Post by mrholmes on May 10, 2015 18:08:19 GMT -6
I would like to have something crappy next to my genelecs for checking. Should be active.
Can you point me in the right directoon, something google do not have clear answer to. Some say its Tannoy Reval 402?
THX Holmes
Post by carymiller on May 10, 2015 19:05:04 GMT -6
I would like to have something crappy next to my genelecs for checking. Should be active. Can you point me in the right directoon, something google do not have clear answer to. Some say its Tannoy Reval 402? THX Holmes Equator D6 or D8's...D8's are probably nicer if you have the room.
Post by svart on May 10, 2015 19:56:02 GMT -6
Active avantones?
Post by carymiller on May 10, 2015 19:58:05 GMT -6
I was thinking about those too...but they're much more upper mid focused than NS10's....still pay the extra $10 for black...the creams look awful! =P
Post by Ward on May 10, 2015 20:13:04 GMT -6
Neumann 120s. What you mix on them sounds better on EVERYTHING else. Liks NS10Ms but without the ear fatigue and with better bass response.
Post by Martin John Butler on May 10, 2015 21:35:36 GMT -6
I found the Adam A7X's to be very much like a new version of the NS10's. I agree with Ward too, the Neuman's are very easy to listen too.
Post by jimwilliams on May 11, 2015 10:11:42 GMT -6
Pricy too. I use a pair of $56 Parts Express mini monitors on my bench. They used the AMT ribbon tweeters and a 6" woofer, very revealing. Yes, you will hear more details with these than any silk dome cloth tweeter. Not active, but most internal speaker power amps suck. I use an Adcom GFA 535 with some better transistors and a lot of precision resistors, sounds amazing. It's a direct coupled design with a cap used for the +26 db gain set. I bought that amp new in 1990. It's a workhorse with thousands of hours of use, still going strong.
Post by Martin John Butler on May 11, 2015 11:58:54 GMT -6
I had that Adcom back in the day, kicked ass.
Post by Bob Olhsson on May 11, 2015 13:29:49 GMT -6
If Yamaha or anybody else knew why NS-10s or Auratones work so well, they'd be a hit. Most crappy speakers send mixes into left field a lot more often. Carl Tatz has best theory I've heard about NS-10s. He says that when placed on the bridge of a large console, they are almost the only monitors of any kind that don't have a big dip around 150Hz!
Post by mrholmes on May 11, 2015 14:46:30 GMT -6
Neumann 120s. What you mix on them sounds better on EVERYTHING else. Liks NS10Ms but without the ear fatigue and with better bass response. I heard my 8040 against the KH120. The construction is very similar, no big diffrence except that the Genelec goes down to 30 hz.....
Post by jimwilliams on May 12, 2015 9:22:30 GMT -6
If Yamaha or anybody else knew why NS-10s or Auratones work so well, they'd be a hit. Most crappy speakers send mixes into left field a lot more often. Carl Tatz has best theory I've heard about NS-10s. He says that when placed on the bridge of a large console, they are almost the only monitors of any kind that don't have a big dip around 150Hz! I did a lot of testing on that back in the early 1990's when I got my AP rig. I had Carl Yanchar of Lakeside Associates do the room tuning and we both found low end notching from any meter bridge mounted near field speakers. The fix was to tilt them up a bit or mount them a few inches above the meter bridge. It was all about the angles, like a game of billiards.
