Post by aremos on May 6, 2015 15:17:40 GMT -6
My Digi 192's internal clock does not work anymore after one of the external hard drives was inadvertently turned off. Has this happened to anyone ... solution?
Post by Ward on May 6, 2015 17:17:26 GMT -6
Reboot the computer. Start up PT. Then Command 2 (command and 2 keys simultaneously) and you can select the internal clock from the 192 again. You should consider upgrading the 192 to an Avid HD interface. It's a MUCH better sounding converter.
Post by aremos on May 6, 2015 17:50:27 GMT -6
Reboot the computer. Start up PT. Then Command 2 (command and 2 keys simultaneously) and you can select the internal clock from the 192 again. You should consider upgrading the 192 to an Avid HD interface. It's a MUCH better sounding converter. Ward, I'm not sure what you mean by "command and 2 keys simultaneously". I've rebooted hundreds of times, have restarted PT countless times, etc. When I access clock & choose internal the system will never sync & the green light perpetually flashes. External sync does work (& that's how I use my Apogee converters). Thanks, Ariel
Post by NoFilterChuck on May 6, 2015 17:56:43 GMT -6
he's giving you Mac keyboard shortcuts.
Post by aremos on May 6, 2015 20:47:46 GMT -6
he's giving you Mac keyboard shortcuts. Oh, ok, the session window (to choose clock source). Yeah I've also been doing that ... & the Hardware Setup also! And nothing.
Post by jeromemason on May 6, 2015 21:37:04 GMT -6
Maybe dump PT pref's?
Post by ericn on May 8, 2015 10:02:17 GMT -6
Double check all your clock connections! Nothing worse than a BNC that somehow isn't seated! Also power down and make sure the cards in the 192 are seated .
Post by Ward on May 8, 2015 14:27:21 GMT -6
he's giving you Mac keyboard shortcuts. Oh, ok, the session window (to choose clock source). Yeah I've also been doing that ... & the Hardware Setup also! And nothing. Depress the Apple (commend) key, and then the # 2 key on the side keypad. Make sure this is the window that pops up. It's where all your clockwork is contained.
Post by aremos on May 8, 2015 15:43:10 GMT -6
Jerome, Eric & Ward, Thanks for your help but it seems there there must be a serious problem inside the 192 ... All the clock sources work BUT the internal one - still. Ariel
Post by ericn on May 8, 2015 18:35:38 GMT -6
Post by aremos on May 8, 2015 21:03:30 GMT -6
Thanks Eric, Seems like it's exactly the help I need.
Post by ericn on May 8, 2015 21:09:26 GMT -6
Thanks Eric, Seems like it's exactly the help I need. I knew I booked marked that site for a reason !
