowledge goes and to build a trust with with reasonable dialogue directly with everyone.
Regards to all of you!!!
Post by jcoutu1 on May 28, 2015 5:45:26 GMT -6
Guys. Sorry for intrusion. I am Viesturs, CEO of Square Audio. Please ask any questions and I also would be grateful if your questions could be asked on Kickstarter and I will answer them there or as well here. Basically I launched Kickstarter to talk to people directly and not through corporation hyped marketing, I wanted to be honest as far my knowledge goes and to build a trust with with reasonable dialogue directly with everyone. Regards to all of you!!! Good to have you here. I expect that I'll have a few more in depth questions once I get a chance to check out your literature a bit in depth. Just a couple basics now. Sorry if this stiff is readily available on your site, I didn't see on first glance. What is is the driver size? What are the physical dimensions of the cabinets? How many watts is the amp? Are there any demo units available? If so, how do I get on the list to demo a pair? Also, don't be offended by any negative opinions of your products or difficult questions. We generally have a very open discussion here with some very technical people talking about the possible negatives and positives and we've had some manufacturers that couldn't "handle the heat" so to speak.
Post by viesturs on May 28, 2015 6:56:40 GMT -6
Guys. Sorry for intrusion. I am Viesturs, CEO of Square Audio. Please ask any questions and I also would be grateful if your questions could be asked on Kickstarter and I will answer them there or as well here. Basically I launched Kickstarter to talk to people directly and not through corporation hyped marketing, I wanted to be honest as far my knowledge goes and to build a trust with with reasonable dialogue directly with everyone. Regards to all of you!!! Good to have you here. I expect that I'll have a few more in depth questions once I get a chance to check out your literature a bit in depth. Just a couple basics now. Sorry if this stiff is readily available on your site, I didn't see on first glance. What is is the driver size? What are the physical dimensions of the cabinets? How many watts is the amp? Are there any demo units available? If so, how do I get on the list to demo a pair? Also, don't be offended by any negative opinions of your products or difficult questions. We generally have a very open discussion here with some very technical people talking about the possible negatives and positives and we've had some manufacturers that couldn't "handle the heat" so to speak. Thanks jcoutu1. Sure, anything I can answer in my knowledge! The literature I created is available on our web. That is a compact and kind of simplified in order to not make introduction things complicated. 1. Diameter of the driver is 5" 2. Dimensions - D 10'' (25cm), W 8'' (21cm), H 14'' (35cm), weight 18.7lbs (8.5kg), each speaker 3. Amp output power - 1% THD, 120W @ 8ohm ![](//storage.proboards.com/5388330/thumbnailer/TcT_GAOGD1C4pR3qP43e.jpg) 4. We have made ready product for demoing around and now it is a very busy time. I think by knowing the delivery or demo address I could see if and when the demo is possible I like critical discussions!
Post by jcoutu1 on May 28, 2015 7:53:15 GMT -6
Good to have you here. I expect that I'll have a few more in depth questions once I get a chance to check out your literature a bit in depth. Just a couple basics now. Sorry if this stiff is readily available on your site, I didn't see on first glance. What is is the driver size? What are the physical dimensions of the cabinets? How many watts is the amp? Are there any demo units available? If so, how do I get on the list to demo a pair? Also, don't be offended by any negative opinions of your products or difficult questions. We generally have a very open discussion here with some very technical people talking about the possible negatives and positives and we've had some manufacturers that couldn't "handle the heat" so to speak. Thanks jcoutu1. Sure, anything I can answer in my knowledge! The literature I created is available on our web. That is a compact and kind of simplified in order to not make introduction things complicated. 1. Diameter of the driver is 5" 2. Dimensions - D 10'' (25cm), W 8'' (21cm), H 14'' (35cm), weight 18.7lbs (8.5kg), each speaker 3. Amp output power - 1% THD, 120W @ 8ohm View Attachment4. We have made ready product for demoing around and now it is a very busy time. I think by knowing the delivery or demo address I could see if and when the demo is possible I like critical discussions! Thanks. PM'd address.
